Underheating problems
Old Aug 10, 2002 | 08:01 PM
Unhappy Underheating problems
Hey all,
I've got a problem with my S4... the engine is UNDERheating. Yes, that's right, it's not getting up to temperature (sorta wierd for a rotary!). Anyhow, any ideas on how I could fix this would be greatly appreciated. Info on the car is as follows:
S4 GXL
S4 / S5 hybrid engine: S5 13BT ext ported, with S4 N/A manifolding, S4 water pump, S4 omp etc.
I have already replaced the thermostat (with a proper Mazda one) so that mustn't be the problem.
I'm out've ideas... so any help would be great.
- Tim
Old Aug 10, 2002 | 08:04 PM
SonicRaT's Avatar
Super Raterhater
Do you have an electric fan? Also, is your clutch fan locked up?
Old Aug 10, 2002 | 08:54 PM
deadRX7Conv's Avatar
Opinions are like........
How does one diagnose underheating?
Are you trusting your gauge or do you have an aftermarket one?
Old Aug 10, 2002 | 09:08 PM
dre_2ooo's Avatar
NEVER TRUST THE STOCK GUAGE.
'nuff said. get an aftermarket one. Even a cheap $40 autometer will do the job .
Old Aug 10, 2002 | 09:25 PM
I checked it a little while ago with a thermocouple setup, its around the 70 degree mark.
Basically, other symptoms are that the car remains in the enrich state (lots of carbon buildup around exhaust, EXCESSIVE fuel consumption, high idle).
As for the clutch fan, I think it may be that. Although the fan turns by hand when the car is cold, with the engine on, it blows like all hell - I have a feeling it may be blowing too hard. The only thing is, I don't want to go spending AUD$200+ to put some electric fans in, if it won't fix the problem. Is there any thing else that could be the cause?
Thanks,
- Tim
Old Aug 10, 2002 | 11:36 PM
Ryde _Or_Die's Avatar
Do you have a thermostat?
Old Aug 10, 2002 | 11:44 PM
Scott 89t2's Avatar
SOLD THE RX-7!
remove the fan and see if it goes up
Old Aug 11, 2002 | 12:22 AM
Amur_'s Avatar
Refined Valley Dude
And get a fan from a wreckers. Why spend that much $ when there are a bazillion perfectly good fans waiting out there in recycling yards for far less?
Don't know if you guys had Fieros down there, but here's a good write-up about its e-fan...
https://www.rx7club.com/forum/showth...ight=fiero+fan
Old Aug 11, 2002 | 01:55 AM
Scott 89t2's Avatar
SOLD THE RX-7!
Thanks,
- Tim
where did you check it? you are talking 70F ?? my car is that temp after sitting all day, let alone after starting / running.
Old Aug 11, 2002 | 02:16 AM
Rotary-Revolution's Avatar
I wish I had your problem!(hot, hot , hot!) My car seeds a aftermarket temp gauge bad. What brand would you guys recomend?
Old Aug 11, 2002 | 09:27 PM
Amur_'s Avatar
Refined Valley Dude
Here's a place to browse around. Their gauges are really expensive. I picked mine up from a parts store for $20 Cdn plus tax. I did order my gauge pod from these guys, though.
http://66.216.67.51/subcat.asp?0=212
WyomingTII
12
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
