Post Some Pics of your FC! :D <- Pics of your car go in this thread!!
Old Feb 1, 2018 | 08:39 PM
  #12776
Relisys190's Avatar
REINCARNATED
Originally Posted by zh2oman
Thanks, the center caps pop in just like the Mazda ones, no adhesive required. I got them off ebay from a guy in England. Apparently, they are high quality re-pops, but I couldn't see a difference. Very well made and half the price of the originals. Polishing those wheels was a job I hope not to have to do again. Each one took about a day, a good winter project.
The lip looks fantastic. Exactly how it looked new i'm sure. Did you use High speed polishing wheel and rouge bar? I want to attempt this myself also my wheels could use it.
Thanks!
Old Feb 2, 2018 | 08:36 AM
  #12777
zh2oman's Avatar
I did it mostly by hand with the exception of a foam polishing cone at the final stage. I started by stripping the clear coat, it's critical that you get it all off, it may take a few applications of stripper. Once the clear is off, start wet sanding. If you have a lot of corrosion, start with 320 or 400 grit, if not you can start with 800 grit. I used 400, then 800, then 1000, then 1500, and finally 2000 grit. after that I used a green scouring pad with Mothers aluminum polish, and finally the mothers polishing cone. When sanding, use plenty of soapy water. I did not strip the paint in the webbing, after polishing the lips, I taped them off and primed the webbing before paint and clear. The aluminum "looking" lock nut in the center cap is not aluminum, don't put stripper on it! Learn from my mistakes. Hope this helps. I used aluminum primer and Dupli color wheel paint for the centers.
Old Feb 8, 2018 | 04:15 PM
  #12778
Owlix_'s Avatar
Old Feb 8, 2018 | 06:27 PM
  #12779
BenRX's Avatar
‘88 GTU
Holy ****, that's clean!
Nice work, sir.
Old Feb 9, 2018 | 02:32 AM
  #12780
BOOGS!'s Avatar
Post Some Pics of your FC! :D &lt;- Pics of your car go in this thread!!-qfqrirr.png
Old Feb 9, 2018 | 08:06 AM
  #12781
milwaukeeandy's Avatar
Originally Posted by Owlix_
Saw the wheel on IG, looks so good on the car
Old Feb 9, 2018 | 08:13 AM
  #12782
First pic is my Advan's which were cracked so they're currently getting fixed. Then I got a pair of Work T7R's for the front and RPF1's (I hate RPF1's) for the rear. Just finished the winter rebuild and paint or wrap is coming ASAP. Just waiting on some color samples to come in.
(see pics below, not sure why they didn't attach in the same post)
Old Feb 9, 2018 | 08:18 AM
  #12783
Old Feb 12, 2018 | 10:53 AM
  #12784
hkp's Avatar
hkp
big turbo spoolin
Wheel Specs and tire size please?
Old Feb 12, 2018 | 10:54 AM
  #12785
hkp's Avatar
hkp
big turbo spoolin
Originally Posted by BOOGS!
wheel specs and tire size please?
Old Feb 12, 2018 | 01:27 PM
  #12786
Relisys190's Avatar
REINCARNATED
Had the 90' GTU out and about this weekend. After about 12 hours of work on all four wheels I am about 90% satisfied with the BBS wheel restoration. The aircraft stripper chemical is no joke!!! It will quickly remove the clearcoat (which had failed in my case) on the wheels. Don't let it touch anything else because it will remove paint from anything.
-M
Keep it clean!
Needs new drivers floor mat. Nearly perfect interior.
Before wheel restoration
After removing failed clearcoat and polishing
Old Feb 15, 2018 | 07:56 PM
  #12787
Owlix_'s Avatar
Old Feb 17, 2018 | 03:51 AM
  #12788
zh2oman's Avatar
-M
Keep it clean!
Nicely done, hope my instructions were easy to follow. Looks great!
Old Feb 18, 2018 | 09:07 PM
  #12789
Relisys190's Avatar
REINCARNATED
It was quite a bit of work, and i'm nearly 100% happy with the result. Could use another round of stripping / wet sanding / polishing, but they are much better for sure. Thanks for the tips.
=M
Old Feb 19, 2018 | 08:22 PM
  #12790
stevenaffonso's Avatar
finally got new wheels and tires.
one of the last steps in a journey.
after years of rebuilding what was already a really nice 1987 GXL; I finally pulled the trigger and decided upon new wheels and tires. so happy.
Old Feb 20, 2018 | 04:21 PM
  #12791
Akomix's Avatar
Here are some from the other day.
Old Feb 20, 2018 | 07:57 PM
  #12792
BenRX's Avatar
‘88 GTU
Did I see this in Oakland today?
Nice work, that's well done.
Old Feb 23, 2018 | 08:12 PM
  #12793
Relisys190's Avatar
REINCARNATED
My son approves!
Old Feb 26, 2018 | 07:59 AM
  #12794
Relisys190's Avatar
REINCARNATED
90' GTU all cleaned up.
Old Feb 26, 2018 | 08:07 PM
  #12795
Relisys190's Avatar
REINCARNATED
Will those hood pistons hold up a steel hood? Doesn't have to lift, just hold. Car looks great!
Old Mar 12, 2018 | 03:58 PM
  #12796
Akomix's Avatar
That's a good question. I purchased through Rotary Extreme. I believe he offers a different damper for steel hoods.
Old Mar 18, 2018 | 08:56 AM
  #12797
Relisys190's Avatar
REINCARNATED
Out and about for a cruise.
Old Mar 18, 2018 | 11:20 AM
  #12798
Red95FD's Avatar
red89fc
1988 Turbo II Infini wheels and tinted LED S5 tails
Sold my GSL-se and bought this beauty with 60K miles.
Attached Thumbnails Post Some Pics of your FC! :D &lt;- Pics of your car go in this thread!!-rx7.jpg
Old Mar 18, 2018 | 02:27 PM
  #12799
JAGreen's Avatar
Tenured Member: 5 Years
Old Mar 18, 2018 | 02:28 PM
  #12800
Relisys190's Avatar
REINCARNATED
Wow wow wow . I want those wheels. Beautiful find!
