Is this the sound of an apex seal gone bad?
Help, what's wrong with my 12A?
It's in a 1984 GSL, stock except exhaust has been running great on the 110 mile daily commute for the last few years. Then on Wednesday it started to fade while traveling the interstate into work, not bad but annoying at high speeds. Same problem on the Thursday commute, it seemed like fuel starvation so when I got home I replaced the fuel filter and checked the pump output, but both looked fine. No change Friday morning, still the high speed fading, but then on the way home it got worse, I had to rev it at stops to keep it from stalling.
Saturday morning I knew I had a problem, the cold engine hardly ran. I have a 2GDFI installed, so I switched back to the stock ignition to eliminate an ignition problem, still no change. A close look at the ignitors and dizzy cap and rotor showed these were all fine - the plugs are NGKs that were installed about three weeks ago and they look fine. And the timing light showed leading and trailing ignition firing normally.
Still thinking it must be fuel delivery, I pulled the top half of the carb, checked the float valves and level and used the air compressor to clean things up, but there weren't any obvious problems in the recently rebuilt carb (1 year old). Also fuel is jetting into both primaries and secondaries when the accelerator pedal is depressed.
So it's sinking in that it might be the engine. I soaked it with Sea Foam, spun it a few times, added more Sea Foam and let it set overnight. On Sunday I blew out the Sea Foam, added fresh plugs and got it running again. Still no change.
Here are videos of the situation. Here's how it was running Tuesday:
http://youtube.com/watch?v=n3Va3xwWzVQ
Here it is now:
http://s259.photobucket.com/albums/h...=engmov004.flv
Could it be that I have a bad apex seal? I don't have a compression tester but with the plugs pulled both rotors whooshed and blew air like nothing was wrong. Both trailing holes made strong and equal compression when I plugged off the hole with my thumb, while the leading holes seemed to be sucking as much as they were blowing. Is this normal? Just listening to the compression with the plugs out there really doesn't seem to be anything unusual.
The timing didn't change of course but could something else affect timing to make it run like this? I checked for vacuum leaks but everything seems tight and fine.
Do I have a bad apex seal? Is there a way to tell without the official Mazda compression test?
Thanks
Ray
Here it is now:
Thanks
Ray
Well I would double check you're fuel output under load, which is kinda hard to do. About the only suggestion I can think of first is if you have a spare fuel pump. Second is you can use a regular compression tester, just have to take out the valve in the end of it and watch the gauge. It'll change a little being warm or cold, so prolly best to do it warm. No telling really if its an apex seal until you get a good compression test. 2 bad compressions and 1 good means a apex seal, 2 good ones means one face has bad side seals.
Thanks for the suggestion on the home made compression tester, RX-7 buddy Crit has one of these he offered so I will take him up on that.
I wish it were just a fuel problem and I have a spare pump I thought about installing but all the signs are that won't help. While the problem started out on the highway at high speed, it now is happening while sitting in the drive at idling speeds when fuel delivery demands are minimal.
Also I pulled the gas feed to the carb and ran the pump and it filled up my 1 quart receiving bottle with no trouble. As I mentioned above, all the jets are squirting plenty of fuel and gas reaches half way up the view windows on the sides of the carb, so it looks like it is getting plenty of fuel.
Still I neglected to check those two little barrel screens that sit in the fuel horn or whatever it's called right where the gas first enters the carb so in the interests of eliminating everything I will check those out once this cold front moves on by.
But it sounds like the backyard compression test is what I need, thanks for the suggestion. If that shows the compression is good (which it sure sounds like with the plugs removed) then I'll go hunting again.
Any other insights or suggestions appreciated!
Thanks
Ray
Thanks
Ray
Any weird popping noises while you are on the throttle? Before my apex seal finally went, it would pop when engaging the secondaries. If you have good speakers, or a nice headset, then you can actually hear it in my most recent "Muskegon" autocross video. Not sure if this will help you.
When I get home from work, I'll check out your videos. But in the mean time, it might be worthwhile to visually inspect your jets just to make sure you haven't picked up some debris. Just pull out the two bolts below the window, loosen the jets, then extract them with a wooden toothpick. That way, you don't need to pull the top off the carb again...
Trending Topics
From recent experience, a blown apex seal sounds much worse than that. I won't idle at all either....sounds like a lawnmower.
Post a vid like the first one....engine shot would help us to hear more.
I hate drum brakes
on
Actually, my engine sounded EXACTLY like this when it blew, but it wasn't a broken apex seal. I was having oil consumption problems and large amounts of smoke on deceleration, and eventually it wouldn't run on both rotors. I assumed that the front rotor had a bad oil seal, because it would foul plugs quickly. When I took the engine out, the front exhaust port was oily black (rear was normal tan). When I disassembled the engine, the front rotor housing had chatter marks and really bad step wear on the irons. the apex seals were not broken, but the oil control rings looked kind of bad (but not broken).
