how much mod will a stock ecu take?
Old Jul 6, 2002 | 02:03 PM
B69ET's Avatar
Hello all,
i have a fd3s and i am planning to add some bolt on mods on it. i have bolted on a hks power flow system and soon to come a hiper cat back exhaust and down pipe.
i am wondering if my car will run lean b/c of these mods or will the ecu be able to handle/adjust to the new mods.
thanks in advance...et
Old Jul 6, 2002 | 02:25 PM
P'cola FD's Avatar
Hamado things my way!
The ecu will not adjust for the mods. The general rule of safety is no more than three mods to a stock ecu running ten pounds of boost. Some people have run more, but a reprogrammed ecu or power fc are much cheaper than an engine rebuild. There is plenty of info on the forum, if you search for it.
Old Jul 6, 2002 | 03:20 PM
Mahjik's Avatar
Mr. Links
Re: how much mod will a stock ecu take?
Originally posted by B69ET
Hello all,
Take a look at Wade's site:
http://www.newwave.net/~flanham/wlan.../3modrule.html
As long as you keep the boost around stock levels (10 PSI), the stock ECU will be fine for just about whatever you slap on with the stock twin turbos.
Queppa
Nov 18, 2024 03:47 AM
incubuseva
14
Sep 3, 2015 12:37 PM
