Matt's NA 20B PP build
Old May 27, 2017 | 01:02 PM
highnitro12187's Avatar
Spankin' the Wank
Hello All,
I have recently purchased (for a pretty good deal) a Racing Beat built P-Port 20B. I'm pretty sure I'll be putting in an Rx-8 but I am going to get it running on the ground before I buy the chassis I'll be putting it into to. Right now my plan is design and build everything myself for the fun of doing it. This is will be a long project, but I should make slow constant progress in the design and testing of parts. I plan to build a test stand for the engine soon so that I can start assembling parts for it.
Current Engine Specs:
Racing Beat peripheral port housings
Lightweight FD rotors
Ceramic apex seals
Racing beat water jacket mod
Balanced rotating assembly
Parts Plan:
MFR drysump
Adaptronic M6000 ECU
Custom Slide throttle
*potential* Variable length Air horns
5.5" flywheel & clutch
EWP setup
Should be FUN!
Pics:
Old May 27, 2017 | 05:09 PM
hsmidy's Avatar
Great to see another build underway. I take it you got this direct from Racing Beat?
I'm suprised to see that they PP'ed a long crank 20b, seems almost a wasy of a thick center plate. Also I see you have an fd Front cover on it. I take it you intend on running the fd Reluctor and crank sensors?
You might want to confirm that the crank pulley hub is an FD one, I cant see the locking pin on the front which makes me think it may be a 20b one.
This will giving you timing issues down the track if it isn't resolved.
https://www.rx7club.com/20b-forum-95...quest-1091664/
Most of what you need to know is in the above thread.
Old May 27, 2017 | 10:14 PM
Spankin' the Wank
I actually bought this engine from a guy who had it built 8 years ago, it has never ran. The engine was for sale on ebay for months and I watched the price drop as time went on. After awhile I contacted the seller and made on an off ebay deal.
I noticed right after buying it that it had the FD front cover and not an FD hub. I have already purchased an FD pulley hub/pulley and timing ring to match the rest of the setup. I do plan on buying the FFE kit, if the drysump front cover will allow for its use.
Old May 27, 2017 | 10:37 PM
Spankin' the Wank
I drew up a quick exhaust flange in Solidworks and 3D printed a sample to check fit. Part fit fine, I think I will thin it out a bit. I am debating between running 3 single flanges and 1 flange with 3 ports. Less weight and cheaper material cost with 3 single flanges. I have not really came up with any benefits of a long 3 port flange.
Also took some detailed port pictures today. Seems like RB did a great job with the port work.
Old May 28, 2017 | 08:42 PM
t-von's Avatar
Rotor Head Extreme
What up Matt? Glad to see you got your engine!
Old May 28, 2017 | 10:16 PM
Mdessouki's Avatar
I thought about sending that guy a really low offer, but resisted. How much did you get off his asking price if you don't mind me asking?
Chip has a group buy for a really nice exhaust flange. Save yourself the trouble and give him a call...
Old May 29, 2017 | 04:09 PM
Spankin' the Wank
Hey Trey, hope to see you put up a build thread soon!
I've seen the Chip flange, it is a nice piece but I want to build every part of this that I can, since it will be cheaper and a good learning experience for me. I'll be buying a CNC mill somewhat soon so that I can do all the work in house for cost of materials.
I only offered 10% less than his asking price as it was/is a great deal in general. I have receipts for over 13k just from Racing beat, not including cost of the engine in the first place.
Old May 30, 2017 | 11:14 AM
Mdessouki's Avatar
I was going to offer 66% of his asking to see if he would bite. Glad I get to see the build...
Old Jun 8, 2017 | 12:26 PM
t-von's Avatar
Rotor Head Extreme
Yea, I know an actual build thread is long over due but the project keeps morphing. Getting ready to pull the engine so I can build version 2 of my intake. Hopefully this one doesn't look like some hack job. Seeing if I can get enough done before Sevenstock this year. Gonna upgrade to the Haltech Elite as well.
