Haltech haltech E8 wiring diagram needed !
Old Aug 27, 2010 | 09:15 PM
dkwasherexd's Avatar
Garage Life
I need the haltech E8 wiring diagram, for some reason I cant find the specific E8 wiring digram, only E6 or 11..
Im stuck at the crank angle sensor, how do I wire this up? ANybody have E8 schematics ? I just need to wire up the crank sensor
Old Aug 27, 2010 | 09:27 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
My Platinum simply plugged into what was otherwise set up for my old E8 with no changes. So I would thing wiring for an E6 would plug and play for an E8.
Old Aug 27, 2010 | 09:33 PM
need RX7's Avatar
Listen to King Diamond.
This what you're looking for?
http://www2.haltech.com.au/downloads...ng_diagram.pdf
Old Aug 27, 2010 | 09:35 PM
Nismo Convert86's Avatar
400WHP or bust
If I remember correctly, the E6X is different from the E8 and E11V2, but those share the wiring diagrams.
Heres the E8 tho:
Old Aug 28, 2010 | 12:54 AM
Garage Life
i still cant figure out the wiring for the CAS. WHat color wire to what color wire, get what I mean..
Old Aug 28, 2010 | 09:19 AM
400WHP or bust
Here you go:
http://www.hitman.hm/installation.htm
Old Aug 28, 2010 | 08:44 PM
Garage Life
thats for e6, i need a digram for e8 CAS and ignition. Its hard to find a digram for e8
Old Aug 28, 2010 | 09:42 PM
bumpstart's Avatar
talking head
http://img837.imageshack.us/img837/9...8201000000.jpg
ignore the 12V,, its for hall effect and optic senders, not for mazda Vr
Vr negatives are common,, this amounts to the CAS ( whites ) being tied together into the ECU ignition input earth wiring ( blue )
for FC type CAS--
24 tooth multitooth trigger in the CAS ( red ) goes to input trigger ( yellow )
2 tooth home event trigger in the CAS ( green ) goes to HOME input ( green )
PS
here is the other diagram for others reference
http://img823.imageshack.us/img823/9...8201000001.jpg
http://img225.imageshack.us/img225/5...8201000002.jpg
Last edited by bumpstart; Aug 28, 2010 at 09:59 PM. Reason: PS extra wiring diag added
Old Aug 28, 2010 | 10:11 PM
fritts's Avatar
Mad Man
Use the Haltech Sprint RE quick start guide. Has all the information you need.
http://files.haltech.com//downloads/...%20Website.pdf
Old Aug 29, 2010 | 01:14 PM
SirCygnus's Avatar
whats going on?
the actual wiring for the cas is the same for all revisions of the haltech. the wire colors are the same on the cas even.
fastsaab
Aug 19, 2015 11:42 AM
Leeroy_25
Aug 17, 2015 12:53 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
Rx7_brad
Aug 15, 2015 09:57 AM
