stereo install
Old Jun 18, 2010 | 10:14 AM
808nismo's Avatar
stereo install
hi i need help to install an aftermarket stereo. i dont have an install kit. what wires are for the front door speakers? they run to a stock amplifier and then change color code to the speakers.
Old Jun 18, 2010 | 10:21 AM
Josh_rx7turbo_2's Avatar
What year is your car? Are you by-passing the amp? A 9 volt battery with two wires attached to the terminals is the best speaker tester money can buy.
Old Jun 18, 2010 | 10:41 AM
satch's Avatar
Taken from the FAQ
What are the wire colors for adding aftermarket radio
LTBlue/Red= 12v+
LtBlue/White= +Accessory
LtBlue/Yellow= -power ant trigger
Red/Black=+ Lumination
White=Factory Amp Turn on
Ground to the body, use the 10mm bolt behind the center console front drivers access panel. Do not use the Red/Black as ground it will damage the interior light circuit and dimmer in the car
Front Speakers (maximum of a 15 watt peak from the radio):
LtGreen/Red= Left
LtGreen/Black= Left
LtGreen= Right
LtGreen/Yellow=Right
Rear Speakers (if applicable, if you have the amplified rear speakers again the Maximum of 15 watts peak is all the stock speaker amp input can handle):
Brown= Left rear
Brown/White= Left Rear
LtBlue= Right Rear
LtBlue/Orange=Right Rear
Old Jun 18, 2010 | 02:02 PM
datz's Avatar
GNARKILL
just run new wires for each speaker, its alot easier than trying to fiqure out existing wiring. most aftermarket stereos will put out 45+watts per channel/speaker, so ditch the stock amps.
Old Jun 18, 2010 | 05:24 PM
bostonspgs's Avatar
Boston Acoustics SPG555's
if yo dont ditch the amps you are gonna have either the amps blow or the deck so just bypass them ,btw if you have bose youll need to replace all speakers as well. bose is the only company to run a mid range woofer at 2.47 ohms this creates problems with 4 ohm after market decks
Old Jun 19, 2010 | 02:43 AM
808nismo's Avatar
ok thanks. i just hooked it up to the stock wiring. i dont think theres a stock amp. i couldnt find it on either side of the dash. how big is it? i only have front door speakers for now.
Old Jun 19, 2010 | 10:13 AM
LunchboxCritter's Avatar
Disco Biscuit
The factory amps are under the 6.5" speakers in the back, and I believe there is another one beside the 4" speaker on the passenger side under the glove box.
Old Jun 19, 2010 | 12:54 PM
Beansy's Avatar
just run new speaker wire its alot easier that way and you dont run the risk of messing things up with the stock amps and DONT forget that if you have a power antenna you will have to install a relay because it is a negative trigger
Old Jun 19, 2010 | 03:41 PM
bostonspgs's Avatar
every speaker in the rx7 has its own amp(high end models , not sure about base ) as has been said run new wires
Jeff20B
73
Sep 16, 2018 07:16 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Enzo1944
Sep 6, 2015 08:57 AM
