Time Slips and Dyno Section is for posting 1/4 mile time slips and dyno graphs
Dyno question
Old Oct 2, 2013 | 08:35 AM
dark mephisto's Avatar
Rotating once again!!
Dyno question
So last weekend I went to a dyno day with my fc. When the guy was setting it up he hooked up the ignition pickup to the trailing number 1 wire. Shouldn't it have been hooked up to the leading ignition wire? At the top end of my dyno sheet it got a bit wavy but I don't have any misfires and my afrs are good. I was wondering if it was because of the hookup or I have other issues.
Old Oct 2, 2013 | 01:09 PM
Nevermind the ignition pick up... It is supposed to be on the trailing coil. I will upload my dyno sheets later if someone can give me some pointers on why my curve got wavy closer to peak. Thanks.
Old Oct 3, 2013 | 01:23 PM
RotaryEvolution's Avatar
Sharp Claws
you can do either but the settings have to be changed on the ignition angle since the leading is waste spark and fires twice as often as the trailing. i find the trailing ignition signal is weaker than the leading so often i choose to use the leading signals and place the pickup near the plug and not the coil.
lead angle is 180*
trailing angle is 360*
_Tones_
Adaptronic Engine Mgmt - AUS
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
