broke small a/c line
Old Sep 16, 2003 | 01:32 AM
twinturboteddy's Avatar
Grumpy Lurker
So yeah was working on the car last night and accidentally broke an a/c line.
System was full so spent 20 minutes waiting for all pressurized freon to stop hissing.
Anyone have any experience replacing this particular line. It's the small a/c line that runs alongside the reinforcement bar that sits inside the engine. I cracked it near where the main radiator hose is.
Here are some pics.
I highlisted the broken a/c line in yellow
Old Sep 16, 2003 | 09:16 AM
DaleClark's Avatar
RX-7 Bad Ass
Typically AC lines are pretty easy to replace. Remember, Mazda installed a lot of the Rx-7 AC systems at the US port - they're designed to be installed relatively easily without taking a lot of stuff apart.
That said, it's probably best to get a new line - either new from the dealer (probably not too much $$$) or a good used one. The fittings at both ends aren't torqued super tight - just use two wrenches and it should come apart easily.
Get two new o-rings - one for each end. Mazda dealerships typically have them in stock, and they're cheap. Lube the new o-rings with dielectric grease to keep it from sticking/tearing, and install. Then, pull the system to vacuum and re-charge with freon.
BTW, there are two different AC systems - the Japan installed and the port installed. I believe the hard lines are different between the two systems - make sure you get the right one. Also, I would leave the bad line on until you get everything ready to replace it - leaving an AC system open to moisture is a bad thing.
Good luck,
Dale
Old Sep 16, 2003 | 09:44 AM
r0gu3's Avatar
Boostless FD
I have that line sitting in my closet ....
Old Sep 16, 2003 | 10:05 AM
Grumpy Lurker
Oh really? how much do you want for it?
Old Sep 16, 2003 | 10:23 AM
Grumpy Lurker
It does look easy to replace being that line isn't that big, probably less than 3 feet in length. The ends look easy enough to reach, however I fear the cost of the pipe to be a little high because it looks like there is a regulator of some kind that is attached to it near the battery.
I had no idea Mazda installs the AC systems at the US port. Interesting.
Thanks for you advise, it will come in handy. I'm definitely leaving the broken line on until a replacement comes in. Aiming by end of this week.
Good luck,
Dale
Old Sep 16, 2003 | 10:37 AM
NewbernD's Avatar
Tequila? ..it's like beer
R1's had port-installed AC.
Oh, and that "regulator thing" is just a pressure switch.. so your compressor won't engage on an empty system.
Old Sep 16, 2003 | 10:42 AM
Grumpy Lurker
yup mine's a r1, port installed it is.
Old Sep 16, 2003 | 11:15 AM
r0t0r-rooter's Avatar
call me Smokie Smokerson
Batmobile recently took out all his A/C lines & junk. You might wanna check with him to see if that was the 1 thing that broke on his (which prompted him to remove the whole thing).
Old Sep 16, 2003 | 12:47 PM
alwan16's Avatar
you can get the line welded up at an a/c shop for $20. also, before you go buying a used a/c line from somebody there were two types of a/c systems put in the car. they use different lines. one was mazda and one was some other japanese brand that i forgot. just an fyi.
Old Sep 16, 2003 | 01:05 PM
Jonesboro's Avatar
Look in the yellow pages for automotive A/C parts shops, the places that supply the parts to the A/C service shops. They can fabricate a new A/C line for you to match the line that broke. Simply take out the broken line and take it to them to duplicate: length, bends, and fittings. No big deal.
Old Sep 17, 2003 | 11:14 AM
jfirko's Avatar
the same thing happened to my line. I got some stuff called braze perfect or something and a torch and fixed it. I found the stuff on the web. I think it was like 7 bucks and comes with enough stuff to fix more then one line. It has worked fine since. Almost a year since the fix.
Old Sep 17, 2003 | 01:51 PM
Grumpy Lurker
Ordered a replacement line from Mazda, cost was about 100. Oh well. Now I gotta look into getting the system re-filled
Old Sep 17, 2003 | 10:01 PM
ErnieT's Avatar
Living life 9 seconds at a time
Teddy,
I just removed all my lines. If you want to give me the shipping costs and $20 I'll send you both lines.
Old Sep 19, 2003 | 10:02 AM
Grumpy Lurker
Old line is out and replacement line is in.
When I removed the old line I didn't notice any o-rings???
Should I use some sort of thread sealer like teflon tape on the threads before I tighten everything down?
DAMN Ernie I just spent the 100 bucks on a new one! Too late otherwise I would have bought yours.
Good luck,
Dale
Old Sep 19, 2003 | 10:11 AM
r0gu3's Avatar
Boostless FD
I guess you didn't get my response?
Old Sep 19, 2003 | 01:47 PM
DaleClark's Avatar
RX-7 Bad Ass
Double-check - there IS an o-ring there. You *HAVE* to replace the o-ring when changing the line, otherwise the freon will just leak back out.
It's probably inside one of the lines. They typically have a male and a female end, and the oring goes around the male end of the pipe.
Don't use pipe sealant on the threads - bad idea. That won't hold the kind of pressure an AC system sees - that's the high pressure line, which is a few hundred PSI!
Dale
Old Sep 19, 2003 | 01:57 PM
DaleClark's Avatar
RX-7 Bad Ass
Double post...
Old May 13, 2004 | 01:44 AM
jbz12's Avatar
Cool AC lines
Originally posted by ErnieT
Teddy,
I just saw your post. I have a snd gen and need ac lines. Pls send more inf if you still have your lines. I have replaced from the junkyard and the line is CRAP. Mazda says they don't have AC on this model.
Thanks,
Jim
Old May 13, 2004 | 02:29 AM
SpeedKing's Avatar
Power Trippin'
Re: AC lines
Thanks,
Jim
Hey Rip Van Winkle, you know this thread is from 9/03, right?
Old May 13, 2004 | 03:23 AM
alwan16's Avatar
same thing happened to me when i was swapping motors once. take off the line and most likely an a/c shop can weld up the line for you for $20. no big deal...
Old May 13, 2004 | 05:45 AM
InsaneGideon's Avatar
Still on 1st engine
...may as well do the R134a conversion now.
Old May 13, 2004 | 10:30 AM
Hyperite's Avatar
Vagina Junction
FYI- take the line off if you want, any moisture in the system will boil off when you vacuum pull it to -27inHg.
Old May 14, 2004 | 03:07 AM
Still on 1st engine
The thread keeps growing!
May as well ask, if you refilled with R12, how much was it going for last year, Teddy? My parents have a can or two sitting in their garage... I've been debating on whether to keep it and top off the daily driver or ebay it!
Old May 14, 2004 | 06:53 AM
dubulup's Avatar
development
Re: Re: AC lines
hey teddy let me know if you need any help
Old May 14, 2004 | 06:12 PM
Still on 1st engine
Re: Re: Re: AC lines
Oops, I re-read jbz12's post: "I just saw your post."
He's apparently aware of the age of the original post, so I guess we should give him a serious answer.
He' obviously using the search function.
jbz12, are 3rd & 2nd Gen lines even compatible?
