General Rotary Tech Support Use this forum for tech questions not specific to a certain model year
Sponsored by: CARiD
Thread Repair Aluminum Housing???????
Old Mar 24, 2009 | 07:46 AM
LoneStarT's Avatar
Exclamation Thread Repair Aluminum Housing???????
I need some advice...
I have some stripped threads in my Rotor Housing where my exhaust manifold bolts up. I'm wondering if anyone has had to repair these threads before and if so what did they use? (Heli coil, Thread locker,....)????
Old Mar 24, 2009 | 01:10 PM
Don49's Avatar
NAPA sells a thread repair kit. Bring a stud to the store to make sure you get the right size. The kit will have a drill bit , a tap and the thread inserts with a tool to install. It's easy and is a permanent fix. Just follow the directions with the kit. Other parts stores should have the kits if you aren't near a NAPA.
Th0m4s
25
Feb 26, 2019 02:04 AM
sYnth.
Aug 19, 2015 06:27 PM