Old Jun 8, 2017 | 05:45 PM
Spankin' the Wank
At least your too busy working on the car to make a thread..... I can't wait to see your new setup. I'm hoping that I can go to sevenstock this year, it won't be in my 20B powered car though.
Old Nov 19, 2017 | 08:32 PM
Spankin' the Wank
Decided to tear the engine down and see whats inside........
Old Nov 20, 2017 | 02:47 AM
USMC REPU's Avatar
Lucky guy.
Old Nov 20, 2017 | 02:48 AM
USMC REPU's Avatar
I Like it, Nice 20b.
Old Dec 13, 2017 | 07:37 PM
Spankin' the Wank
I picked up a MFR drysump setup today from a local guy. Came off of a formula mazda 13B-MSP. It is pretty much new with only break-in dyno time. I'll tear it all down in the next couple days, inspect everything and clean it up.
Old Dec 17, 2017 | 04:04 PM
Spankin' the Wank
I took apart the oil pump assembly as far as I easily could, everything looks great inside. I cleaned out all the residual oil and added some fresh assembly lube to the gears. Now it sitting on my ready to go parts shelf.
Old Dec 17, 2017 | 08:58 PM
Dude, some serious eye candy. The coolant passage work near the spark plugs made me raise my eyebrows
I like the fact that you set the parts on towels, make sure they're resting nice and comfortably
Old Dec 18, 2017 | 06:15 PM
Spankin' the Wank
I do love the coolant passage work racing beat did on these housings. I can't wait to be able to record all the temp data for this engine and "maybe" see how effective all these "little" mods are.
I'm paranoid about scratching things or parts rolling into each other, the towels prevent this. When I do a final clean on the parts I'll seal them in plastic until they get assembled, they still we be resting on towels though haha. A comfortable engine is a happy engine
Old Jan 4, 2018 | 03:28 PM
EllaMoto's Avatar
Who cnc'd those rotors?
Looks similar to the work i have seen from chip when it comes to the oil gallery's.
You have got yourself a sweet engine!
Old Jan 4, 2018 | 04:46 PM
Spankin' the Wank
According to the invoice I got with the engine it says Racing Beat machined them. Thank
I will probably be trading these rotors with a gentlemen who has a set of 3 S5 NA lightweight rotors. Still working out the details but I'd love to go high comp.
Matt
Old Jan 10, 2018 | 09:25 AM
Mdessouki's Avatar
I have a NA set (three) of rotors that were balanced by Roger Mandeville that I may part with if your deal falls through. PM me if interested.
Thanks,
Mike
Old May 17, 2018 | 09:28 PM
tomCTR's Avatar
Nice thread this, great engine!
any updates?
Old May 19, 2018 | 11:00 AM
Spankin' the Wank
any updates?
Right now I've been working on slowly doing all the mods needed to run the drysump on the engine. I've drilled and tapped the bearing oil feed holes in the front and center iron. My wife and I will be buying a house in the next few months so most updates will come after that as I've been waiting for my new garage before getting too deep on this project. I'll probably have the engine reassembled in the next month or two as I don't want to move with it in pieces (too risky).
Matt
Old May 19, 2018 | 01:10 PM
calichase's Avatar
Looking forward to seeing this running and getting your opinion on the MFR unit!
Old Jun 3, 2018 | 01:32 PM
t-von's Avatar
Rotor Head Extreme
Matt
Hey Matt seems they went all out on your engine. To further bullet proof, I would highly recommend sending your rotory housings to Chips Motorsports so he can install those PP block off plates since you already have everything apart. Eventually that epoxy will start to leak over enough heat cycles due to expansion differences of the epoxy and aluminum. That's been my biggest problem with my setup. With his plates, you won't ever have to worry about the engine drinking coolant.
Old Jun 4, 2018 | 07:43 AM
Spankin' the Wank
I have thought about sending them his way, but I honestly think the racing beat housings will hold up better since the P port sleeves are threaded in and have an Oring seal on it. The engine will probably come apart after I get it running for a high comp rotor swap, so worst case I'll do it down the road. If I start doing all of the "might as well while I'm in here" stuff I'll be another 10k in the hole too quick. haha.
Matt
