Green Machine LS1/T56 Build
Old Feb 2, 2016 | 09:40 AM
codywelshrx7's Avatar
Rotary Powered
Quick Story:
Picked car up at the end of last summer. Had two fd's at the time. Decided to keep one and do an LS swap over the winter. Car was in pretty good shape but alot of errors were made during modifications which I am fixing as I go along.
A month after I purchased the car:
For the mount kit I have:
- newer hinson subframe kit
- samberg bumpsteer kit
- Hinson radiator setup
- Hinson torque arm will try to add KG diff brace or may end up trying to get the samberg diff mount
Ran into a couple problems so far:
- The mount kit I purchase was for a Auto trans. I purchased the proper t56 mounts needed and was able to pickup a Brand New 3.9 diff!
- Fuel and brake lines weren't in the best shape so ripped that all out
- Fuel canister had some problems
- Wiring for front lights
- T56 clutch line/bleeder
Old Feb 2, 2016 | 09:50 AM
Rotary Powered
Brake/Fuel lines taken out and replaced
Fuel canister with some butt connectors and non submersible fuel line
Picked up a low mileage LS1/T56 full hot rod swap. It is from an 02 Firebird. Took it apart to inspect it and its in great shape. Going to do some basic maintenance:
- New rear main seal
- New GM slave
- New rear main seal gasket
- Oil pan gasket
- New pilot bearing
For the Clutch setup:
- New Textralia Z grip
- New wilwood clutch master
- Chase bays clutch line and remote bleeder
- New oem slave cylinder and pilot bearing
For the Fuel set up I decided with:
- 6an fittings
- 6an nylon braided line
- New Corvette 58psi FPR/Filter I believe it is Wix part #33737
For the rear end setup I was able to pick up a brand new 3.9 diff. I was also able to pick up a low mileage 3.9 spare as well! I have installed new super pro differential bushings.
Old Feb 2, 2016 | 10:13 AM
Littleguy's Avatar
Piston Head
Looks good, I highly recommend doing a cam as long as you have the motor out.
Old Feb 9, 2016 | 02:09 PM
Rotary Powered
I was considering a cam but for now I am just going to run bolt ons with a Frost tune for now.
Ronin modified harness with fuse block and obd port in progress!
LS6 Intake manifold getting ready to be cleaned up.
Wilwood master installed with adapter plate.
Old Feb 17, 2016 | 08:43 AM
Rotary Powered
Out with the old Rotary!
I believe a rare front bumper I picked up as I havent seen one of these before. Looks like a 99 spec front bumper with a moulded autoexe lip except It is all fibreglass
Identification tag on the back if anyone can identify what company this bumper came from.
99 spec Front lip
Tri-Ax Shifter for the t56
Super pro bushing kit
Debating running these wheels and powder coating them black.
Old Feb 19, 2016 | 06:07 PM
karsty's Avatar
I wish you would have sold me this car before you decided to do the swap. Was a good deal.
Should be a fun project!
Old Feb 21, 2016 | 03:27 PM
Aaron tietje's Avatar
Great color. That front bumper looks so much better with the lip too.
Old Feb 21, 2016 | 08:39 PM
XLR8's Avatar
Great work! Looking good.
Old Feb 24, 2016 | 04:48 PM
Rotary Powered
Finally the chase bays clutch line and bleeder showed up and I was able to put everything back together and get the engine in.
Vertical limits to get it in lol
Starting to piece everything back together
Starting to mock up oil cooler. Probably will change this as I don't like the distance of the lines. May go in front of the rad. Hinson intake is taking up the space on the driver side.
Some more mock up of the oil cooler mounting
Oil Cooler setup:
Mocal 19 row
Deral thermostat
10an lines
Sandwich plate with 10an
Power Steering setup:
Heidts one turn valve
Custom 6an high pressure side lines from rack and ls1 pump
earls 991955 x2
Derale power steering cooler
Old Feb 24, 2016 | 06:03 PM
RA8225's Avatar
Banned
When do you think you will complete?
