How far down should I tighten the knuckle onto the control arm ball joint
Old Mar 9, 2017 | 09:02 PM
FührerTüner's Avatar
Penis Healthy
How far down should i take this before tightening. Not in the FSM. Thanks in advance.
Old Mar 9, 2017 | 09:43 PM
LargeOrangeFont's Avatar
Fistful of steel
That's not in the FSM because the stock ball joint only goes on one way.
Old Mar 9, 2017 | 09:49 PM
Penis Healthy
Thanks for the reply. I guess I'm not asking the question right.
See how the steering knuckle can slide up and down the ball joint? My question is at what position on the ball joint shaft should the steering be (along z axis) when I tighten it?
Old Mar 9, 2017 | 09:56 PM
Fistful of steel
That depends entirely on where you want to set your roll center, which will also depend on how much adjustment you have for bump steer in your tie rod ends.
Set it equal on both sides and come back to it when you have the front suspension back on the car.
Old Mar 9, 2017 | 09:59 PM
Penis Healthy
Cool time to learn about stuff!
Old Mar 9, 2017 | 10:06 PM
Penis Healthy
There's not just like a stock position. I'm not tracking the car. Mostly weekend cruising and maybe some canyon roads.
Not that I don't wanna learn about suspension. But I have a tune on the 1st and I still have a lot of stuff to do. As of right now I have the front struts, control arms and sway bar installed
Old Mar 9, 2017 | 10:16 PM
put a stock ball joint on it, and measure it, and then make yours in the same place.
put some miles on it, and then move it as high as it goes (ball joint away from the bolt on the spindle), and then drive it.
that will be your minimum and your maximum.
Old Mar 9, 2017 | 10:25 PM
Penis Healthy
Ok, I'm just let both sides poke out the top about 1mm. I don't have an OEM ball joint. I'm assuming they have some sort of stop?
Old Mar 9, 2017 | 10:26 PM
there is a spot that is a smaller diameter, and the bolt fits in that. so it only goes 1 way
Old Mar 9, 2017 | 10:29 PM
Penis Healthy
Oh ****. Yep I get it now. Lolzers
It was getting dark and I was rushing. Thanks for the help gentlemen.
Fistful of steel
Honestly just buy a pair of stock ball joints and run stock tie rod ends.
You are going to have to build your own bump steer tie rod ends with that setup.
I have a similar kit in my garage, and that is why they are not on the car.
Old Mar 9, 2017 | 10:45 PM
Penis Healthy
I haven't changed any ball joints, or tie rod ends. So for all I know these could be OEM. Not sure how to tell. I took it all apart to changes all the bushings and boots.
Old Mar 9, 2017 | 10:51 PM
Fistful of steel
Is the picture posted what you have? If so that is not a stock ball joint.
If you have a stock ball joint your question is moot because the stock piece only goes together one way with a pinch bolt.
This is a stock s4 ball joint. That is not a stock tie rod end though.
Old Mar 9, 2017 | 10:58 PM
Penis Healthy
I got that pic off the interwebz as a reference. This is my setup:
Old Mar 9, 2017 | 11:15 PM
Fistful of steel
Those are stock ball joints. You have nothing to worry about. Pinch bolt interfaces with the groove in the ball joint stud.
Old Mar 10, 2017 | 05:06 AM
Penis Healthy
Awesome.
