Fuel injectors clogged?
Old Aug 7, 2001 | 08:27 PM
HAILERS's Avatar
HAILERS
Could it be that the engine that is in the car is one who's injectors are the low impedence (about 3ohms) and the impedence of the new engines injectors is high impedence(12 ohms)? It does indeed sound like they are not operating. What year car is this? What year car did the new engine come out of? Then again it could be something else. If you pull all the plugs out and spin the engine over for ten to fifteen seconds do you get a fuel mist out of the plug holes? If not it just ain't injecting. Check ohms value.
Old Aug 8, 2001 | 12:29 PM
HAILERS's Avatar
HAILERS
Sounds like the injectors are the wrong ones especially when you mentioned the offset tab on the connectors. That offset I'm sure was to make the design idiot proof so you could not put the wrong injector on. They were wrong. I can put that plug on either injector. Done did that before. OOOps, what did I just call myself? If you have a wiring diagram you can ohm the injectors out from the ecu. As I write this I forgot what your car is, n/a or turbo. If n/a the secondaries are not hard to get to. Even if they were the right ones they play no part in starting so they could be good and the primaries bad. Cannot win.
Old Aug 9, 2001 | 07:34 AM
RETed's Avatar
Mazda changes from low- to high-impedence fuel injectors mid-year for the 1987 models.&nbsp I think the cut-off date was 07/87 in terms of build date...
-Ted
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
82streetracer
Aug 23, 2015 09:28 AM