Old Feb 24, 2016 | 06:26 PM
Rotary Powered
I should be completely done by end of April. Just more of the little stuff to do now. Plus a few things I need to order or send out. (Some more fittings, send out Ecu)
Old Feb 24, 2016 | 10:28 PM
RA8225's Avatar
Banned
Right on. Hopefully you can make it out to the summer meet, whenever it happens
Old Mar 4, 2016 | 01:17 PM
ZoomZoom's Avatar
SEMI-PRO
Old Mar 4, 2016 | 06:52 PM
^Lmao
Old Mar 31, 2016 | 12:59 PM
Rotary Powered
Some more progress made on the car. Waiting for a few things to come in:
- Samberg rear diff brace
- Coupler for intake
- Earls power steering fittings and line
- MGW shifter
- Frost tuned ecu
Miata red stitched wheel wired for fd connectors and holes drilled.
PCM controlled fan relays being wired in
Exhaust system heat wrapped ready to be put on.
Almost Done!
Oil cooler, rad, power steering cooler mounted now just to make an undertray.
Old Apr 8, 2016 | 10:38 AM
Rotary Powered
Intake fitment testing
Obd port mounted behind the glove box... still easily accesible
Interior almost done. Aem gauges installed. Nardi wheel installed. Everything is coming together nicely.
Old Apr 8, 2016 | 12:22 PM
RA8225's Avatar
Banned
We need better pics!
Old Apr 8, 2016 | 07:52 PM
Moar pics of the pooch !
Old Apr 19, 2016 | 01:48 PM
Rotary Powered
Almost all completed just stock water temp gauge to be hooked up and then realign a couple of things and add fluids!
New driveshaft bolts seem to misplace mine
Some brake stuff
MGW shifter installed..... Those front bolts were a real pita
Old May 2, 2016 | 10:24 AM
Rotary Powered
Engine bay completed. Hood dampers installed. Now time to make an undertray and radiator ducting.
Diffuser mounted and exhaust sitting in place... Need to fab up the vband flanges to connect it all together. Test fitting a spoiler I had seems to be ok..... still debating on spoiler or not.
On way to alignment shop today! May have to black out that oil cooler.
Final stance before it gets aligned. <br/>Wheel specs:<br/>18x9 +40 255/35/18<br/>18x9.5 +40 265/35/18
Old May 2, 2016 | 11:20 AM
Natey's Avatar
Nice work on the swap, the Volks look great, and I like the OEM bumper better.
Haha, Once you're on the road I'll bet your neighbor in the TypeR is gonna rev his vtec at you!
Old May 10, 2016 | 09:08 AM
Rotary Powered
Update on the car:
After the tcs trailing and toe arms from Banzai were installed along with the super pro/power flex bushings the pillowballs have seen the end of their days. Awaiting replacements from J-Auto hopefully they are here today.
Side note. Had my harness modified by Ronin ran into a couple snags as the fuel pump relay pins were mixed up causing me to run around chasing grounds. It is all fixed now and running good.
Had an ecu from Frost tuning modified for my application. I was only able to go to 80mph due to the speed calculation from the ecm being incorrect. This is all resolved and a new ecu is on its way. For now the vss is disconnected.
Next to do:
Intsall J-Auto pillow *****
Install new ecu
Replace collector gasket
Replace shifter bushing
Re bleed brakes
Re bleed clutch
Improve on radiator ducting
Old May 12, 2016 | 01:27 PM
Rotary Powered
New shifter bushing and cover
Old worn pillowballs out!
New pillowballs in from J-Auto just need to install the snap rings!
Final engine bay setup for now....
Late night spoiler install using the stock hole so it can be removed easily. Taillight modification with Yellow turn rings as well came out quite nice. This is the second pair I have done now.
Old May 31, 2016 | 12:26 PM
Rotary Powered
Old Jun 27, 2016 | 10:22 AM
Rotary Powered
Picked up some R1 seats and gave them a good cleaning.
Picked up some forgestar f14's <br/>18x9.5 +42 <br/>255/35/18 Re71r front<br/>265/35/18 Re71r rear
