NO More Turbo lag !!!
Old Jul 6, 2002 | 02:33 PM
Check this **** out, this type of system is used on world rally champoinship cars. there is a drawback expect tho expect to Rebuild your turbo every week and replace the bearings cartridges. All teams use what they call an 'anti-lag' system. When the driver lifts off the throttle, the ignition timing is severely retarded, an above normal amount of metered air is allowed to enter the engine and fuel is injected between the exhaust valves and the turbine inlet. The ignited fuel creates heat that keeps the turbo speed up. When the driver re-applies the throttle, there is an explosion of raw fuel in the turbine that sounds like pistol shot, a burst of flame, and voila, no lag. This system can be switched on or off or modulated by a switch on the driver's control panel. i would love do that cept the cost damnit.
Old Jul 6, 2002 | 03:09 PM
relvinnian's Avatar
Sorry, couldn't resist
Old Jul 6, 2002 | 04:27 PM
ok well its new to me, i haven't seen anyone on any site with car do it, so its news to
Old Jul 6, 2002 | 04:30 PM
Greg's Avatar
exactly, there are new member joining everyday that have no clue about stuff like this.
Old Jul 6, 2002 | 06:06 PM
So why hasn't anyone tried it? cuz the cost of repiars ??
Old Jul 6, 2002 | 06:16 PM
i dont think anyone has the money to rebulid their turbo every week
Old Jul 6, 2002 | 11:27 PM
maxcooper's Avatar
WWFSMD
There is some anti-lag stuff in the PowerFC/Datalogit setup, too, but I haven't played with it yet.
Max
Old Jul 6, 2002 | 11:41 PM
Schweet thanks gmonsen, does the haltech feture work the same as i mentioned above or, is it safer for your turbo, and if it does work they same, wouldn't i have to Set up a a fuel line to the exhaust Manifold? thanx for the info.
Old Jul 7, 2002 | 05:12 AM
1FooknTiteFD's Avatar
Ghost Ride the Whip
Some of the high end FMU's can do this. Anyone watch initial D before? this is the exact system the Mitsubishi Evo 3 had in it's car dubbed the "misfiring system" I heard that it only works on certain turbos though.
Old Jul 7, 2002 | 05:47 AM
HWO's Avatar
HWO
inteligent extratarestril
you cant run WRC style anti lag on a rotary, because the rotor is too far round past the spark plugs to fire it miles after TDC to get the flame front straight out thru the turbo. The Hyundai WRC cars run 45psi boost at 0% throttle from antilag.
What they do is have a high flow solenoid which by passes the TB and flow enough air to keep the motor running when its running at like 30-40 degrees after TDC, they run like 20% enrichment when the antilag is acvtivated so you get combustion thru the exhuast manifold and into the turbine. It melts turbine wheels from prolonged usage (ie a rally stage) they thru the turbo's away after each rally
Old Jul 7, 2002 | 04:27 PM
Ok screw that idea for my car, so how do the electronic version of this sytems work, how could a computer type component eliminate Turbo lag?? I'm confused. i got another question tho, its not exactly related to the topic, i know the difference between a Wastegate, BOV, and SSBOV, but what is best? and is my understanding correct that a wastegate would do just as good as a BOV up to 400hp ?
Old Jul 7, 2002 | 05:15 PM
AJatx's Avatar
Anti-lag or as rally guys say "bang bang" has been around for quite some time. There are a few rotaries using anti-lag (as Gordon mentioned, a few from the Haltech list like Horatio from Jamiaca). I've heard of good results as well.
Steve Kan may have used anti-lag since a friend has heard his boost spool on the line.
You will shorten the life of the turbine. I think some people may over exaggerate damage as they are only guessing off hearsay.
Wastegate and BOV are similar mechanisms and functions, but very different application.
Wastegate basically vents out the "wasted" exhaust pulses through the gate into the exhaust; therefore, bypassing the turbine. A boost controller controls the top of the wastegate diaphragm to control the upper limit of boost.
Blow-off valve (or air bypass valve) will release the compressed air that is being made by the compressor wheel of the turbo charger as the throttle plates shut (letting off throttle) so as to prevent compressor surge (not good).
