My 1st 13b Issue..
Old Jul 21, 2009 | 04:34 PM
rotary_bünta's Avatar
Rotary Retard
Exclamation My 1st 13b Issue..
Ok. lil back story.. i bought the FC from zerox7. loving the car runs great..
this morning i woke up to go to work, and before i head off i always warm up the beast and pop the hood to check oil and listen for anything out of the ordinary.
everything was fine and dandy until i noticed this.. ..
Zerox7 you said you fixed this!!!! LOL
what is? why is it leaking? and how the F*ck to i fix it. i know it flows coolant to the engine soo i am assuming it can be a potential big problem
Old Jul 21, 2009 | 05:23 PM
jake1191's Avatar
Pop Pop BANG FIRE!
I used to have the same problem. Depending on your fabrication skills or how much you want to spend. You can either make a block off plate(i did this) or you can spend around $65 on the part to replace it.
Old Jul 21, 2009 | 05:25 PM
13B Etc's Avatar
Das ist thermostat housing with an attempted quick-fix that is now leaking. If I remember correctly, there's an o-ring between the cap housing (usually plastic, top part) and the thermostat housing (aluminum, bottom). However, those two bolts love to break off, so be careful and use common sense. I see some coolant above the seal, meaning the cap could be leaking as well, but I'm unable to see if that's still the original cap, or what kind it is. Pop it off first and ensure that it's not the problem here, otherwise replace the o-ring underneath the cap's housing.
Old Jul 21, 2009 | 05:29 PM
jake1191's Avatar
Pop Pop BANG FIRE!
It could be the o-ring but is likely that seeing someone took the fitting for the cap off that the fitting is cracked like mine was. Either way you will need an o-ring.
Old Jul 21, 2009 | 05:34 PM
MaczPayne's Avatar
Mac Attack
Looks like RTV was used in place of the O-ring.
Old Jul 21, 2009 | 05:42 PM
RotaryRocket88's Avatar
Top Down, Boost Up
+1.
There shouldn't be any RTV on there. It gets an o-ring underneath. You can order it through Mazdatrix or a dealership.
Old Jul 21, 2009 | 05:46 PM
Rotary Retard
ok. so it sounds like a simple fix then? and what the hell is RTV?
Old Jul 21, 2009 | 05:49 PM
Top Down, Boost Up
Room-Temperature-Vulcanizing (RTV) Silicone.
Old Jul 21, 2009 | 05:58 PM
Rotary Retard
so im basically... taking them 2 bolts off. popping in o-ring.. and putting it back on? should i use silicone too?
Old Jul 21, 2009 | 06:04 PM
13B Etc's Avatar
The o-ring is Mazda part no. N326-15-174, $1.87 through mazdamotorsports.com. Or just find one that fits.
Old Jul 21, 2009 | 06:18 PM
Battle Cat's Avatar
Space cadet
haha i did it ghetto. it worked fine for a long time,(no perminant fix lol) the oring was going bad, it would drip 1 drop like every week.
just go to mazdatrix and buy the O-RING.
and its not a big deal. just 2 size 10 bolt screws, get the oring, and thats it.
i cant go there my self because of issues between me and some of the workers at mazdatrix.
Old Jul 21, 2009 | 06:21 PM
HAILERS2's Avatar
Old Jul 21, 2009 | 07:00 PM
Renton's Avatar
Originally Posted by HAILERS2
Actually he needs he one without the overflow hose.
When I bought mine i forgot the o-ring, so i just cut a gasket out of gasket paper and its been fine since (I checked to make sure it wasn't tearing it away from the inside, its fine)
Old Jul 21, 2009 | 07:02 PM
duo2999's Avatar
Pabs
he should get the one without the overflow tube. if the car is 87 like his signature says, that means s4's dont have the overflow tube there. its on the radiator cap thing.
arent s5's the ones with the overflow tube at the filler cap and not the radiator cap?
make sure that cap is actually sealing. i was using the wrong cap one time and i kept loosing coolant and i had no idea why. stupid me
*edit: ^^ beat me to it
Old Jul 21, 2009 | 07:08 PM
Renton's Avatar
Remove the 2 10mm bolts. Scrape whats left of the old o-ring off. Put in new o-ring. Replace/ tighten 10mm bolts.
Old Jul 21, 2009 | 07:27 PM
Top Down, Boost Up
That is an aftermarket piece; you can't use that with the stock radiator. You'd need an aftermarket radiator that has another overflow tube & cap on it.
S5s have the filler neck / radiator cap / overflow tube on the radiator, near the battery.
S4s have the cap and overflow tube on the thermostat cover, just like in the OPs pictures. There's a rubber hose that connects to the opening; It was probably taken off for the picture. However, it it is missing, a new hose needs to be run from there to the overflow tank.
Old Jul 21, 2009 | 07:52 PM
duo2999's Avatar
Pabs
i had one like the OP's picture though. It had some sort of thing for a hose but it was blocked off. i never understood why it was like that but i didnt question it. i dont know if the new one i got from the mazda dealership has something like that but i'll check.
Old Jul 22, 2009 | 01:45 AM
Renton's Avatar
It's a series 4 NA.
NA S4's do NOT have "the cap and overflow tube on the thermostat cover"
Old Jul 22, 2009 | 04:31 AM
JxT's Avatar
JxT
Uh I have a nearly bone stock S4 and it definitely has tube that goes to the overflow tank there so RotaryRocket88 isn't wrong.
Old Jul 22, 2009 | 09:16 AM
13B Etc's Avatar
Maybe somebody else had this problem and replaced the cap with the one you now have. I've never seen an S4 with the overflow tube on the thermostat housing. Did you get it fixed up, Bunta?
Old Jul 22, 2009 | 10:40 AM
JxT's Avatar
JxT
Unless the old white lady was secretly drifting the night away tuning the **** out of my car, then no.
<a href="http://smg.photobucket.com/albums/v355/xIJTIx/?action=view&current=rad.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v355/xIJTIx/rad.jpg" border="0" alt="rad"></a>
Old Jul 22, 2009 | 01:29 PM
funkjaw's Avatar
My NA S4 looked exactly like JxT's. When I put the koyo radiator in I had to get rid of the over flow line coming from the thermostat housing, so I went next door to rotorsport (rotory shop in Santa Clara I work next to) and they had one laying around for me to put on.
Old Jul 23, 2009 | 09:35 AM
DREYKO's Avatar
I "lost" my emissions....
just go on mazdatrix and get the aluminum replacement its like 30 bucks and comes with the cap and o ring, and it'll never crack either.
Old Jul 23, 2009 | 10:58 AM
Top Down, Boost Up
It's a series 4 NA.
Really? Then why have all four of my S4 engines had the overflow nipple on the thermostat cover? I guess a bunch of people from all over the world got together and conspired to change them, huh?
Clearly there were two different forms, though before this thread I'd never seen an S4 WITHOUT the overflow nipple on the thermostat cover. The only explanation I can come up with is that different factories in Japan used different radiators/overflow nipple setups. Check your VIN for where your car was made, and there will probably be a pattern. All I know is, the OP had better have an overflow hose connected underneath a radiator cap SOMEWHERE; be it on a stock radiator or an aftermarket one.
Old Jul 24, 2009 | 10:32 AM
Rotary Retard
not at all. i got it as is from Zerox7, i mean i do have an over flow tube to the over dohiky near my radiator cap. does that count?
