Pics of my first motor
Old May 23, 2002 | 10:18 AM
RacerXtreme7's Avatar
NASA geek
I built this like 3 years ago, watcha think? I have sence pulled it back out and sold it. My new project is a series 5 ( 89-91 ) turbo motor. Should be gorgeuos and lots of reliable power. 3rd gen upper, LARGE street port, all the internal goodies and a hybrid turbo .
Old May 23, 2002 | 10:19 AM
NASA geek
pic #2
Old May 23, 2002 | 10:20 AM
NASA geek
pic #3
Old May 23, 2002 | 10:21 AM
NASA geek
pic# 4... I got 4 more,, sorry I dont know how to post all in one message
Old May 23, 2002 | 10:22 AM
NASA geek
pi# 5
Old May 23, 2002 | 10:23 AM
NASA geek
pic# 6, 2 more
Old May 23, 2002 | 10:24 AM
NASA geek
Old May 23, 2002 | 10:26 AM
NASA geek
last one.. #8
Old May 23, 2002 | 10:27 AM
vosko's Avatar
Just Call Me Terminator!
that engine looked good. can't wait to rebuild mine!
Old May 23, 2002 | 12:56 PM
NASA geek
Thanks vosko, that all the feed back I'm gonna be getting?
Old May 23, 2002 | 01:09 PM
wozzoom's Avatar
Looks pretty sweet! So what are the specs:
What application is this going in?
What internals are you running?
What modifications have you done?
We need details!
vaughnc's Avatar
knowledge junkie
I need one of those engine mount stands, where can you get them cheap?
Old May 23, 2002 | 01:18 PM
KNONFS's Avatar
B O R I C U A
http://www.harborfreight.com/
Old May 23, 2002 | 01:19 PM
KNONFS's Avatar
B O R I C U A
How much HP did that puppy pumped? Any 1/4 times, it is very PUUUUUUUUUURRTYYYYYYYYYYY
Old May 23, 2002 | 01:29 PM
NASA geek
Well, I no longer have this engine, I recently sold it to fund my series 5 turbo project. Spec wise.....86 motor.
*LARGE street port.
*Smoothed aux ports.
*89-91 Light weight high compression rotors.
*89-91 NEW turbo rotor housings (89-91 has revised leading plug hole placement, turbo has no stupid exhaust splitter in port and turbo housing have a special coating to the surface.) ported
*Light steel fly wheel
*centerforce II clutch
*all roating assemly balanced to couple grams.
*shimmed oil relief (85 psi)
*oil pan baffle (MsO2 coated)
*side housings were MsO2 coated.
*rotors were treated with heat tranfer coating on in side.
*Dellorto carb system.
*True dual exhaust (all RB and LOUD!!)
*almost all parts were new.
*custom tps bracket to allow stock ignition to work properly, custom OMP rod/linkage.
* lots lots more i can't remember at moment, new owner should have miles and miles of service.
I estimate the motor made around 200 hp give or take 10. It was fast in my 86 sport, flames were HUGE!!
I now have a 90 GTU and a 91 Turbo II. The 86 was parted out.
As far as stand,, it was made by a friend a loooong time ago, check Mazda Trix.
Old May 23, 2002 | 04:00 PM
MaxRX7's Avatar
hambre y sueño
wow, that's awesome.
my TII rebuild was the same except for the streetport. no carbs by the way.
Old May 23, 2002 | 04:45 PM
QC Motorsports
That is one beautiful peice of work
I don't think I could Get rid of something like that. I would like you to send me thoughs pics in e-mail
mordoris@hotmail.com
I love the way that engine looks.
Charles
Old May 23, 2002 | 04:53 PM
NASA geek
THANKS!!! Its good to get positive feed back when you work so hard on something . I was so obsessive I even took all the crimp / wire holdown thinggys that hold the wire harnesses in place and beed blasted, then painted, then dipped them in a rubber coating . There the red things in the pic. peacekeeper, pics are on their way to you.
-Mike.....
Old May 24, 2002 | 12:53 AM
NASA geek
BOOST!!!..can't wait
cristoDathird
28
May 30, 2019 08:47 PM
Azevedo
26
Mar 1, 2019 09:19 PM
incubuseva
14
Sep 3, 2015 12:37 PM
