Efan Kits?
Old Oct 18, 2004 | 12:20 AM
BlackGopher's Avatar
Continuum Transfunctioner
Question Efan Kits?
I'm getting a new radiator and I decided that It would probly be a good idea to get an Electric fan while im at it. I've looked on all the usual websites (Mazdatrix, rx7. corksport, etc.) not including ebay and I can't find any kits for an Electric fan, if anyone knows a good site to find one It would help.
Also If someone knows where I can find a step by step for installation I could use that info also.
87 N/A: No mods as of yet but hope to change that very soon
Old Oct 18, 2004 | 12:24 AM
torean's Avatar
vac leak
2 ways to go about it....
easy and simple:
flex a lite black magic for 199 with built in thermo switch and fan shroud
www.summitracing.com
or
permacool 16 for 99 then 20 for thermo switch, 20 for relays and connectors then fabbing up a shroud for the fan...
also from www.summitracing.com
Old Oct 18, 2004 | 12:31 AM
Cool thanks Torean. But what fan diameter will fit? just wanna make sure I dont get one thats too big. So far im thinking 16' will be good.
satoacs's Avatar
lol id add my .02 cents, but im confused about some of these words
can you clearify this as if i was retarded? that seems to help
Old Oct 18, 2004 | 12:35 AM
torean's Avatar
vac leak
nope, thats all u get...
Old Oct 18, 2004 | 12:36 AM
satoacs's Avatar
whats an electric fan, in case anyones feeling generous
Old Oct 18, 2004 | 12:39 AM
I dont know very much about mechanics as it is, but from what I do know, the electric fan runs off power from your battery/alternater and not from the pulley system, so it gives you some more horsepower because its not straining your engine at all. Same concept as removing your AC (except you save weight also).
Old Oct 18, 2004 | 12:42 AM
satoacs's Avatar
ok..........whats it do? wheres it go?
Old Oct 18, 2004 | 12:43 AM
torean's Avatar
vac leak
noo....i did it cause 2 of my fan clutches crapped out on me and i got tired of it....gives u move power ehh?.....what about the load the fan will put on the electrical system?(same system powering the injectors, spark plugs).....btw..i have the FD alt upgrade..so i wasnt worried about that...if u have the stock s4 alt....i'd think twice
Impreza2RX7's Avatar
Sheesh.. It goes right over the radiator to do the same job the clutch fan did..
Old Oct 18, 2004 | 12:44 AM
torean's Avatar
vac leak
and before u ask "where do i get a FD alt" search for silverrotor
Old Oct 18, 2004 | 12:51 AM
Will do )
Old Oct 18, 2004 | 12:53 AM
satoacs's Avatar
lol i didnt expect an answer i was playing stupid
Old Oct 18, 2004 | 01:27 AM
NZConvertible's Avatar
I'm a boost creep...
I decided that It would probly be a good idea to get an Electric fan...
Why? If your clutch fan works okay there are no gains to be had.
Old Oct 18, 2004 | 01:40 AM
Bob_The_Normal's Avatar
BTW, I was putting around online and came across this, which I thought looked like an awesome cheap and good e-fan... check it out, let me know if you buy one 'cause I want to know how good they are.
http://www.absoluteradiator.com/FanStore.asp
--Gary
Old Oct 18, 2004 | 01:46 AM
NZConvertible if your fan is'nt attached to the engine its giving it more power correct? Thats what I was told because its not connected to your engine, thus, not draining power. If im wrong tell me cuz i just may keep my clutch fan then. Seems like everyone wants an Efan eventually.
Old Oct 18, 2004 | 02:04 AM
torean's Avatar
vac leak
yeah.thats cause efan costs about 150-200, while new fan clutch(only ones thats not gonna break next week) will run u about 400 big ones from mazda
Old Oct 18, 2004 | 03:47 AM
You mean it's not drawing any power from the engine. This is the case of the stock fan too. When the fan is not required the thermoclutch almost completely disengages it from the engine. The fan is only fed just enough power to keep the engine temps stable when the car is travelling slowly or stopped. The actual difference in power to the wheels between a thermoclutch or electrical fan is negligible and not noticable.
If you want an electric fan you have to make sure you do it right. A stock fan with a working thermoclutch will give you zero problems, but a half-assed e-fan install will cause cooling and/or charging problems.
Old Oct 18, 2004 | 10:11 AM
ok thanks, I may save the Efan for later, at least until I can learn more about it.
SakeBomb Garage
SakeBomb Garage
9
May 11, 2020 10:04 AM
SakeBomb Garage
8
Oct 9, 2015 10:05 PM
