I have 20b D series block with Xcessive LIM and Xcessive rails.
Can someone provide me part number for 1050x primary that will fit my D series block and ID2000 that will fit Xcessive LIM with Xcessive rails?
Tried e-mailing xcessive but no replies yet.
I think they are 14mm but they have different cap configurations that makes selection little dicey.
I also have Bosch style FIC 900cc injectors with caps and O-rings and what not... will these fit into the ID injectors? If then, I can just buy the universal ID injectors and reuse these.
I confirmed with them and just for the record, for Xcessive primary fuel rail with updated (shortened) standoff, you need 48mm O-ring to O-ring distance 14mm O-ring diameter injector. For their older standoff mount which had clearance issues, you need 60mm o-ring to o-ring distance with 14mm o-ring diameter. or just ask them to send you the updated mount and go with 48mm body length.
For the Xcessive LIM with Xcessive secondary fuel rail, you need 60mm o-ring to o-ring distance and 14mm o-ring diameter. The o-ring diameter applies to both top and bottom of the injector in both primary and secondary.
