Turbo line kits
Old Aug 20, 2009 | 11:00 AM
Zero R's Avatar
Just in time to die
Turbo line kits
I get tons of calls for turbo line kits either for the water lines for the Garrett ball bearing CHRA's or just for braided stainless oil feed lines or drain lines. I setup product so you can now order any length line you wish. This means you can now build your own turbo line kits without issue.
Just so it's clear once the lines are made and purchased you own them so make sure you get your line length correct
Water lines for the Garrett ball bearing CHRA are high temperature shielded and come with hose ends and clamps.
They can be found here along with Oil feed lines and Oil Drain lines....
http://www.a-spectuning.com/store/in...ex&cPath=13_22
~S~
Old Aug 21, 2009 | 11:44 AM
Zero R's Avatar
Just in time to die
I thought I posted pics of the water lines. They come with straight ends as well.
FD7KiD
15
Feb 26, 2021 10:12 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
FD7KiD
Aug 17, 2015 11:50 PM
