Fc Custom Dual oil cooler system
Old Nov 7, 2009 | 02:15 AM
djchiptoothsfc's Avatar
dj
Talking Fc Custom Dual oil cooler system
hi, i am about to make a custom dual oil cooler kit for my Rx7. The benefits are endless and yes im doing ducting too. Lower oil temps will give better engine performance because heat expands metal so it doesn allow bearing to have the best clearance. (correct me if im wrong) so the lower the oil temp the better the clearances and the better the engine will perform. I am not trying to pay nearly $1000 for my kit. Im am building them from scratch and when i am done i will offer them for you guys to purchase with an fittings and all hose needed for the system, exact brackets and bolts, not to mention a oil accumulator can =) My question is, Can i use tranny oil coolers for engine cooling? I was discussing this matter with a friend and he says yes because its a cooler and its supposed to cool oil, i think different. Engine coolers are made for engines. What do you guys think? Obviously a few things might change; oil pressure and oil capacity but thats not really a big deal because i am "upping" the oil pressure. check out the link to how to do it. http://www.rebuildingrotaryengines.c..._Oil_Regulator
again, lmk thanks
Old Nov 7, 2009 | 06:11 AM
Black91n/a's Avatar
Unless you're having problems with oil temperatures that are too high, confirmed with a proper gauge, then it's a waste of money. You won't find extra power or efficiency by running the oil cooler than normal, in fact you'll likely find that things get worse.
Old Nov 7, 2009 | 06:23 AM
cmanns's Avatar
Smoke moar
and do FC's have much of a problem with OIL temps when boosted even? I believe the bad oil coolers were the beehives for the FB's.
Old Nov 7, 2009 | 06:58 AM
Evil Aviator's Avatar
Rotorhead
- The stock FC oil cooler is one of the best ones on the market. Not only does it work just fine for the street, but many track cars also use it.
- Race RX-7s need higher oil pressure more so than lower temperature. Street RX-7s should not have a high pressure oil system.
- Transmission coolers will probably work, but I am not sure if you would be able to randomly piece together something that would work better than the stock cooler.
- If you are planning on a dual core system, running them in series may adversely affect the oil pressure, while running them parallel will greatly increase the amount of plumbing. Also, ducting will be difficult, and the typical problems with dual oil coolers are the blocking of air to the front brakes (which is way more critical than the oil temp) and potential damage to the coolers if the car hits a curb (which happens quite often in road racing events).
- FYI making something from "scratch" means that you will fabricate all components yourself, which in this case means that you would fabricate your own heat exchanger cores and tubing. It sounds to me like you are attempting to simply gather a bunch of aftermarket parts and sell them as a kit.
If you are just looking for something to sell, how about some affordable stock-level or upgraded halfshafts? Mazda no longer sells new halfshafts, and no aftermarket shafts are currently offered by Racing Beat or Mazdatrix. Only rebuilt shafts are available right now for about $115, and I think a lot of people would not mind paying a little more for new and/or upgraded shafts.
Other items that would probably sell well would include a UV tinted glass or carbon fiber sun roof, rebuilt or aftermarket headlight and wiper switches (new are currently $300-700 each), and a less-expensive outer window seal. If you hang around this forum for a while you will get a better idea of what we really want.
Old Nov 7, 2009 | 10:21 AM
RotaSpinna69's Avatar
My good friend has a Datsun shop and uses FC oil coolers on his race cars You won't find anything better than stock for a decent price.
Old Nov 7, 2009 | 02:46 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
Is there a oil temperature friendly pump that can be used in line with an in series system to take the strain off the oil pump?
Old Nov 7, 2009 | 06:29 PM
dj
yeah i was thinking that a dual oil cooler set up along with raising the oil pressure might add strain to oil pump... nothing last for ever. Im building my system with that in mind. Eventually i say in about 4-5 years down the road if the pump gives out leaves me stuck somewhere, i wouldn't mind because i would know i got the best possible performance out of that pump for that amount of time which is a long time if you think about it. Most rotary oil pumps last longer than the engines themselves lol. Adding a little more strain to a pump only effects the life of it. Im doing this set up for me because i want my oil system to be bullet proof. i want it so that in an event in which case i have to push my car to the limit my oil system will be there to support my needs. Im also installing a hobbs low pressure kill switch as well.
Old Nov 7, 2009 | 07:40 PM
Rotorhead
Most of the serious racers have the MFR dry sump system which uses its own front cover and pump. I have also seen some 13Bs with Peterson pumps. A cheaper trick for those running NA engines is to use the higher-flow TII pump. There are also the usual shimming and pressure regulator (80-85psi for street, 100-105psi for track only) mods which your engine probably already has if it is prepared for racing. If you have a dual oil cooler system then I think it will be OK if you just make sure the pressure is adequate before racing the engine.
http://www.who-sells-it.com/cy/mazda...6/page-29.html
http://www.petersonfluidsys.com/
I'm not sure what you are trying to accomplish, as there are 600+ horsepower RX-7s using the stock oil cooler. It sounds to me like you are spending a lot of time and money to fix a problem that does not exist. Enduance racers that need a "bullet proof" oil system use a dry sump.
Old Nov 7, 2009 | 09:07 PM
dj
yeah what he said ^^^^ lol thanks man i look forward to this custom set up. if you guys want ill keep you posted.
Old Nov 8, 2009 | 01:11 PM
wackaloo13's Avatar
are you planning on mounting the coolers off to the sides in the brake ducts? TTT already did that. He used 2 mocal coolers. I guess it does put less crap in the middle/make life easier if you are trying a vmount
Old Nov 8, 2009 | 04:18 PM
dj
yup, in front of the brake ducts. I want to try and modify the brake ducts to accommodate for the cooler. I want the brake ducts to allow more air to be pushed in. I have to see how i will do this.
