thermostat?
Old Apr 10, 2002 | 07:34 AM
MazdaRx7Power's Avatar
thermostat?
how do you gut it??? i heard that you can gut it so it holds back a little bit but is still flowing?? cause i think mines is getting stuck right now....
Old Apr 10, 2002 | 08:48 AM
RETed's Avatar
If you stare at it, you'll see that it's supported by two "legs" on the top and the bottom.&nbsp Get a pair of wire cutters and cut all four of them.&nbsp The center core should fall out.&nbsp Put the flange back into the thermostat housing...
-Ted
Old Apr 10, 2002 | 08:52 AM
jmseven's Avatar
Asset is Wealth
Buy a new one.
Old Apr 10, 2002 | 09:38 AM
do i cut the spring off???
Old Apr 10, 2002 | 09:54 AM
RETed's Avatar
The spring falls off with the "core" once you cut all the legs off.
-Ted
Old Apr 10, 2002 | 09:57 AM
oh basically all i'm gonna do is cut everything off except the part that lays in the housing????
Old Apr 10, 2002 | 10:02 AM
RETed's Avatar
That's it!&nbsp That's how you "core" a stock thermostat.&nbsp You just end up with the metal flange on the outside.
The other option way is to drill holes around that metal flange, but I've found it's a major pain in the *** to do that!
BTW, my thermostat has been cored like that, and I've been running it in my car for the past year or so.&nbsp Yes, the car runs too cold sometimes, but once it warms up to operating temp, it never goes below 180F, unless ambient temps are stupid low like under 40F.
Why did I do that?&nbsp I had an overheating problem, and I didn't have another replacement at 1AM in the morning...
I never bothered to replace it since...
-Ted
Old Apr 10, 2002 | 03:46 PM
NZConvertible's Avatar
I'm a boost creep...
Re: thermostat?
Just go and buy a new Mazda one.
Ted, you're a lazy bastard!
Old Apr 10, 2002 | 07:29 PM
RETed's Avatar
You know what's funny...&nbsp I actually have a stock Mazda thermostat sitting in the box on my desk...
Hell, Vegas just started hitting 90's again - no need for a thermostat!
-Ted
Old Apr 10, 2002 | 07:33 PM
yeah i'm in florida so i should be good right? i just cut it and the temp didnt pass 1/4... thats also ok right??
Old Apr 10, 2002 | 07:41 PM
It's not just overheating you should be worried about. You want your engine to warm up as quickly as possible to minimise engine wear, emissions, fuel consumtion, etc. Only a working thermostat can do that.
Old Apr 11, 2002 | 02:53 PM
perfect7's Avatar
always remember that heat is not our friend
Old Apr 11, 2002 | 03:29 PM
blu_gxl's Avatar
i've gone to an e-fan and realy don't need my thmostat exept for the housing would it be better to just gut it?
james
Old Apr 11, 2002 | 03:54 PM
The fan and the thermostat perform two totally different functions, you need them both. You needed a 'stat when you had a mechanical fan, why wouldn't you need one with an electric one?
MidnightOwl
Sep 25, 2015 10:24 PM
erevos
Sep 15, 2015 09:19 AM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
