Had my FD corner weighed. Advise, Comments, Suggestions?
Old Jun 3, 2005 | 03:20 PM
John Magnuson's Avatar
Had some work done at a friend's race shop and went ahead and put the FD on the scales. Here are the results with a 180lb driver in the car:
Left Front - 792 lbs
Right Front - 697 lbs
Left Rear - 732 lbs
Right Rear - 712 lbs
Or for those who like graphics:
792 | 697
732 | 712
So obviously it's too heavy on the front left. I have Advance Design adjustable coilovers so I can tweak the ride height. I could raise the left rear a little bit. However the owner of the shop seemed to think that this might just mess things up since my sway bars don't have adjustable endlinks. Also my rear weights are pretty good so why mess them up.
Any advice?
Another interesting aside is that my car, a 1993 touring model with nothing removed, came in at 2753lbs once you subtract the driver. All the information I have read said that the touring model should weigh a little more than 100lb more than that. The only things I have done that reduce weight are a complete aftermarket exhaust (downpipe, HF cat, RB catback), removed the spare tire, relocated smaller battery & the AD shock are much lighter than the stock shocks. Also the car had only a half tank of gas. So do you think the half tank of gas and lighter exhaust accounts for this weight? The shop insists that their scales are state of the art and very accurate.
Thanks,
John
Old Jun 3, 2005 | 04:36 PM
RotaryAXer's Avatar
Well it isn't too bad actually.
The cross weight is within 1.3% of an ideal 50%. That is pretty good.
(LF+RR)/Total
A lot of people will focus on getting cross weight as close to 50% as possible. This is a good compromise on a typical street car. It will give a pretty good consistent way to get transient weight transfers to be close when turning either direction.
Other than that I would say that your 100 lbs could very easily be accounted for by the exhuast, wheels and battery.
Old Jun 3, 2005 | 05:29 PM
scotty305's Avatar
~17 MPG
If you've got something else to use as a daily driver, you might look into removing your power steering & AC.
-s-
Old Jun 3, 2005 | 05:35 PM
-s-
I do have other cars. I usually drive a Miata on the street although I still take the FD out at least once a week if not more. I have thought about removing the AC but I have decided not to cause once in a while I'm REALLY glad I have it. You're right that removing the AC and PS would reduce weight at the front left corner though.
Old Jun 3, 2005 | 10:28 PM
alberto_mg's Avatar
what height are you set to on each corner? i don't have much experiencing corner weighting other than my Rotax, but i'd say lift the driver's side front just slightly.
Old Jun 4, 2005 | 01:31 PM
JJ01769's Avatar
Lovin The Spinnin Doritos
I got rid of the ac in my FC which is my daily. It still gets some "cool" air through the vents but its basically just blowing hot air onto me, but its not too bad.
Old Jun 6, 2005 | 07:02 AM
Re-Speed.com's Avatar
I does look OK....Could be closer. I would first get some adjustable sway bar end links. I think you will find you would be chasing your *** if you try to adjust the corner weights with the sway bars in a bind.
If you do that.....Then take some off the left front. I will move the weight to the right rear mostly but some will go to the other corners including your right front - which needs it. Your rears will get all out of whack before they get better.
-billy
Old Jun 6, 2005 | 01:00 PM
Thanks for the advise everyone! I suppose the next step will be adjustable endlinks and then messing with the ride height a bit. Did a track weekend with the Porsche Club of American this weekend at Buttonwillow. Great time! Played around with the rebound on the shocks a bit and found a setting that I like. Car ran very well and was competitive.
-John
Old Jun 6, 2005 | 01:22 PM
adam c's Avatar
Cheap Bastard
I would try raising the right front a little bit. That should take some of the weight off the left front, without messing up the rear very much. Don't move it very much
Old Jun 6, 2005 | 01:23 PM
turbojeff's Avatar
Do it right, do it once
2753lbs is pretty light for a Touring but I think it could actually be accurate.
