Owned by a flywheel nut
Old Feb 3, 2004 | 07:56 PM
Sgtblue's Avatar
Urban Combat Vet
OK, tried most of the day to get the flywheel nut off of my FD. Looks like it's been off at one time, but it wouldn't budge. I literally broke a fair quality 18" breaker bar with a 24" cheater pipe as an extension.
Now I understand that these things are put on with something like 350+ ft/lbs of torque, but mine must have been put on by some Summo wrestler or Binky the 800 lb Gorilla. I bought the rear seal etc to install w/my clutch but I getting ready to give up and leave the flywheel. Anyone got any suggestsion or know where Binky lives now?
Old Feb 3, 2004 | 07:58 PM
R-magic's Avatar
Heat it up!
Old Feb 3, 2004 | 08:00 PM
Mahjik's Avatar
Mr. Links
Air tools....
Old Feb 3, 2004 | 08:21 PM
94RXMAGEE's Avatar
I agree with the air wrench, mine came off with no problem.
Old Feb 3, 2004 | 08:28 PM
Sgtblue's Avatar
Urban Combat Vet
Impact was tried, didn't even come close. ISUposs and I also tried heating it up with a propane torch. Might be able to give that another try though, the flywheel was really conducting the heat away from the nut fast and I don't think I got it real hot. I was just afraid of cooking the bearing or worse.
I'm tellin ya, this bad boy is on there. I used the above breaker bar and cheater pipe extension. While grabbing on to the left front a-arm, I pushed with both of my legs. Had to have put well over 450 lbs on it before breaking the breaker-bar. I was even getting afraid I might do some damage to my motor mounts I was pushing so hard. Unbelievable.
Old Feb 3, 2004 | 08:35 PM
Hyperite's Avatar
Vagina Junction
Impact took mine off in about 8 or 9 seconds. Ingersoll Rand 1000ft-lb reversing power...oh baby.
Old Feb 3, 2004 | 08:42 PM
TheCrazyAZN's Avatar
LOL, just take a look at what i used
https://www.rx7club.com/forum/showth...ht=thecrazyazn
Huy
Old Feb 4, 2004 | 12:12 AM
KoalaFD's Avatar
The Rotary Hermit
Wow... you broke the breaker bar?
Old Feb 4, 2004 | 01:22 AM
poss's Avatar
Slower Traffic Keep Right
Jim, we should break out the cutting torch for tomorrow.
Old Feb 4, 2004 | 12:04 PM
powermalex's Avatar
Use a dremmel instead and break the nut.
Old Feb 4, 2004 | 12:19 PM
mad_7tist's Avatar
you just need biger air tools! and yes it is a bastard. i have that IR 1/2 inch gun and it just wings that baby off
Old Feb 4, 2004 | 12:20 PM
Enconsiderate's Avatar
I am so smrt.
Just remember righty tighty, lefty lucy. LOL
Wouldn't that be funny if your were turning the wrong way.
Old Feb 4, 2004 | 12:39 PM
Kento's Avatar
2/4 wheel cornering fiend
Some sort of impact-type tool is necessary for this. The problem with using leverage like an extension on a breaker bar is that the torque is applied gradually (compared to an impact), and that's often not enough to break the torque and/or contaminants in the threads that are holding the nut on. Although not in this case, it can also inadvertently cause damage to other parts if the impact's quick torque application isn't used.
Old Feb 4, 2004 | 01:04 PM
DrunkenBowler's Avatar
Wrong way wat. Anyways, instead of a 24 in extension, get a 4 foot extension, and a new breaker bar.
Or u can go easy and take the easy way out and get big tools.
Old Feb 4, 2004 | 04:09 PM
rex u.k's Avatar
Ingersoll Rand make very powerful airguns, but the one i undone yesterday took a 5ft cheater over a 24" proto breaker bar, flex was like a bow before it let go,those proto breaker bars are the best.3/4" bluepoint impact wrench wasn't doing ****.
All depends on how much locking paste is on there,some break easier than others.
Old Feb 4, 2004 | 04:17 PM
Kento's Avatar
The "impact" doesn't have to be pneumatic.
Old Feb 4, 2004 | 05:01 PM
vspecpgt's Avatar
holy cow.... mine is sitting waiting for me in my garage.... now i'm getting scared.......
Old Feb 4, 2004 | 05:46 PM
BLKTOPTRVL's Avatar
I used a one inch socket and a 7 foot cheeter to remove the nut from my '71 (also 350 ft lbs.).
Old Feb 4, 2004 | 05:47 PM
Sgtblue's Avatar
Urban Combat Vet
From my current experience, I agree with KENTO for exactly the reasons he stated. #1, the quick application of torque to break it loose and #2, if I would have kept going, I think I would have begun stressing the motor mounts unnecessarily. I could really feel and see the engine rocking back and forth when I was pushing and it didn't look good.
The reason to pull the transmission in the first place was to fix my 5th gear synchro and replace the clutch. I've got about 60K on my car and the flywheel surface really didn't look too bad so I re-packed the pilot bearing w/grease and left it. That friggin' flywheel nut beat me....this time. But if I ever have to pull the tranny again I'll be better prepared. Thanks to ISUposs who helped out ALOT, I now have some experience. And next time I'll have a better compressor and a much bigger impact.
Old Jul 4, 2004 | 09:21 PM
Snook's Avatar
Tony Stewart Killer.
impact wrench bud 2 seconds
Old Jul 4, 2004 | 10:37 PM
MakoRacing's Avatar
Where has my $ gone?
I had a 4ft bar and it wouldnt come off with my dad and me pushing on it, so i cut 1/3 of it off and it came of no prob!
Old Jul 4, 2004 | 11:03 PM
dgeesaman's Avatar
It's not easy when you don't have $1500 and space for big tools.
Dave
Old Jul 4, 2004 | 11:13 PM
busy13b's Avatar
Om Namah Shivaya
n/m --> old post.
the prob has long since been resolved...
Old Jul 4, 2004 | 11:19 PM
Flybye's Avatar
It's never fast enough...
Originally posted by Sgtblue
From my current experience, I agree with KENTO for exactly the reasons he stated. #1, the quick application of torque to break it loose....
Yep Yep.
What you might need is get a good breakerbar and a small sledge hammer.
Have someone hold the socket in place with the nut and whack the breaker bar with the sledgehammer.
Old Jul 4, 2004 | 11:30 PM
Godzilla-T78's Avatar
haha my stinking $1000 air tools couldnt do it, I just sprayed it with oil, drank alot of coffee, got really pissed and my big german *** took care of the rest... I hung under my car on it for about 2 minutes and the constant pressure of 300lbs pulled it loose.
