help!!!!!!!! my car won't start!!!!!!!!
Old Apr 23, 2002 | 05:47 PM
RUWETYT's Avatar
i have an 88t2. it killed and then wouldn't start. so i thought it was just flooded. so i let it sit almost all day and it still wouldn't start. so i changed the plugs and had no luck. then i relized i was getting no spark, and no power from the ecu to the ignition system. every thing else works (radio, fan, etc.). and the fuses are all ok. i am thinking it is some kind of relay or something. does anyone know or have any ideas? thanks!
Old Apr 23, 2002 | 11:45 PM
RUWETYT's Avatar
Old Apr 23, 2002 | 11:52 PM
try to switch out ecus. borrow another from your friend or something. and check the interior fuses also. like the room fuse.
Old Apr 24, 2002 | 01:19 AM
MaxRX7's Avatar
hambre y sueño
how did it get "killed".
check the fuses under the hood. especially the 1st two (EGIs)...
Old Apr 24, 2002 | 02:55 AM
fLyiNgOuFeR's Avatar
if you think it's a relay check out the main relay. it's ryte next to your trailing coils. little gold box. that controls ignition power to your coils and injectors.
Old Apr 24, 2002 | 08:11 AM
RUWETYT's Avatar
it just killed will i was driving slow. thanks for advice. i will try checking the fuses and relay. i'll keep ya posted.
Old Apr 24, 2002 | 08:33 AM
HAILERS's Avatar
HAILERS
Look at the forth row from the bottom on the fuse box. Third fuse from the left, on the fuse box in the car. In the engine compartment check the sixty amp fuse. You claim there is no power for the ignition system so that would be the 60amp in the engine bay which passes thru the third fuse from the left mentioned above. How did you determine there was no power from the ECU to the ignition system?????????
Old Apr 24, 2002 | 08:34 AM
Kastle's Avatar
I have the same problem with mine it will not start and doesnt want to push start either , Did you try a compression test? thats what was wrong with mine but i got that problem fixed but it still doesnt want to go ....shes sooooo close tho .
Old Apr 24, 2002 | 08:58 AM
HAILERS's Avatar
HAILERS
Here in black and white:
Old Apr 24, 2002 | 09:04 PM
RUWETYT's Avatar
yeeeeeaaaahhhhh!!!!! that was it. it was the 15 amp fuse under the dash. ya know.... the one that says "engine". duh! kastle you should try checking that fuse. thanks hailers and every one else for the help.
alphawolff
Nov 17, 2015 05:57 PM
torky007
Aug 17, 2015 05:14 PM
