Who have a 20B installed and where are you located?
Old May 2, 2002 | 04:05 AM
rerx7's Avatar
If you have a 20B, please state your location and mods
Old May 2, 2002 | 05:10 AM
mad20b's Avatar
yip - all the usual mods - big single etc etc - living in christchurch new zealand
Old May 2, 2002 | 05:16 AM
mad20b's Avatar
Old May 2, 2002 | 10:37 AM
now's Avatar
now
I have one in the works in a fc 10th ae, will be close to all stock,, and should have it running in a week or so.
rerx7, what about you?
matt
Old May 2, 2002 | 11:25 AM
rerx7's Avatar
I have a FD 13B not lucky enough to get a 20B into my FD.
Old May 2, 2002 | 12:09 PM
bermuda20b's Avatar
My FD is from Canada, I live in Bermuda...the car lives in either Las Vegas (racing) or Victoria (storage). All the racing goodies and engine upgrades.
Old May 3, 2002 | 03:31 PM
j9fd3s's Avatar
Community Builder
1988 turbo 2
current mods:
20b w/k2rd mounts
e6k
profec a boost control
greddy fmic (the old one)
rb 17# flywheel
act extreme(ly insane) clutch
k2rd radiator
sparco torino (drivers side)
89+ taillights
coming soon:
rear seat
suspension (k2rd)
some sort of exhaust
the car is in northern california
mike
Old May 3, 2002 | 06:42 PM
now's Avatar
now
mike you get it running?
Looks like I will have to wait till monday now to try my
20b out, having problems getting the drive shaft made
will have to post a request when i get more info,,,
something about no replacment u joint for the cosmo
shaft end.
matt
Old May 3, 2002 | 07:21 PM
j9fd3s's Avatar
Community Builder
when i brought it home (changed jobs) i decided to clean some stuff up. so no its not running, but its gonna look like its factory im even playing with the idea of some sort of factory airbox
mike
Old May 3, 2002 | 10:00 PM
now's Avatar
now
Hmmm I was looking at the air box area and I don't think
there is going to be much room there for anything more
than a cone filter,,, but that's a few days away for me.
worked on wiring routing all evening tonight and there is
still lots more to do,,, guess that gives me something to
do while I wait for the drive shaft..
matt
Old May 4, 2002 | 03:02 AM
Bitchn7's Avatar
Zilla Killer
Have 20B in JC Cosmo, ported, big exhaust, filter etc.
Also have 20B in Citreon, yip thats right, but its just in the boot at the moment, will be trial fitting it into our 323 hatch soon.
In Waikato NZ.
Old May 4, 2002 | 01:16 PM
j9fd3s's Avatar
Community Builder
dude you should put it in the citreon that would be funny.
now: i dunno if it will fit but im going to give it a shot.
it might just be the cover with a cone placed underneath
mike
Old May 4, 2002 | 03:51 PM
Evil Aviator's Avatar
Rotorhead
My car is still in the works, but this is what I have so far. It is being built as a street/road race car, and is located in St. Petersburg, Florida, USA.
Body:
Mazda 88 RX-7 SE Body
Mazda 89 RX-7 Front End
Mazda RX-7 Turbo II Aluminum Hood (Intercooler Scoop Internals Gutted for Engine Clearance)
Engine:
20B 3-Rotor Engine from Shane Racing (Stock Porting & Internals)
88 NA Front Cover and Mechanical MOP
Turbonetics T-66 Turbo (Tangental Undivided Housing w/V-Band discharge, P-Trim, 0.96 AR, 2.580"Incucer/3.584" Exducer/4"Inlet, Polished and Ceramic Coated)
GReddy Type-C Wastegate
TiAl Blowoff Valve
Wolf-3D 4.0 Engine Management System with 3D Boost Control
Wolf Modified 20B Crank Angle Sensor
SPiN Racing Custom Engine Mounts
Griffin Custom Radiator (26.5" wide 16" tall 3" tanks, 2 3/4" core)
SPiN Racing Billet Aluminum Dual Thermostat Housing
Aeroquip AN -20 Radiator Hoses and Fittings
Aeroquip AN -10 Fuel & Oil Hoses and Fittings
Spearco 2-248 1500cfm Front-Mount Air-Air Intercooler
Essex Industries (SX) 18201 Fuel Pump, 41001 Filter, and 15402 Fuel Regulator
Exhaust:
Sidewinder Racing Custom 3" SS Downpipe and 3" Y-Exhaust System
Sidewinder Racing Custom Wastegate Bellows
CMR Turbos Custom Short-Runner Exhaust Manifold
A'pex N1 Mufflers (2 each)
Hi-Flow Cat (Can be quick-changed with straight pipe for track events)
Transmission:
Mazda 88 NA 5-speed Manual Transmission (Should last a couple of minutes)
Quarter Master 5.5" 2-Disc Clutch, Pressure Plate & Throwout Bearing
Mazda Competition (Billington) 4-lb Flywheel
Mazda 88 GXL Limited Slip IRS Rear End
Suspension:
Mazda 88 GXL Hubs, Spindles, etc.