Say hello to Mr.Wankel
ray-- ill be in oakwood all day tomorrow. all i have to do is school and some school work. so whenever you can swing by oakwood is fine by me.
ill pm you my cell number. actually. if you can do it in the afternoon then ill just do the test for you. let me know.
keep it original!!
well check my thread out https://www.rx7club.com/1st-generation-specific-1979-1985-18/my-rx7-sick-%3D%5B-579862/ it has some vid sound clips there. maybe its a vacuum leak since you can rev your car fine but doesnt idle
Famous Taillights
Just on the off shot, have you checked the trailing ignition out put? Check if the coil is firing. Judging by the ease of you being able to start it, I doubt it is a blown apex seal. When mine went, it was very difficult to start hot and it took a bit to start it cold. I also had to crank the idle up to keep it running
Can't view the second video, down for maintenance. I'll check again tomorrow. When my apex went, the car would idle but it looked like it was shaking itself apart...
Resurrecting Gus
Ray,
This may or may not help, but try removing a spark plug on the front rotor. Pull off ALL of your plug wires too. Crank it over several times and listen to all three apex seals puffing through the spark plug hole. You should be able to hear nice puffs on all three of the apex seals. Usually if you have a bad seal you can hear the difference just by cranking it over. You will hear two weak puffs, and then a strong one if you have a bad seal. Repeat the same procedure for the rear rotor. This is a good free test that may or may not tell you more info. It's like the poor man's compression check.
Good luck!
Jamie
Good luck!
Jamie
on
What do you know about the history of this car? How many miles when you bought it? What did the sump oil and coolant look like when you got it? Did it have a coolant leak? How many miles have you put on it? Have you been using MMO or 2-cycle premix? Do you warm it up in the morning? Do you observe the redline?
Stu-Tron Get Yo Groove On
Hey Ray, if it comes down to it I still have a spare 12a here I have not torn into. I kept it around in case of emergencies. I guess this looks to be the beginning of one (hopefully not). Let me know if you need it, I can run down there sometime and we can just exhange yours for mine. I saved the one without the front cover oil leak.
Yep for sure, the last four posts have been nothing but good news and generosity. I'm up to my ears in broken down cars, my wife's jeep just went on the fritz again (thought I had that one fixed) and I'm trying to figure out if I can fix the white one or whether I need to put it in the hospital and get the silver one ready for the road - it all rests on that compression test.
Jamie your idea sounds like its the poor man's answer (and I am one of those) so I will try that first - I wish I had thought of that trick!
Also Crit has a ghetto compression tester that he will loan me, hopefully if Jamie's methods doesn't work I can pick that up tomorrow and put it to use to see if it really is a compression problem.
Dave no cats on the White One, just a bonez pipe hooked up to the stock manifold and back to the stock cat back system - a poor man's racing beat set up.
Stu thanks, I might take you up on that. Would you and your Carolina boys want to do the rebuild, maybe put a mild street port in it? (Stock is fun, but life is short).
Bliffle, I got the white one about three years ago with 83,000 miles on it. It needed some minor brake and exhaust work and I swapped in a tranny that didn't growl in high gear, but after those minor repairs I got 60,000 trouble free miles doing the daily commute, almost all out on the highway doing the speed limit and a few other speeds. Everything about the car is in top shape, I maintain my GSLs well, but I think I did make a couple mistakes that together may have contributed to wrecking an apex seal, if that's what's happening.
First, about three months ago, I stopped adding my 8 oz of MMO to every tank full of gas, as I had been in all my commuter GSLs for the last seven years. Hundreds of thousands of miles and never even the slightest problem with any of the 12As I've been driving - I really believed they were bullet proof. I'm going back to the MMO from now on.
Second the car was running so well I was beginning to drive like Stu, all the time. I was even stopped one predawn morning a few weeks ago in Gwinnett on my way into work. I was read the riot act (yes everything he said was true and then some) and then was let off with a warning and a comment about my "little car" and "getting killed". I think our police officers like 1st gen RX-7s.
So put 2 + 2 together (not enough lube and hot rodding) and you get a wrecked seal - it ain't rocket science.
So now I've got to fix the jeep and we have a major freeze coming tonight, which means I now have to move the dozens of house plants I just put outside last week back in the house - all before the sun goes down. If I get that done I'll do Jamie's poor man's compression test. If that doesn't work I'll try Crit's ghetto compression tester. Then I will report back.
If it really is a bad apex seal we can archive the video so people can listen first hand to the bad news.
Thanks y'all!
Ray
Thanks y'all!
Ray
Thanks Jamie, we're still waiting for the fat lady to sing on this one, I haven't given up yet.
Hey Boyee, my engine sounds just like yours in this clip:
http://youtube.com/watch?v=v3JifX9jhr0
You say that was just an ACV problem? It's probably wishful thinking, but maybe I don't have a bad seal after all?
It's getting good spark to all four plugs (shown with the timing light) so I don't think it's ignition. Also I've swapped out all the ignition components one at a time without affect (more wishful thinking).
But maybe those jets Ken is talking about? No ACV on this one but maybe it's something else screwing up the fuel flow?
I'll do the compression tomorrow with Crit's modified unit (no offense Boyee, but your paper towel compression tester is too ghetto even for me).
Who knows, maybe the White One isn't dead after all?