My R1 weighed 2796lbs on SCCA scales. Full tank of gas and I had the spare in too.
1/2 tank gas = 50lbs or so.
Spare = 23lbs IIRC
Jack and tools = 5lbs?
I had a 51R battery, DP, CB to lighten the car up. 51R battery isn't the smallest you can get so you might be saving another 5-15lbs there.
Your same setup on my car would have made my R1 75-95lbs lighter or 2720-2700lbs.
I also added cruise, factory CD player and a JDM rear seat. I think those things may have added 10-15lbs.
A stock 93 Touring probably weighs 2850lbs or so. I don't think your weight is out of the ball park.
IIRC the sunroof assembly weighs about 30lbs. Do you still have the Bose?
Old Jun 7, 2005 | 06:27 PM
Yes, still have the bose. The only thing I have removed is the spare since it doesn't fit over my larger brakes anyway. Still have the Jack and Tools. I have an aftermarket steering wheel too and that I know weighs at least 3 or 4 pounds less than the stock airbag/steering wheel.
Old Jun 7, 2005 | 06:41 PM
gnx7's Avatar
Just for reference for the LS1/FD:
I had the car alignmened and recorner weighted to race specs running 18x10.5" CCW's and 285/30/18 Michelin Pilot Sport Cup tires with a full tank of gas.
2800lbs total without driver (no spare/jack/rear carpet/bins/divider)
.4993% front l690 r708
.5007% rear l712 r690
With driver in place it was within 1lb difference on the cross weights.
no a/c or p/s, touring model without Bose system, no spare, rear carpet or jack, Odessey mini battery (14lbs). Heavy 60lb dual 3" exhaust with stock rear hatch/glass and no other weight saving tricks.
Your car without a/c or p/s should be around 2700lbs which is great. Any further weight reduction and the car becomes a noisy and hot race car.
Old Sep 6, 2006 | 01:10 PM
scotty305's Avatar
~17 MPG
I know this is an old thread, but I'd rather add my info to this thread than create a new one. I weighed my car yesterday, and was very pleased with the results:
Empty: 2691 lbs (without driver or spare tire).
LF: 721, RF: 665 (52% front)
LR: 640, RR: 665 (48% rear)
Loaded: 2861 lbs (with 143lb driver and 27lbs of spare tire & jack).
LF: 767, RF: 672 (50% front)
LR: 709, RR: 713 (50% rear)
Touring: 3004 lbs (with 143lb driver, 143lb passenger, and 27lbs of spare tire & jack).
LF: 772, RF: 720 (50% front)
LR: 742, RR: 768 (50% rear)
Here are the mods that got me there:
Chassis:
1994 Base model, no sunroof, single oil cooler, stock stereo/cassette player and speakers (not the Bose system). The fuel tank was about 40% full, just below half a tank.
Suspension & Wheels:
Avon 245/45R16 tires. Racing Beat front swaybar, Mazdaspeed sway bar mounts, Tripint endlinks. Stock shocks, springs, wheels and rear swaybar.
Engine Bay:
Odyssey PC680 battery, Megan Racing downpipe (Jet-Hot coated). Removed Cruise Control. Everything else is stock including radiator, air pump, AC & power steering, exhaust.
Interior: all stock. Base model has cloth not leather. Autometer boost gauge might weigh 0.5 lbs. I haven't gotten around to removing the cruise control computer, but I doubt it weighs more than a pound.
For comparison, my friend's '86 Mustang LX weighed in around 3100lbs (about a 60/40 balance), and the corner scales showed my weight as being within 3 lbs of what my bathroom scale says so I trust their accuracy.
Someday I might shoot for 2600 lbs, I hope I can get there by removing the AC, PS and air pump, and installing lightweight seats.
-s-
eplusz
General Rotary Tech Support
15
Oct 7, 2015 04:04 PM
Zinraf
Oct 1, 2015 01:09 PM
RuffRx7
Oct 1, 2015 03:08 AM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
