Aquamist HFS-5 system: Official Q&A...
Old Aug 8, 2007 | 05:50 PM
  #51
Richard L's Avatar
Yes, you can connect the HFS-5 to the secondary injector.
I believe this is how the RX7's fuel injector banks work:
1) When Primary injector reaches 50% DC
2) the second injection start at 25% DC
3) At exactly the same time, the primary drops down to 25% DC
4) Both injector banks will ramp up to 100% thereafter.
If the HFS-5 is wired to read the secondary injector, it will inject from 25% to 100%. You can set the HFS-5's trip point anywhere below 25%.
Can someone chime in to confirm this?
The reason for the summer was to extend the HFS's operating range form 12%-100%. compared to 25% to 100% (reading the secondary only)
Old Aug 8, 2007 | 05:53 PM
  #52
Richard L's Avatar
Originally Posted by Marcel Burkett
Finally ! ......Hi Richard ! , I got the piece for the spray bar nozzle , thank you yet again . Can you thell me what tap was used on in hole? As for the pump , does BKA have a web site ?
It is a M3 thread.
I don't think BKA has a website. They are listed on our "supplier listing" section of our website.
Old Aug 8, 2007 | 05:56 PM
  #53
dis1's Avatar
www.silverbulletrx7.com
I thought the secondary was activated by rpm as well. For example I could be on full boost under 3K rpm and only be injecting fuel from the primary. For this reason I believe the summer is needed. I think I'd rather inject based on boost compared to only the secondarys and at that point I don't need such a nice kit as this.
Old Aug 8, 2007 | 07:53 PM
  #54
cozmo kraemer's Avatar
Darkside FD
The PFC has a reading on the commander that is IDC. Is this already summed? It doesn't jump around like the primary and secondary individual duty cycles do when you log them...
This just another of the wonderful rotary quirks. This car is such a pain in the ***.
Old Aug 9, 2007 | 05:09 PM
  #55
Richard L's Avatar
Here is a logged image of Scott's car:
Re trace (top chart): is Primary injector. Ramp up to 50% at (cyan line) and immediately to 25%.
Blue trace (middle chart): secondary injector starts at cyan line. Both start to ramp at the same rate until 119 time-line (x-scale).
Bottom chart: Showing pulse width of both injector pegged at ~6ms after cyan line.
Green trace (top chart): Aquamist prototype summer output.
Old Aug 11, 2007 | 04:52 PM
  #56
ryan1's Avatar
I'm planning on up setting the system with everything located in the spare tire well. Is this fine,or does the hsv and/or the flow sensor need to be closer to the jets?
Old Aug 15, 2007 | 12:39 PM
  #57
^ +1
Old Aug 15, 2007 | 05:42 PM
  #58
Richard L's Avatar
The HSV must be in the engine bay - can be 2-3 feet away from the jet or jets.
If you are putting the tank in the tire well, make sure your put some baffle plates or foams in the tank,.
Richard
Old Aug 15, 2007 | 07:34 PM
  #59
mrmarsh's Avatar
Richard
any chance you can pm me the breakdown on just the gauge and what else i would need to make it work on my alky control kit?
Old Sep 7, 2007 | 05:46 AM
  #60
efiniste's Avatar
Hi Richard,
I've worked out my flow rate to be 774cc per minute so I'll need to use 2 nozzles. The 1.0mm and the 0.9mm. My question is, which restrictor do I use? The 600 or the 900? I'm guessing the 900 but just wanted to check.
thanks,
Steve
Old Sep 24, 2007 | 05:00 PM
  #61
dis1's Avatar
Still waiting for the summer... Maybe you will have time for it during the off season and I can expect it for the early spring?
Old Sep 25, 2007 | 12:32 PM
  #62
Richard L's Avatar
I am hard at it at present ...
Old Sep 30, 2007 | 10:18 PM
  #63
Marcel Burkett's Avatar
Hi Richard , I sent you a pm !
Old Oct 11, 2007 | 10:57 AM
  #64
efiniste's Avatar
Any news on the summer yet Richard? I'm planning my install for over the winter and could do with getting hold of it before then.
thanks,
Steve
Old Oct 11, 2007 | 01:12 PM
  #65
Richard L's Avatar
thanks,
Steve
I am receiving the printed circuit board on Monday, will populate it and test it. Keeping my fingers cross - fire it up and hope it works.
Old Oct 11, 2007 | 03:07 PM
  #66
efiniste's Avatar
Great news!
Old Oct 11, 2007 | 04:11 PM
  #67
dis1's Avatar
Awesome!
Old Oct 13, 2007 | 07:04 AM
  #68
Richard L's Avatar
It is a good time to discuss how the summer works, if you have any questions and comments, please chime in.
The summer reads the individual duty cycle of the injectors and adds it up and drives the HSV directly.
User has to dial in the flow capacity of the injectors via two individual trim pots. Adjustment range covers between 500cc/min to 2000-cc/min.
There is a third trim pot that allows user to scale the summed duty cycle by +/- 10%. A 100% DC test button enable the user to test the system without activating the fuel injectors.
There unit will communicate with the DDS3. The supplied FIA2 will be made redundant but please keep it in a safe place so when you decided to put the system back on the market, it will be universal again.
Old Oct 14, 2007 | 06:44 AM
  #69
Darkside FD
I am VERY excited to receive it. I have sent you multiple emails. Let me know if you have not received my requests.
Regards,
Brian Kraemer
Old Oct 14, 2007 | 09:50 AM
  #70
Richard L's Avatar
I have not received any email form you recently. If you can send another one and I will check my spam filter just in case.
richard@aquamist.co.uk
Old Oct 15, 2007 | 04:31 AM
  #71
efiniste's Avatar
I think your post covers everything I can think of for the moment Richard. I hadn't realised it would replace the FIA2, I just assumed it would go between the injectors and the FIA2.
Re: Testing. I know Scott no longer has an RX-7 but I won't be in a position to help test anything until early November when I get my breakout loom. After that I can help out if you need anything. I'm only in Manchester so it may be quicker than sending stuff over to America.
Steve
Old Oct 15, 2007 | 02:02 PM
  #72
Richard L's Avatar
Good to know we have another RX7 test bed, this time closer to home.
Do you have some sort of logging device?
Old Oct 15, 2007 | 03:56 PM
  #73
efiniste's Avatar
yep, I can add it as an input on my Datalogit.
Old Nov 11, 2007 | 08:07 AM
  #74
Richard L's Avatar
pending the result of one user, it is ready to be distributed to all HFS-5 users participated on the GB in March 2007.
Old Nov 11, 2007 | 08:14 AM
  #75
Richard L's Avatar
Steve
Steve,
Please pm me your postal address.
