BBS rims and tire size
Old Mar 26, 2008 | 07:17 AM
Rotarywall's Avatar
Plan Golf
What is the widest tire someone put on the BBS vert rim and if i could see some pics I was thinking about 225/55 at least in the rear but I don't want the tire to stick way past the rim. Send some pics let me see what they look like.
Edward
Old Mar 26, 2008 | 07:20 AM
RETed's Avatar
Why do you want such a wide tire?
I would think a 205 wide tire is about the widest I'd go with the 6.0"? 6.5"? width...
Going with a wider tire than the rim can handle will degrade performance due to too much sidewall flex.
Old Mar 26, 2008 | 07:29 AM
SCCAITS's Avatar
SCCAEP
They are 6.5" rims. I ran 225/50/15 on the BBS Vert wheels before. I no longer use the wheels but here is an old picture...
225/50/15 Toyo RA-1, BBS vert wheel, no spacers, coilover suspension
wrankin's Avatar
Old Rotary Dog
Vert rims are 15x6.5. You can go out to 225 fairly safely (common size for a track tire would be 225/50r15). You may or may not see any performance gain depending on the tire.
(edit: too slow this morning )
-bill
Old Mar 26, 2008 | 02:37 PM
KhanArtisT's Avatar
Former FC enthusiast
If you just want it for the wider look then go for it, a lot of people with the vert wheels run 225s. The sidewall flex probably cancels out with the extra grip from the bigger footprint so not too much of a performance gain, if any.
Old Mar 26, 2008 | 05:45 PM
misterstyx69's Avatar
Retired Moderator, RIP
225/50/15 Falkens on my FC..with BBS Vert Wheels..Excellent Handling.VERY good Grip(maybe too much!).
