My DIY Intake under $100
Old Jun 3, 2002 | 11:44 PM
xph's Avatar
xph
I wanted a nice looking intake, but no way was I going to spend $500 for it, so I took a trip to autozone, and picked up some 3" filters, and then to the F&F Speed Shop (Fleet Farm) for some parts... Pop rivets, some plexi-glass, PVC Pipe, some aluminum angle, and some aluminum sheet (for the duct down to the radiator edge.
Old Jun 3, 2002 | 11:45 PM
xph's Avatar
xph
A Little Magic and some silver paint....
IgoSlow's Avatar
Hey not to shabby at all.. good work man
Old Jun 3, 2002 | 11:49 PM
xph's Avatar
xph
I am not using the air pump at this time, or I would have mounted is little filter through to the front, along with the "moo" pipe. I have to pull the filter off the BOV before I race, as it is too restrictive, and I am afraid it will cause boost spikes / creep / shoot off the end and dent my hood =0
X
Old Jun 3, 2002 | 11:51 PM
xph's Avatar
xph
Another Angle
Old Jun 4, 2002 | 12:26 AM
AdamP's Avatar
That is a sweet set-up man. I want to do that myself. Can I grab the dimensions from you To make my life a bit easyer. Part numbers for those filters would be nice to if you have them. Thanks
Old Jun 4, 2002 | 12:28 AM
Bucrx7's Avatar
Won't the PVC pipe melt and become disfigured from the engine heat?
Old Jun 4, 2002 | 12:41 AM
FourtyOunce's Avatar
good luck with the underhood temps. your box will last about 20 mins under hard driving before meltdown happens.
Old Jun 4, 2002 | 12:55 AM
AdamP's Avatar
On my turbo II I used ABS plastic tubing for my all my intercooler piping and it worked perfect for over 2 years, before I sold it. Never did I see any of it melt and I had it coming right off the turbo. There is no way that there will be any problems using it for some intake piping that far from the turbo.
As far a s plexi-glass I have no idea how that will stand up to underhood temps. I would worry most about keeping the glass clean.
Old Jun 4, 2002 | 12:59 AM
Cetchup's Avatar
The Cursed FD
Nice work! I really appluad your creativity...However, like some others have said you may want to rethink your materials. Im pretty sure you could go to a machine shop and have them make a mold of your design out of maybe aluminum or some other metal. It would turn out awesome im sure!
Old Jun 4, 2002 | 01:39 AM
RX-8's Avatar
sweet
Old Jun 4, 2002 | 01:53 AM
Quickfini's Avatar
Woah those look damn good.. i was thinking of making my own setup like that too.. looks sweet..
But i have one question about pvc.. when it melts, doesn't it release some kinda chlorine gas? i don't think thats healthy man.. ???
Old Jun 4, 2002 | 04:17 AM
xph's Avatar
xph
Had no problem with CenDiv last weekend, The main back plate is 1/4" I also have all of my exaust / turbo housing ceramic coated. I really dont thik that the PVC will be a problem... The PlexiGlass will melt well before the PVC is a problem.
Old Jun 4, 2002 | 04:34 AM
xph's Avatar
xph
The K&N 3" filter I used was #RU-3580 / $35 each (the most expensive part, the small 3/4" filters are push in jobbies from the rice boy area.
The next time I pop it iff I'll be sure to get the dimensions.
X
Old Jun 4, 2002 | 05:39 AM
~ZoSo~'s Avatar
Newbie
those two 3/4" filters and hoses arent required though are they? can you just get rid if them all together?
Old Jun 4, 2002 | 08:42 AM
RyanREX's Avatar
Killer Turbo Twins
Beautiful. Great work. I'll have to try my hands at something like that when I get my filters on.
Old Jun 4, 2002 | 09:16 AM
Want2race's Avatar
Bigger and better things
Looks great.. if the shield melts try lexan.. no heat transfer and resistant to heat.. Nascar uses it!
Old Jun 4, 2002 | 11:44 AM
black99's Avatar
Lurking..................
One of the better looking intakes I've ever seen..
Old Jun 4, 2002 | 11:54 AM
martini's Avatar
Lexan WILL bend, melt, and bubble when heated.
On my CRX, we made Lexan headlight covers on the fiberglass front end. And in order for them to curve properly around the edge, we had to use a heat gun, and bend it in place. We messed up once because it got too hot and started bubling and turning brown. It wasn't really that hot, either.
Old Jun 4, 2002 | 05:57 PM
legendr35's Avatar
looks pretty cool
Old Jun 4, 2002 | 09:29 PM
MaxRX7's Avatar
hambre y sueño
that's **** !!
Old Jun 4, 2002 | 09:50 PM
RonKMiller's Avatar
Blow up or win
Lexan brand (made by GE) can handle up to 300F, after that you can bend it, it melts at around 450F which is low setting on most electric heat guns. Depending on the brand of "plexi-glass" you have you will probably see it melt well before that. Should not be a problem in your application. The ABS though, will discolor and melt at MUCH lower temperatures. Still should not be a problem, and so what, you can always go to Schedule 40 for that heavy duty boost!