Old Nov 8, 2009 | 07:56 PM
Jager's Avatar
Tear you apart
+1.
I actually stocked up on axles in the past few years.
6 TII axles total.
2 differentials.
Old Nov 8, 2009 | 09:40 PM
dj
ok yeah, you guys all have good points. Ill look into the production of Half Shafts.
Old Nov 8, 2009 | 10:38 PM
Havoc's Avatar
lol and you do realise mazdatrix already sell a kit anyway ?
http://www.mazdatrix.com/instruction...er_Kit_new.pdf
Old Nov 8, 2009 | 10:49 PM
dj
yeah but for almost $900. Not trying to say anything about mazdatrix they are one of the worlds leading rotary performance companies but my goal will be to create a similar system with an accumulator and including everything necessary for the kit at an affordable price. Before and after results, proven results, A one year Guarantee and one year Warranty on any of the products included in my kits. I mean, im working on making custom fuel rails as we speak ( money is tight) so the dual oil cooler kit can wait lol.
Old Nov 11, 2009 | 06:13 AM
RussTII's Avatar
Veteran: Air Force
****, my oil temps are the only thing forcing me to pull off the track and cool down. Ill get to 120*C in less than 10 minutes on an average day. Fresh oil and filter. 20w-50
Ive been trying to do this for a while now but i always get discourage once i starting adding up all the fittings i'll need. they're not cheap.
oh well, guess im on my own again
Old Nov 11, 2009 | 12:54 PM
wackaloo13's Avatar
The parts are not that expensive:
oil thermostat - $50
10x -12 90 degree fittings (to lazy to look up prices for straight fittings) - $20*10=$200
2 coolers - 70*2=$140
20' of -12 hose - $133
525ish as an estimate for parts. could be cheaper if you used less hose and some straight fittings. The coolers are cheap ones from frozen boost. If you go with mocals it is going to be much more expensive.
of course, this does not include ducting mounting hardware etc.
Any idea of pricing on the kit you would provide?
Old Nov 11, 2009 | 12:58 PM
RotaryEvolution's Avatar
Sharp Claws
waste
of
time
if you want more efficiency then adjust the angles of the oil cooler so it does not block airflow to the radiator(or exchange heat), nothing beats the stock FC oil cooler, not even the R1 FD duals(although they did have the right idea of moving them out of the way of the radiator but that was mainly due to space limitations).
Old Nov 11, 2009 | 12:59 PM
dj
between 500-600 depending on whether you would want the oil accumulator.
Old Nov 11, 2009 | 06:00 PM
wackaloo13's Avatar
I probably could justify doing this if i went to a vmic... otherwise the stock cooler is good enough for me.
Old Nov 29, 2009 | 03:10 PM
danegerous's Avatar
it go down in the dm
I'd be in...but I could make a kit for a little less then that. Most expensive pieces are the AN fittings and lines, coolers can be had for cheap from Summit, Baker Precision or a good friend named Jaime. There are guidelines though, for instance how many rows would be required to adequately cool the oil better then the stock cooler. If I recall, the fc rule is if you're running dual coolers they need to be 19 row. Fd guys, dual coolers are 21. This isn't concrete so don't quote me but it makes sense. If you run two small 19 row coolers the pressure drop couldn't be harmful.
I'd like to no more of the concerns with building a kit though, the only thing I can be for sure about is my oil gets plenty hot on track and and I'd like to atleast slow it down. Horse Theif Mile is alright for hot-lapping but all the other small venues I drive are pretty quick on the gas and off.
Sorry for my useless contribution to this thread, just trying to say I'm interested
I'm working on a diff cooler project as well but thats nowhere near as difficult or as fragile as an oil cooler set up.
Old Nov 29, 2009 | 03:39 PM
Rob XX 7's Avatar
FC guy
you are talking about making things in your home garage versus a legitimate company, I think they are allowed some profit for making a kit that you can install without making your own hoses, brackets, etc.
Dont any of you value your time? Put a price per hour and how long you think its going to take, then factor that into your budget.
Old Nov 29, 2009 | 05:48 PM
dj
yeah you have a valid point. i am also in the works of creating my very own legitimate company. I do not have anything against That company but were does it say you cant compete? I am experimenting with my dual cooler designs in the search of better engine performance, life and reliability. As a matter of fact, im also looking into an alternative to the OMP by instead of injecting conventional oil you inject safe and clean Two cycle so instead of premix you just refill a reservoir in the engine compartment somewhere. I will test my cars oil temp for a while and test the car through different condition to see if a dual oil cooler system is in need. A dual oil cooler system is not a necessity but it would be a good peace of mind knowing your oil system is bullet proof. Thats were i come in. I am going to offer proven results and keep everyone updated on the progress... But first i need to buy some 13B-RE engine conversion mounts =)
Old Nov 29, 2009 | 06:12 PM
Simpsons did it.
Old Nov 29, 2009 | 07:21 PM
Rob XX 7's Avatar
FC guy
im not saying anything against competition, im saying just because someone can assemble parts for $550 does not mean a shop is out of line for charging $900 for a complete system ready to bolt on.
There is a reason why some companies stay in business for a very long time, you have to be able to charge a fair price and be able to turn a profit to be able to stay in business.
the OMP is a good idea but it must be able to work off throttle so that it does not always dump the same amount in all the time, or have a inexpensive standalone electronic control like that one company has in australia