Mazda Competition Stage II Kit
Koni Coilover Shocks
Eibach ERS Springs (400lb Front, 275lb Rear)
Eibach Anti-Roll Bars
Urethane and Delrin Bushings
Delrin Toe-Steer Eliminators
Front Camber/Caster Kit
Rear Camber Kit
Interior/Other:
SPA Techniques Gauge Set (Tach/Speedo, Boost/EGT, Oil Temp/Press, Water Temp/Press)
Wolf AF1 Air/Fuel Ratio Meter
GTech Accelerometer
Momo 1000 Lakes Seats (2 each)
TRW Sabelts Camlock 5-point 3" harnesses
Creative Motorsports 8-point Custom Rollcage SCCA GT Spec w/NASCAR-type side bars
Old May 5, 2002 | 09:40 PM
RX-Heven's Avatar
I'll blow it up real good
I'm in San Francisco and the car has been in the works for a LONG time. Hope to have it done by the end of the summer, if not end of the yaer. Though realistically by the time internal engines become illegal to operate. The car is an 88 10th Anniversery. Engine is finally being built now at Pineapple Racing.
Engine:
Large street port
Probably a dry sump system
Hurley 3mm
As bullet proof as Rob can make it
Polished and powdercoated
Fuel/induction/ECU system yet to be determined
A LONG ways to go
Car so far:
Major diet
Tri-Point Engineering flare kit
RE Amemiya FC 2000 front bumper
Should fit 17x11's in front and 17x12's out back
Kaaz diff
Diff mount welded together
Aluminum driveshaft
Jericho 5-speed dog box
Koni dual adj. custom valved & dynoed by Tri-Point
500 lb. front 275 lb. rear
Delrin wherever it can be
Adj. rear sway bar w/ eurathane & adj. links
14" rotors with alum. hat in front
6 POT AP racing calipers up front
Stainless lines
Front camber/caster
Rear camber
Subframe connector
Manual rack
K2RD mounts
6 - point roll cage
A LONG ways to go
Old May 5, 2002 | 09:49 PM
Rotorhead
Where did you get the adapter? Also, how did you mount the starter?
Old May 6, 2002 | 01:25 AM
RX-Heven's Avatar
Don't have the engine yet to mount a starter on since it is still being built. I think I recall Rob at Pineapple telling me that since the 5-speed is a shift rail type, it would clear the starter. If I need an adapter I can mill one at my shop if there are none available or are to pricy.
Old May 6, 2002 | 08:10 PM
Turbo III's Avatar
'89 TII Body
Acura Inza Red paint
SR Motorsports street-port
T-76 Turbo, Q-trim, 1.32 exhaust housing
FMIC (R&D, waiting on bumper yet)
SR Ultimate II fuel pump
Weldon fuel pressure reg
1600CC secondaries w/custom SR rail
Indigo FC racing radiator
Custom SS 3.5" turbo-back single exhaust w/Borla XR-1 Electromotive TEC I computer w/TEC 2 Prom
18# flywheel
ACT Extreme clutch w/6puck disc
16" 2950 CFM electric fan
APEX'I AVC-R
Yokohama A520's
TEIN HA coil-overs
Manual rack conversion
ABS -> non-ABS brake conversion
Adj. -> non-adj. steering column
Custom hood
Rotary extreme C-West FD-> FC bumper
Polished motor parts and rims
Battery relocation
Racing Beat rear sway bar
Autometer guages ->A/F, dual probe EGT, Fuel pressure, oil temp/pressure, coolant temp
I'm sure I'm forgetting something else...custom interior (sound dampening, stereo, alarm, etc.)
Future plans - Full brake kit, Kaaz differential, custom front sway bar, custom driveshaft, wide body kit with the largest rims I can fit for traction purposes, keep turning up the boost and put 720's in the primaries after the traction problems are worked out.
Old May 7, 2002 | 02:10 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
Anyone ever concider a t56 transmision to put behind a 20b? some of them are rated up too 750lbs/ft . I know theres is an adapter housing for a 13b..... Just curious.
I can get one cheap to rebuild.
Old May 7, 2002 | 03:16 PM
Rotorhead
Yes, I am considering it. They have rather sloppy shifting, and the models with the .5 6th gear can't handle enough torque, so I would have to use a .62 or .75 6th gear model and an aftermarket rear end. I'm not sure if it would be so great for high revs. It doesn't cost very much, though.
Who sells an adapter?
Old May 7, 2002 | 11:31 PM
Rx_treme's Avatar
where have you found the prices on those at?
also what would you do with the rear end? use a different one or just make a custom driveshaft?
Old May 13, 2002 | 03:13 PM
DELTA_Rotary's Avatar
Bourbon King
I've asked about the T-56 before and I got the impression that the T-56 could handle the HP and Torque but the really high revs would kill it.
Old May 22, 2002 | 03:38 PM
PaulC's Avatar
The .5 6th gear ones are rated for 550lbs/ft of torque. And I know thats conservative because a friend put one behind somewhat built 454 and hes hard on it.
As far as an adapter there was a thread for one in the 2nd gen forum around the begining of the year I think. I was contemplating one for my NA. I lost the link to the web page when my hard drive crapped out. So I would need to find it again. Hopefully its still in archive if nothing else. Ill try to find it.
Old Jun 4, 2002 | 09:00 PM
protlewski's Avatar
Body:
Engine:
TiAl Blowoff Valve
Exhaust:
Transmission:
Suspension:
Rear Camber Kit
Interior/Other:
GTech Accelerometer
damn man!! thats alot to type! I would give up and say I put the whole nine yards. holy crap thats good we have a moderater that can type a bajillion words a minute. I'm hoping to get a 20B in the future to put in my corvair. That will be sweet when I do.
