Remove rats nest and keep Charcoal Canister?
Old Feb 22, 2006 | 04:28 PM
Pinfield357's Avatar
can i remove the rats nest and keep the Charcoal Canister? I know that there is no way of passing emmisions with the rats nest removed. But i would rather not smell raw fuel while driving around.
thanks
Old Feb 22, 2006 | 04:39 PM
I think im going to go this route
Old Feb 22, 2006 | 04:59 PM
elnots's Avatar
I can't stop boosting!!
Whats the downside of doing that besides failed emissions?
Old Feb 22, 2006 | 05:28 PM
putting in the work to do it if you really consider that downside
Old Feb 22, 2006 | 05:30 PM
Found this great description of the PCV system in the archive anyone see any bad side to this?
"PCV SYSTEM - now we're getting complicated . This is the Positive Crankcase Ventilation System, which is there because the oiling system generates pressure which needs to be bled off - it can't be a sealed system. Stock, the system is fed back into the intake, and some residual oil is pulled into the intake, dirtying intercoolers and throttle bodies . On the TurboII, the nipples to be concerned with are just below the oil fill cap, and where the oil fill neck meets the block. The NA's only have the one where the fill neck meets the block (I think). This HAS to be vented - if you cap it up, you will pressurize the crankcase, which can lead to smoking and all kinds of weird problems. Venting it to atmosphere is the easiest solution, but will over time make a mess, as excess oil comes out of the nipple. The right way is to use a catch can that has a filter on it to catch the excess blow-by. Jaz makes a tiny catchcan that works great - Jeg's carries it."
Old Feb 22, 2006 | 05:36 PM
bigdv519's Avatar
IFO Forced Induction Slo
So in one hour, you answered your own question...hmmmmmm.
Edit: At least you posted the description and the diagram.
Old Feb 22, 2006 | 08:42 PM
ya i searched and searched before posting then after i poseted i found what i was looking for
figures
Old Feb 22, 2006 | 08:54 PM
88rxn/a's Avatar
tom port.. AKA streetport
emissions??? its PA man!!!! visual only !!!! i just go to old men that say.... rotary huh*scrathes head*... ok so its how many cylinders........ i still need the "catch can" for my oil PCV system... mines blowing oil like moby dick right now....
Old Feb 22, 2006 | 08:55 PM
88rxn/a's Avatar
i thought about uising the fish tank rock filter thing but reall dont want the smell of gas either...
Old Feb 22, 2006 | 09:56 PM
DREYKO's Avatar
I "lost" my emissions....
i dont see much piont to taking it out. if its such an eyesore relocate it farther down. it weighs like 1lb. i can sacrifice that dso my car doesnt smell like ***
Old Feb 23, 2006 | 04:42 AM
NZConvertible's Avatar
I'm a boost creep...
Originally Posted by Pinfield357
...i would rather not smell raw fuel while driving around.
I removed the charcoal cannister and ran a vac line from the fuel tank vent line (the one that used to feed the charcoal cannister) under the car and zip-tied it to the fue lines. I haven't smelt fuel from this once.
Old Feb 23, 2006 | 09:23 AM
Aaron Cake's Avatar
Engine, Not Motor
I still have my charcoal canister and purge valve...
It's easy to do...The big line from the canister connects to the nipple on the middle iron. The other nipple connects to the big nipple on the purge valve. The small nipple on the bottom of the valve connects to the throttle body BEFORE the throttle plates and the nipple on top to a vacuum source.
Old Feb 23, 2006 | 08:40 PM
not in allegheny county they follow CA laws and it SUCKS but i can find ways around it wow ludlow ill be up there in a couple of days
thanks arron ill have to try that
Old Feb 23, 2006 | 09:55 PM
88rxn/a's Avatar
come on up !!! 3 1/2 hour drive and youll drive home with a inspetcion sticker !!
Steelwheelz
6
Sep 15, 2015 03:22 PM
