Racing beat full exhaust for an NA
Old Aug 15, 2014 | 05:10 PM
JoesFC's Avatar
Triangles and Cats
I was wondering a few things about this exhaust, as it has basically everything youd need in an exhaust system, but is a large investment. So here goes:
Is it too loud for street use in southern california?
Being catless, does the smell attract a lot of attention from other drivers (cops)?
Will it backfire much? Visibly?
If not the rb full exhaust, what would yall recommend?
Thanks guys!
Old Aug 15, 2014 | 05:12 PM
JoesFC's Avatar
Triangles and Cats
The car is my DAILY by the way, but things like driveability dont really concern me all that much within reason
Old Aug 15, 2014 | 06:09 PM
roTAR needz fundZ
If you have the cash, and need to pass smog, a full racing beat exhaust is by far the easiest and best way to go for exhaust on these cars
Old Aug 15, 2014 | 06:32 PM
marclong's Avatar
Rb exhaust is not too loud. However I used there presilencer in place of cat. You will need a cat to pass smog. Bonez has a cat designed for rx7s that I've heard work well. The smell without the cat is pretty evident.
Old Aug 15, 2014 | 07:09 PM
clokker's Avatar
Cake or Death?
Interesting clash of concepts there.
Old Aug 15, 2014 | 07:19 PM
JoesFC's Avatar
Triangles and Cats
Hahaha just because i drive it every day doesnt mean comfort is my main concern
Old Aug 15, 2014 | 07:20 PM
JoesFC's Avatar
Triangles and Cats
I would be running the setup complete as they sell it. Which means WITH the presilencer/header combo. So it would be catless
Old Aug 16, 2014 | 08:34 AM
LargeOrangeFont's Avatar
Fistful of steel
It will smell, not horribly if your car is running ok. It won't be too loud. Mine didn't afterfire a lot, at night you could see a bit of purple flame in the exhaust here and there when it was catless
I had an OBX header, an aftermarket main cat and the RB catback. The cat got cooked and died so I replaced the cat with a resonator, and the car was a bit quieter like that. It did smell a little.
Old Aug 16, 2014 | 08:35 AM
Fistful of steel
He's 17, I'd say that is typical.
Old Aug 16, 2014 | 09:06 AM
misterstyx69's Avatar
Retired Moderator, RIP
17 years old...lives in a place named after beer..Racing Beat exhaust...
Goddamn..this Guy has got it all..I'm Jealous!..( I got belly button lint older than him..haha!)
Old Aug 16, 2014 | 10:16 AM
JoesFC's Avatar
Triangles and Cats
Hahahaha what can i say i live a blessed life. But im grateful for what i have, unlike many in similar situations.
Old Aug 16, 2014 | 12:09 PM
Acesanugal's Avatar
Winter Rotary
I personally feel the header is a necessary piece of the puzzle as that is where the majority of the gained BHP is at. The downside, however, is noise. The factory shoebox header dampens noise significantly due to its design affecting the 'pulses' coming out of the engine.. they mingle in the box and a lot of noise is canceled out as a result. This also makes the shoebox horribly inefficient. A full RB exhaust will net you a noticeable power increase, but utilizing the header and the cutback with either a presilencer or cat in the middle of it greatly increases the drivability. Its a little hard to describe... but I feel it ultimately means youre not accelerating nearly as hard to, say, keep up with traffic at the lights.
The way I see it.. youre paying for decent quality, and the fact that the mufflers where they exit the car looks stock. That is possibly my favorite 'design feature'.. its totally different if you've got two fart cans chillin off the back of the car.. looks like you're up to no good! To top it off, the system sounds great and was engineered to be of actual use, not just make noise and widen exhaust pipe diameter...
Old Aug 16, 2014 | 12:18 PM
FCnut's Avatar
My interpretation of that ^ excellent observation albeit with a twist, if you're primarily daily driving the 7, stay with the stock manifold and just do downpipe to pre-silencer. The extra noise will get old after a while.
If you track it, or are expecting to start tracking it regularly, get the header set up.
If unsure, you can always get a header later.
Racing Beat themselves will give you that same conclusion.
Old Aug 16, 2014 | 04:34 PM
the stock manifold works exactly like you describe, there is even an SAE paper on it. as far as power goes, it does fine, the exit diameter is about right, so for a street car it works really well.
the RB header on the other hand is smaller than the port outlets and they cheat the radius on the inlet too, so this is why it doesn't show power gains.
