94 Montego Blue Grand Touring Build
Old Feb 19, 2017 | 02:24 PM
kensin's Avatar
Put it in the microwave!
I tested half of them that was easy to get to and all of them turn out fine. if my twin starts to behave weird or not boosting correctly I'll then pull the UIM and test the rest and also switch out the blue silicone to black for a cleaner look. also replace the injectors and FPD.
Old Feb 21, 2017 | 03:42 PM
moderu's Avatar
Yo, that Y pipe doe. 😂👍🏻
Old Feb 22, 2017 | 01:07 AM
kensin's Avatar
thanks to a special friends ;D
Old Feb 22, 2017 | 01:15 AM
kensin's Avatar
small update:
new water neck/ pump assembly in. along with new FC thermoswitch and new thermostat
fitted the intercooler and Y pipe
fitted everything the best way possible and came across this !
no room to wiggle
i thought i might have to spend a few more dough to get a greddy elbow and a connecting pipe for it to fit good.
re-positioned the SMIC and a little bit of trimming ....
fits now ~~ yay
going to buy new black couplers so it all matches .. maybe even powercoat everything black to look natural
so its all buttoned up and began testing the twins secondary boost .
twins are working as they should but now im running into misfiring above 4500 rpm while in full boost . didn't notice before because the secondary never worked... more trouble shooting...
first things is to change the spark plugs and go from there..
Old Feb 23, 2017 | 05:21 PM
kensin's Avatar
newly acquired knightsports intake !!in very great condition ... i might just repaint this piece and with new hardware so it shines ~~
Old Feb 23, 2017 | 08:15 PM
kensin's Avatar
small update,
changed the spark plugs. they were really bad. probably old aswell. change then out to all oem 7s and 9s
boom. no more misfire and twins are working great.
primary 11psi and transition to 10~9 psi. and secondary a solid 9~10psi
a second vacuum hose job will be done in the near future along with cleaned injectors new FPD and new fuel pump
Old Feb 24, 2017 | 06:21 AM
kensin's Avatar
as of now. the plan is to get matching black couples all around, change the vacuum hose to all black and powder coat the SMIC/piping,cross over pipe and perhaps the UIM.
Old Feb 24, 2017 | 03:27 PM
Narfle's Avatar
Rx7 Wagon
Damn, bro. You get busy in that garage. Make me jealous, why don't you.
Old Mar 5, 2017 | 01:02 AM
kensin's Avatar
haha. thanks? I try to collect all the necessary parts and get portion of things done at once instead of over a period of time .
still...things pops up and need this and need that. never as smoothly as planned ;(
Old Mar 6, 2017 | 01:00 AM
theagavejazz's Avatar
For the door handle, did you replace the whole part in your picture? Or just the outside part that you pull on? My drivers side door doesn't open and I've never been able to figure out why. I've only replaced the pull part with the aluminum replacements they make.
Old Mar 6, 2017 | 02:49 AM
kensin's Avatar
if you look at the L shaped rod and hinge where theres a big fat spring , you can see that the spring assembly is very worn out and thus not making it have enough tension anymore to have leverage to pull the cable . at least that's what my case was. i just replaced the assembly with a low mileage one that i bought from the for sale section. are you able to pull the handle at all ? is it stuck shut or is it pulling freely with out opening the door ? if its stuck most likely a cracked handle plus loose springs causing it to jam some where. open it up and take a look
Old Mar 6, 2017 | 02:51 AM
kensin's Avatar
small update.
now onto to the suspension side of things.....fun.....
teaser
very very busted
superpro
Old Mar 6, 2017 | 02:53 AM
kensin's Avatar
Left,NEW Right,OLD(very old)
Old Mar 6, 2017 | 10:05 AM
Johnny Kommavongsa's Avatar
Good stuff.
Fuel filter reminds me of my first fuel filter replacement which was not fun.
Old Mar 7, 2017 | 12:39 AM
Thank you. it pulls but feels stiff, I will open up again and check it out.
Old Mar 7, 2017 | 09:41 AM
RA8225's Avatar
Banned
I dread the day I have to remove my fuel filter.
Old Mar 7, 2017 | 10:20 PM
kensin's Avatar
update ~
Ohlins recommended setting
J-auto Toe link and Trailing arms
J-auto pillow ball bushings
Old Mar 9, 2017 | 05:07 AM
kensin's Avatar
just a few things on the waiting list
power FC OLED
front speakers adapter for 6.5
turbojeff battery tray . time to start saving for a nice 51R
much needed missing map pocket Lid ;D (cant wait for this one to be installed )
Old Mar 9, 2017 | 05:14 AM
TomU's Avatar
It Just Feels Right
Were did you get the speaker adaptor?
And did you replace any other bushings? I found after 60k miles, the only good bushings I had were the trailing arms (and maybe the toe links, but I didn't check those)
Old Mar 9, 2017 | 05:51 AM
  #45
kensin's Avatar
I bought the adaptor off amazon.
here buddy
https://www.amazon.com/gp/aw/d/B016YS6OSI/ref=cm_cr_arp_mb_bdcrb_top?ie=UTF8 https://www.amazon.com/gp/aw/d/B016YS6OSI/ref=cm_cr_arp_mb_bdcrb_top?ie=UTF8
I have not replace other bushings beside the pillow *****. the rest on mine are still in decent condition
it is in the future plans replacing with new oem for the entire front along with new brake system and some new bearings and wheels. aaahhh the journey
Old Mar 15, 2017 | 02:23 AM
  #46
kensin's Avatar
no sleep for the wicked lol
back at it again
old and busted
new hotness
looks like somthing from the aliens
with ohlins front and somthing new that does NOT look like somthing from the aliens
im sure these were original .. but not anymore !!
new
Old Mar 15, 2017 | 11:45 AM
  #47
Narfle's Avatar
Rx7 Wagon
Nice work on the tie rods and dust boots. Where you source them?
Old Mar 15, 2017 | 11:57 AM
  #48
kensin's Avatar
give Juan at J-auto a call . i got it from him he will take care of all your suspension needs.
Old Mar 15, 2017 | 09:34 PM
  #49
kensin's Avatar
today i took the FD out of storage to wash it and maybe cruise a little bit
Old Mar 15, 2017 | 09:35 PM
  #50
kensin's Avatar
all buttoned up and clean
