XS T04S Single Turbo Kit
Today my friend is tuning his car at XS. I left before they are even done. But the last few runs my friend was at 467rwhp @ 16-17psi on 92 pump gas.
Just thought to share..
Oh, the sound of the dyno pull is just amazing. It does sounded like the HP it's putting out.....cover your ears at all times if you don't want to be deaf.
Wayne
93 CYM R1
Prepaid Legal Independent Associate
http://www.prepaidlegal.com/go/wayneoun
Wayne
93 CYM R1
at what rpm does he see 15psi in 4th gear? what a/f ratio is he running and what kind of timing?
93 RX-7, the works
87 RX-7 (header/presilencer/catback/intake/pulleys/radiator/electric fan/suspension)
93 RX-7, the works
He ported the motor himself, so I guess he has his own porting theory.
The air fuel was somewhere in the range of 10.5:1, 1300cc 2nd / 850cc primar with about 72-75% duty cycle.
His using twin supra fuel pump he said.
My jaws just dropped to see that kinda hp with a T04S.
Wayne
93 CYM R1
Wayne
93 CYM R1
Trending Topics
wow that ratio is rather conservative.. he should see if he gets any gains running 12.0. Hows his timing at? **** I might have to get a TO4S instead of a T66 =] Hows the spoolup on that turbo?
What ECU is he using?
What about the rest of the relavant mods...
Thanks!
Inquiring minds want to know!
Mike
Michael J. Gallagher
'93 Mazda RX-7 Base
Pensacola, FL
Thanks!
Mike
'93 Mazda RX-7 Base
Pensacola, FL
He has a great car. The exhaust is rather loud though.
We are hoping he keeps this motor together for a good long time.
The car is supposed to be awesome!!!
Rick
Rotary RX-7 = tootsie roll pop (how many
licks does it take?)
Rick
I was wondering where i can get a T04 cast iron manifold from CHEAP!!?? I know jason sells it at the store for $599. the manifold that i have is all rusty and have little cracks on the welds. pls. let me know.
HOLLY ****!!
i only dyno my T-78 450rwhp @ 20psi with race gas at rotary performance. i also have street ported motor , new GREDDY FMIC with 3" piping, heltech E6K, 1600cc RP FUEL SYSTEM. my air/fuel ratio is about 12.1 before 6500 rpm 11.8 after 6500 rpm.
When I left he was getting 467rwhp, I guess they tweak the air fuel alittle more to get 477rwhp. Awesome.
I posted his mods at the Power FC section, but yeah he's using Power FC:
1300 secondary / 850cc primary
Twin Supra Fuel Pump?
SX Fuel Pressure Regulator
XS T04S kit
Apexi AVCR boost controller
HKS Titanium exhaust 4" straight through
XS Ported Motor
3mm Apex Seals
1.1 bar of boost
Custom Apexi FMIC
Hm..that's about it. Just crank up the boost and tune. The HP was achieved via Eric Hsu's magic tuning, with I think close to 30 pulls on the dyno...scary.
Then my friend called me next day and told me the car is rather scary to drive now. He's going to Sevenstock btw since he works for XS and XS will be at 7stock.
I am not sure about the timing though..
Wayne
93 CYM R1
XS T04S kit
XS Ported Motor
3mm Apex Seals
1.1 bar of boost
Custom Apexi FMIC
Wayne
93 CYM R1
those are some awesome numbers... especially at such a low psi on pump gas.. does anyone know how much that XS kit costs?? I imagine alot of it is in XS building and tuning the motor too....
I would be carefull of posting BS FLAGS
I get 520bhp at 1bar 14.5psi boost with a TO4 wich is over 450rwhp.......at std temp and std pressure day.
Now depending on ambient conditions and dyno accuracy it would be easy to have a difference of + or - 5% if there is no correction factor applied for the variations in atmospheric conditions.
Let alone individual dyno accuracy.
450+rwhp is very achievable with a TO4 and street porting on a "proper street port" 13B
Street ports do vary! go visit my web page and look under porting...this is the reason why I make so much power at lower boost levels.
Nice power, go the TO4
Originally posted by Roy Johnson, Jr:
[/IMG]
(Flag borrowed from sunnyvalemazda)
[/IMG](Flag borrowed from sunnyvalemazda)
All you have to do is call XS. If it's BS then it they are in on it. They confirmed on 2 occasions to 2 people.
Perhaps the BS flag should have been posted on your thread when you 'cancelled' your T-78 purchase that was such a great deal?
Uh-huh...see what I mean?
Regards,
Passenger
Posts: n/a
OK I dont know much about turbos yet. Fourtunatly Rotary Performance is just on hte other side of dallas from me. Im slowly gathering the pieces to make my NA in to a turbo car. I have found a couple turbos in the local wrecking yards but they wouldnt spin and didnt look liek they were rebuildable (I did stash them in case that isnt true). What is the best turbo out there that I should be looking for? Im basicly rebuilding my 2nd gen for fun now and later to turn into a more dedicated race car later.
Any help will be appreciated.
Thanks
87 Sport
Bonez cat
N1 Single exhaust
142k and still kickin
Thanks
87 Sport
Bonez cat
N1 Single exhaust
Well, I guess we'll jsut wait until the car goes to the track and brings us some slips...that'll tell a lot.
I've just know there are too many ways to manipulate numbers on a dyno. I'm not saying this was done.
FYI: The T-78 was (and still is) a great deal. If circumstances change, I'll still probably get it.
'95 VR RX-7 R2 - New Engine w/ Street port, intake, dp, mp, cat-back, BOV, elbow, pulleys, Trust SMIC, Alcohol/Water Injection, i/c pipes, clutch, 9.5# fly, fuel pump, rising rate regulator, 1200cc Secondary Injectors, Power FC, Factory Rebuilt Turbos, 17# boost, HKS Twin Power, 10mm wires, NGK plat. plugs
I'm with you, Roy. Timeslips talk, BS walks....errrr something like that. Those are the highest numbers I've ever heard of and its not by a small margin, more like about 50 hp. No flames, maybe theres some magic part of this buildup the owner hasn't disclosed or something (n20, massive porting, ect). Even single turbo Supras wont lay down that much at 15 psi(bad comparison I know).
The car has massive porting. No nitrous. Car will be at 7stock I think.
Porting, tuning and Sizing your turbo correctly.
Putting off the shelf parts will just get you off the shelf number. That's what everyone do because that's what majority of you do. But because someone went the other route and got a different result does not mean it's not possible.
Wayne
93 CYM R1
Wayne
93 CYM R1
