Ignition Idea...
Old Oct 3, 2005 | 11:46 PM
smnc's Avatar
EliteHardcoreCannuckSquad
Ignition Idea...
Firstly, a little backround...
Well, as you may know, I (somewhat) recently managed to destroy my car, and am in the planning stages of a new car/build-up.
My car was (and will be) a GSL-SE.
It will have a ported out 13B 6-port, and I'm going to be running a Wolf3D for engine management.
Custom exhaust, (see: https://www.rx7club.com/rotary-car-performance-77/pre-silencers-466741/), CAI
The longer term plans for the car call for a supecharger setup.
Now, the next thing on my list is ignition, and I've had a few ideas.
On my old car I had orignally tried an MSD setup, (with Accell Superstock coils), but was less than impressed. I also tried the 2GDFIS (no transistor trick) and felt it worked at leas as well as the MSD.
This time I want to do somthing a little different.
I've been thinking about a Coil-On-Plug setup...
Basically, I figure on using the Wolf to trigger an ignition amplifier... Say an MSD or Jacobs, which would power the coils.
For starters, I'm planning on grabbing some coils from a junkyard, but long term, I've found two aftermarket coils...
http://www.visteon.com/products/auto...lug_spec.shtml
http://www.splitfire.com/disystem_mazda.htm
Now, why do this...?
1.) Cleans up the engine bay
2.) Eliminates the power loss and other problems of plug wires
3.) I like to be different...
Problems
1.) Kinda limits coil options right now
Old Oct 3, 2005 | 11:54 PM
Rx Seven's Avatar
Can You Wankel?
Sounds interesting can't wait to see how it turns out
Old Oct 7, 2005 | 12:54 PM
smnc's Avatar
Thanks!
Anybody else with any other thoughts... ?
Old Oct 7, 2005 | 01:09 PM
misterstyx69's Avatar
Retired Moderator, RIP
will it work?
looked at the split fire ..noticed it's for a miata 1600cc. just an observation..i'm thinkin crane hi-6 myself..that split fire looks interesting though ..if you slip it on.. pm or post ..i'd like to hear the outcome..
Old Oct 7, 2005 | 01:38 PM
smnc's Avatar
Well, for starters I'm going to see if I can grab some stock ford or gm coils next time I'm in the junkyard.
Depending on how things go, I'll upgrade to the splitfire setup later... They have Miata kits for 1.6 and 1.8L... (they also have a Nissan 2.0L kit)
WANKfactor
6
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
General Rotary Tech Support
Sep 24, 2015 09:58 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
