Basic Single Turbo setup
Old Jun 5, 2002 | 07:37 PM
neo_omega's Avatar
***Moderator***
Question Basic Single Turbo setup
Assume I have no mod to the car. What the basic things needed for a single turbo setup?
BTW I saw Jason's stage mod list. I know these parts are needed.
ECU
Front Mount Intercooler
Midpipe
Fuel Pump
Turbo Kit
Exhaust
But are all these following parts needed?
Main Drive Pulley
1300cc Injectors
Boost Controller
Pulley Set
Old Jun 5, 2002 | 07:52 PM
user 84205's Avatar
Is this a quiz??? haha
PULLEY kit/ Main drive pulley. Anyway, depends on the turbo weither you need the pull kit or not, but you dont need a power pulley, unless you want it, BUT its not Needed...
1300cc injectors are not needed, but for the price
many people get them because you can convert your
old ones. Depending on the turbo, will tell you what
fuel you may need, the pump and stock injectors could
be enough.
BOOST controller, well this I think depends on you, you can tune your ECU so you dont really need one, BUT! if you want to race then do street driving you would want to be able to change it back and forth, especially when you have cold days... I recommend a boost controller.
NEO, i know you already know this right? So whats up?
Old Jun 5, 2002 | 07:59 PM
Jason's Avatar
The one
Here is a minimum single turbo setup.
Single Turbo Kit
ECU - Power FC
Larger Injectors
Fuel pump
Just those 4 things is all you need to run a single. You can actually get away with the stock injectors depending on the boost you want to run.
If you want to do it right the first time, then add:
Intercooler upgrade
High flow cat or midpipe
Catback
Pulleys
Ignition computer
Jason
www.rx7store.net
Old Jun 5, 2002 | 08:11 PM
neo_omega's Avatar
***Moderator***
Thanks Jasons
Old Jun 5, 2002 | 08:14 PM
user 84205's Avatar
hahaha I think both of us agree, NO PROBLEM>>>>
Old Jun 7, 2002 | 08:52 AM
neo_omega's Avatar
***Moderator***
Originally posted by Dont_Be_A_Rikki
you do not need a front mount to go single that is Bull $hit..... why does everyone think this? single turbos actually run cooler than stock twins so any upgrade from stock is fine unless you want more than 18psi then go a bigger but for front mount it does not matter they just look cooler that is all.IMO
actually I do need a FMIC, coz I ordered the CF Scoot Hood.
Old Jun 7, 2002 | 08:24 PM
Jim Swantko's Avatar
Re: Basic Single Turbo setup
ECU
Midpipe
Fuel Pump
Turbo Kit
Exhaust
Main Drive Pulley
1300cc Injectors
Boost Controller
Pulley Set
You should have just bought my car! Hahaha...
Just kidding Neo
Old Jun 7, 2002 | 09:12 PM
Want2race's Avatar
Bigger and better things
I dont see why you NEED the pulleys... personally i would not add them to my car because I like the alternator working @ full speed, I like my Ac cold and I like the powersteerings rates.. And finally i dont want to lower the speed of the water pump. So personally I think its fine!
What would you say its needed? Singles dont have any adverse effects that i know of..
someone educate me..
Old Jun 7, 2002 | 10:30 PM
Jason's Avatar
The one
If you want some extra H.P. get the pulleys. They have no adverse effects on the A/C or water pump. Most people that go single remove the airpump and buy the Greddy pulley set. Thats why I have them listed.
Jason
Old Jun 9, 2002 | 09:41 AM
neo_omega's Avatar
***Moderator***
Re: Re: Basic Single Turbo setup
Just kidding Neo
I would have You just didn't give me time as you said you would.
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
