The End All, Be All FC3S Electric Fan?
Old Apr 2, 2010 | 01:37 AM
arghx's Avatar
rotorhead
looks like it would fit better (with less work involved) than the Pontiac 6000 fan that myself and Aaron Cake use.
Old Apr 2, 2010 | 02:15 AM
xeccentric's Avatar
Non-op
I like. This is going on my to-do list.
Old Apr 2, 2010 | 11:45 AM
barnett87rx7's Avatar
lite rotary = easy push
LOL this is so funny cuz last week I measured the efan on my merc villager that is sitting in my driveway waiting to go to the wrecker and had the same idea
Old Apr 3, 2010 | 12:40 AM
BDC's Avatar
BDC
BDC Motorsports
Heh heh, good deal Barnett.
B
Old Apr 3, 2010 | 10:55 PM
xeccentric's Avatar
Non-op
Sorry if this is a double post. Dont know if the first reply went through. But I went to the local junkyard today and picked one up. Every villager/quest between 93-98 so far has the same fan.
As for wiring it in, i haven't done it yet. Brian I might have missed it, but did you splice it into anything specific?
Old Apr 4, 2010 | 12:34 AM
BDC's Avatar
BDC
BDC Motorsports
Nah. For a regular non standalone car, just grab yourself a relay and switch it using the switched +12vdc power hanging off the green plug near the driver's side head light. Fuse the battery power to 25-30A. Use 12awg wiring and wire the power portion off the relay to the BLUE/RED lead to the fan. That's high speed.
B
Old Apr 4, 2010 | 01:59 AM
xeccentric's Avatar
Non-op
Oh and also, were you running a stock alt or an fd upgrade?
Old Apr 4, 2010 | 06:46 PM
BDC's Avatar
BDC
BDC Motorsports
On the 'vert? Stock S4 alternator. That's another reason why I raised the idle up a bit.
B
Old Apr 4, 2010 | 09:02 PM
xeccentric's Avatar
Non-op
Awesome. My s5 alt shouldnt have a problem yesterday. I already have a lumpy *** idle because of the porting on my t2 motor
Old Apr 4, 2010 | 09:20 PM
BDC's Avatar
BDC
BDC Motorsports
Yep it oughta do ok. May want to consider bumping the idle up a hair to compensate for the current draw of the fan if you run it on switched ignition +12ve constantly.
Anybody else try the fan out yet?
B
Old Apr 4, 2010 | 09:36 PM
20Bforme's Avatar
three spinning triangles
i may have to try this...
subscribed.
Old Apr 4, 2010 | 09:41 PM
need RX7's Avatar
Listen to King Diamond.
I'll likely be heading out to my favorite junkyard down in the ghetto this week, I'll be on the lookout for sure. Thanks for the tip .
Old Apr 4, 2010 | 10:44 PM
clokker's Avatar
Cake or Death?
B
What is the point of installing the efan if you're not going to exploit it's greatest advantage over stock?
Even the crude mechanical fan attempts to sync it's performance with the temperature, wiring the efan to be ignition activated ("Always ON") is a step back from that.
Why do you need/want any fan action at all before the thermostat opens?
Old Apr 4, 2010 | 10:58 PM
turboIIrotary's Avatar
can't you just get a temp switch there like 30 bucks?
Old Apr 4, 2010 | 11:16 PM
BDC's Avatar
BDC
BDC Motorsports
You're right.
B
Old Apr 5, 2010 | 02:05 AM
xeccentric's Avatar
Non-op
Im going to go ahead and assume theres a thread hidden somewhere in the deep bowels of the forums. time to do a little searching.
Old Apr 5, 2010 | 05:52 AM
clokker's Avatar
Cake or Death?
Here's one.
Yes, I'm biased.
Old Apr 5, 2010 | 08:18 AM
Rob XX 7's Avatar
FC guy
to be fair the stock fan runs all the time too
I think some do it to keep things simple
Old Apr 5, 2010 | 08:58 AM
clokker's Avatar
Cake or Death?
True, but the thermoclutch at least pretends to adapt to heat levels.
Possibly, although a thermoswitch is hardly a major addition to the already present relay wiring.
Old Apr 5, 2010 | 11:23 AM
  #45
BDC's Avatar
BDC
BDC Motorsports
Here's one.
Yes, I'm biased.
Terrific read. Very good photo documentation. I wasn't aware of that cool relay you could get. Certainly it's ideal to have the fan on under only certain conditions as (when ducting on the car is setup well) there's no reason to run it once the vehicle is moving good and quick down the road. It's meant as more of a low vehicle speed thing.
On my Turbo II, I've got my Fiero fan wired in to the Haltech and it ground-switches it on at 193*F and then shuts it off at 188*F. So, in theory, it's not coming on really when the car is going down the highway; just at lower speeds where there's not enough air moving through the front air damn and into the heat exchangers to pull heat out of the rad.
I'm going to have to eyeball your thread a bit more. I think it deserves a sticky.
B
Old Apr 5, 2010 | 11:25 AM
  #46
BDC's Avatar
BDC
BDC Motorsports
With you on that.
B
  #47
Rob XX 7's Avatar
FC guy
its not, but it can be considered another thing that could fail
Old Apr 5, 2010 | 02:47 PM
  #48
clokker's Avatar
Cake or Death?
Didn't realize you were such a Luddite, Rob.
Old Apr 5, 2010 | 02:49 PM
  #49
Rob XX 7's Avatar
FC guy
im just making conversation thats all
sometimes people like to keep things simple or they decide on a Thursday afternoon they want to have something done by Friday and have not put hours of research into a project.
there is always GOOD-BETTER-BEST isnt there?
Old Apr 5, 2010 | 09:01 PM
  #50
Pele's Avatar
Right near Malloy
It's from the Mercury Villager/Ford Quest from the late 90's.
NISSAN Quest.
