Electric Impact Wrench
Old Aug 6, 2001 | 07:55 PM
HAILERS's Avatar
HAILERS
I would appreciate some input on what is a first rate electric impact wrench for removing say the rear hub nuts on a rx7. One that would be good for the flywheel nut also. One that you have used and works on these items. I've broken half inch sears breakover bars on the hub nuts and had to cut the nuts off in the past.
Old Aug 7, 2001 | 12:51 AM
fcturbo2's Avatar
Re: Electric Impact Wrench
Whenever i take motors apart i use my DEWALT electric impact wrench. It worked good removing the hard to undo flywheel nut!...
Old Aug 7, 2001 | 08:52 AM
tims's Avatar
Milwaukee 1/2" electric impact has removed many a stubborn nut including the flywheel, rear stub axles, and pinion flange nuts.
Old Aug 7, 2001 | 09:56 AM
RexMan's Avatar
Milwaukee 1\2.......Definitely.
Old Aug 7, 2001 | 10:56 AM
HAILERS's Avatar
HAILERS
Thanks for the DeWalt, Milwalkee input. Whichever I spy first I'll buy. And REXMAN, thats interesting device that you made with your Milwalkee impact wrench! (humor).
WANKfactor
Sep 29, 2015 01:14 PM
nycgps
30
Sep 29, 2015 12:02 AM