So, both will vent out air (exhaust or intake), but different application (limit boost vs. preventing compressor surge).
Your last question makes no sense to me.
BOV has nothing to do with horsepower. You set the spring tension so it'll vent out the compressed air at a desired boost level (soft -> less boost; hard -> high boost).
The wastegate has a spring in it as well that determines it's natural release point (14psi spring will compress at 14psi; thus the wastegate releases the exhaust at 14psi thereby holding boost at 14psi -- theoretically). The wastegate discharge diameter can play a factor on how efficient the wastegate can dump the wasted exhaust (40mm v. 50mm, etc).
Sorry for the long reply.
J
Old Jul 8, 2002 | 02:01 PM
Well i've seen on a few websites, and posts, that wastegates will be efficeint up to 400hp or like 15-17 psi. is this correct ? Thanx i appreciate the long post, means i learn more
Old Jul 8, 2002 | 03:27 PM
I use a anti lag system called NOS.
Old Jul 8, 2002 | 06:40 PM
maxcooper's Avatar
WWFSMD
Wastegates and BOVs do two different things -- AJatx described each of them well. Some particular wastegates and BOVs are only good up to a certain HP level or boost pressure. But these parts do different things, so you wouldn't buy a BOV if your wastegate was inadequate -- you'd get a different wastegate. Similarly, if your BOV can't handle the pressure, the only solution is to get a different BOV (or eliminate the BOV from the system entirely).
Wastegate is for boost control. All turbo cars have them. This is THE device that controls boost; nothing else does this job but the wastegate. Electronic boost controllers and other boost control devices just modify the control signal to the wastegate (which is one or two air/vacuum lines) -- it is still the wastegate that controls the boost pressure.
BOVs are for preventing compressor surge. Most turbo cars have them. They make the pssss noise when you let off the gas.
They serve different purposes, and just about everyone with a turbo on this forum has both devices.
-Max
Old Jul 8, 2002 | 07:53 PM
Ahh ok thank u, i was confused, cuz i listening to some guy who lives around here, and owns a riced out civic, but he seemed to know what he was talking about when i acually met him. I guess i was right, he's full of it.
Old Jul 10, 2002 | 09:54 AM
peejay's Avatar
Old [Sch|F]ool
hey now, not ALL cars have wastegates Some early turbo kits (and many diesels for that matter) ran what is known as a free-floating turbo setup - the turbo is sized so that it doesn't build maximum boost till near redline. Exhaust and carb restriction also came into play.
The Diesels are a different story - they're funny engines, for a given amount of fuel, they run cooler with more air, so it's best to just let the turbo spin up as hard as it wants.
Old Jul 10, 2002 | 01:34 PM
spyfish007's Avatar
Yellow Dragon is no more
I know of certain diesel trucks that have two turbos and no wastegates or blow off valves. Don't need the BOV if you don't have a throttle plate.
Old Jul 10, 2002 | 06:40 PM
Marcel Burkett's Avatar
The anti - lag system can work on a rotary , the claim that the " rotor is too far round the spark plugs to fire it " is incorrect , what actually happens is , when the feature is engaged the computer retards the ignition a pre determined amount to allow "raw" fuel to pass through the engine and into the very hot turbine housing where it is ignited by this heat just like a "back fire " from the muffeler.,this ignition is what causes all the strange noises and what also makes the turbo spool up due to the sudden and massive expansion of the gasses after the explosion.If you select the ignition retard featutre as your means of rev. limiting on the E6K you would see what I mean.
Old Jul 11, 2002 | 01:14 AM
HWO's Avatar
HWO
there are many different ways of running antilag, some do work on a rotary, others do not.
Old Jul 11, 2002 | 05:22 PM
pluto's Avatar
Anti what???! LOL
Old Jul 11, 2002 | 08:36 PM
R Xplicit's Avatar
how about a quick 25-50shot of spool-up juice. many drag racers are usng it....right?
Old Jul 12, 2002 | 01:52 AM
peejay's Avatar
Old [Sch|F]ool
On every upshift?
Old Jul 16, 2002 | 03:44 AM
UnSeeN's Avatar
haha..i was thinking the same thing..
