No Ignition Spark
Old May 16, 2002 | 11:27 PM
Killa7's Avatar
No Ignition Spark
I tried to start the 88 N/A. I have tried to turn it over, and it turns over fine. I have fuel, but no spark on any plug wire. Neither leading or trailing had a spark when i put a timing light on the wires. Checked the fuses in the engine bay, and all were live. What exactly should i do, or check next?
Bryan
Old May 17, 2002 | 12:24 AM
Killa7's Avatar
Any Ideas? Trying to get this done this evening. Sorry if I seem impatient, thats what i am :P
Old May 17, 2002 | 06:13 AM
HAILERS's Avatar
HAILERS
Check the fuses in the crew compartment. Near your left foot. /Count the rows of fuses from the bottom upwards. Forth row up, third fuse over from your left. If you have a cover for the fuse box, it should call that fuse *engine*.
Old May 17, 2002 | 07:37 AM
kylekyle's Avatar
If you starting, motor is move, or no?
Old May 17, 2002 | 07:39 AM
kylekyle's Avatar
if motor is move, then Fuses is OK
Old May 17, 2002 | 07:43 AM
kylekyle's Avatar
check cabels from wire spool to plugs
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
Aramir
Oct 18, 2015 02:39 AM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
subeone
Sep 24, 2015 09:58 PM
Mps_hell
Sep 19, 2015 10:02 PM