Old Aug 16, 2014 | 09:44 PM
JoesFC's Avatar
Triangles and Cats
So bottom line, downpipe or headers?
Old Aug 16, 2014 | 09:46 PM
Acesanugal's Avatar
Winter Rotary
I am currently running the stock shoebox, and a bonez downpipe + high flow cat (gutted) and the Racing Beat catback. I personally preferred the header overall.
Old Aug 16, 2014 | 11:40 PM
I just checked out my S5 and some asshat put on 2 cats.( I am sure they are hollowed out)
Seeing it is a royal Screwup and the catback looks like a 2 year old got at it,I got a RB TII setup that has the 2.5 inch tips.It has a 3 inch y pipe flange.
So plans are to toss a 3 inch universal Cat on it and adapt it to the stock downpipe.
I just got the car into the garage today so I will know more as time permits.I'll try to update.
Old Aug 16, 2014 | 11:57 PM
FCnut's Avatar
I'd go with the down pipe. I'll bet if you asked Racing Beat that is what they would also recommend.
Old Aug 17, 2014 | 03:57 AM
Dak's Avatar
Dak
Information Regurgitator
Yes and no. Yes if you have no plans of ever touching the intake or doing any porting or going stand alone.
From RB:
"The 1986-92 13B 6-port engines, in stock form with the factory fuel injection, produces similar power gains with either our Header/Presilencer combo or our RX-7 Down Pipe/Presilencer combination. If you have no intentions of installing our Holley intake System (or any other aftermarket carb set-up), we recommend the use of the RX-7 Down Pipe/Presilencer combo since it offers a slightly quieter exhaust note, is easier to install and less costly."
I think they would reccomend the header if you are not keeping the above mentioned stock.
"If you are intending to upgrade the intake or fuel injection system, the Header/Presilencer combo offers the greatest performance potential."
Personally I would go with the header/presilencer combo. It is only $122.00 more and offers more expandability for the future. Now as j9fd3s mentioned and you can find by searching, it does have some design flaws but is better than the stock manifold or anything else currently on the market other than the Defined Autoworks header. Can't comment on the noise difference between the two as I went with the header/presilencer setup years ago.
Old Aug 17, 2014 | 01:28 PM
the RB header is made from 44mm ID tubing, and the exit of the engine is 48mm, there is enough meat to port the RB header so that there is at least a cone/taper from the engine into the header.
the RB pipe is the right size, the FC engine is too big. the racing engines have smaller outlets, so the ideal fix is a new exhaust sleeve, but that requires making one, and then rebuilding the engine so its not very practical
Old Aug 17, 2014 | 03:56 PM
Dak's Avatar
Dak
This is what I attempted to do. I may not have ported deep enough but I at least tried to knock the sharp edge off to help smooth the flow.
Old Aug 17, 2014 | 06:41 PM
Evil Aviator's Avatar
Rotorhead
The Racing Beat full exhaust is not street legal in the People's Republik of Kalifornia, nor are any of their headers. Therefore, the catback exhaust is your next best choice. The one nice thing about socialism is that it makes your choices a lot easier.
Old Aug 17, 2014 | 08:03 PM
JoesFC's Avatar
Triangles and Cats
Hahahaha legal or not doesnt concern me. Whether it smells bad enough for a poliec ociffer to notice is what worries me
Old Aug 17, 2014 | 10:28 PM
Rotorhead
That's not how it works. If your region has mandatory emissions inspections, then you will not pass and therefore can't drive the car on the street until you get it fixed. If your region does not have mandatory inspections, then you will be OK until you get into a wreck or get stopped by a police officer for whatever reason (speeding, parking, not stopping at a stop sign, loud stereo, just to be a *****, etc.). The fine is $2,500 for each illegal part, and possibly jail time. It is stupid to spend a lot of money on an exhaust system that will just get you in trouble.
Old Aug 17, 2014 | 10:48 PM
Dak's Avatar
Dak
If you get an Evel Knievel stopped behind you at a light he will notice the smell. A regular cop with the windows up and the air on, probably not.
You will need a stock setup to use to pass emissions and your inspections. After that it's a roll of the dice on whether any of the things Evil Aviator mentioned happens. Sounds like in the P.R.K the cops pay attention to that stuff. In TN. At least my neck of the woods they could care less.
