superchanger
Old Jul 12, 2002 | 05:03 PM
CHRISRX7F's Avatar
Question superchanger
who knows about superchanger(66hp more in rx7 fc non turbo)?how much can cost?
Old Jul 12, 2002 | 05:36 PM
Evil Aviator's Avatar
Rotorhead
http://www.geocities.com/boatseason/
http://www.atkinsrotary.com/supercha.htm
Old Jul 12, 2002 | 06:20 PM
J-Rat's Avatar
Alcohol Fueled!
http://www.camdensuperchargers.com/
Old Jul 14, 2002 | 08:47 PM
kristopher_d's Avatar
http://www.whipplesuperchargers.com/homepage.html
Old Jul 14, 2002 | 08:51 PM
Stay away from roots type superchargers, they are very thermally inefficiant. If you are going to supercharge, stay away from centrifugal, as they behave similarly to turbos, and a turbo setup can usually be had for less. That means twin screw superchargers. The camden/atkins rotary kits are not designed for FI engines, but they do come as a kit for the Rex. The whipple units will work with FI engines, but you have to either design and fabricate all the mounting hardware and ducting yourself, or find someone who has done it and pay them to do it for you.
Old Jul 14, 2002 | 10:02 PM
mazdaspeed7's Avatar
mad scientist
Youre contradicting yourself. The whipple sc is nearly the same as the eaton. Both are modified roots blowers. Roots blowers have straight vanes, while the whipple and eaton have them twisted, which increases efficiency by a good bit. It also makes the sc's have a better top end, lower outlet temps, higher VE, lower parasitic losses, etc.
