Best possible fluids, oils, and liquids?
Old Apr 9, 2002 | 11:35 PM
JumpyRoo's Avatar
Maybe asked before, prolly not in the same post.
Please list your favorite oils, coolants, fluids, and etc. For all possible applications. Brand names, weights, amounts, and all that good stuff.
Old Apr 10, 2002 | 12:37 AM
RETed's Avatar
Motor oil - Mobil1, if money was no object I'd go Redline
Trans - Redline MT-90
Rear end diff - Redline 75W90
Brake/clutch fluid - Ford Hi-Performance, if money were no object Castrol SRF
Coolant - Prestone (although a recent story on Mercedes coolant got me thinking)
Grease - Redline CV-2
Penetrant - Liquid Wrench
Anti-sieze - Permatex nickle
RTV - Permatex Copper RTV
(no windshield washer fluid)
Pre-mix - Valvoline Multi-use Premix, if money were no object Redline premix
Non-toxic cleaner - Oil Eater
Drink - ANYTHING fruit punch
-Ted
Old Apr 10, 2002 | 12:49 AM
rico05's Avatar
WTB S5 N/A FC
Everything Ted said I use in my car. Good list to follow, but NOT a cheap one!!!
Old Apr 10, 2002 | 01:07 AM
JumpyRoo's Avatar
Tell me about Magical Mystery Oil...
Old Apr 10, 2002 | 01:17 AM
Jerk_Racer's Avatar
That list might have some expensive fluids on it, but how often are some of them changed? Initial out of pocket expense might be high, but spread the cost over time and it isn't so bad. Can't go wrong with Ted's list.
Old Apr 10, 2002 | 01:18 AM
cymfc3s's Avatar
I Raise Chickens
redline motor oil is actually just repackaged from a major oil company. Shhhh, you didnt hear that from me. ; )
for me, i used valvoline 20w50 in the engine. And believe me, for as much money as i have into the motor, this is what i use. They real key is changing it frequently.
I used motul brake fluid, but it does need to bled often. It obsorbs water easier. The ford stuff i hear is pretty good.
Coolant, use the green stuff. I just use the mazda brand coolant. (Prestone)
Tranny: Redline MT-90
Diff: Redline shockproof gear oil
Drink: Long Island Ice Tea (best bang for the buck)
Old Apr 10, 2002 | 02:21 AM
JumpyRoo's Avatar
So, what if my car turns out to have synthedic oil in it from the previous owner? What do I do?
Old Apr 10, 2002 | 03:10 AM
Jerk_Racer's Avatar
Don't worry about it. Just use Mobil1 or the good ol' Castrol GTX and change it often.
Old Apr 10, 2002 | 03:12 AM
how about ate super blue for brake fluid?
Old Apr 10, 2002 | 04:07 AM
kim307's Avatar
I would say:
Motor Oil - Royal Purple 10w40
Rear Diff - Redline 75W90
Tranny - Redline MT90
Coolant - Evans Non-aqueous coolant
that's my plan, anyways.
Jay Kim
Old Apr 10, 2002 | 09:00 AM
RETed's Avatar
Sure, that'll work.&nbsp It's the same thing as Super 200, but with a blue dye in it.&nbsp Lots of racers switch between the Super 200 and Super Blue just so they know when their ENTIRE brake system is flushed.
This still won't touch the Castrol SRF. Castrol SRF is da **** when it comes to brake fluids. &nbsp You ever priced this stuff?
-Ted
Old Apr 10, 2002 | 11:34 AM
Newbie
ANYONE TRY VALVOLINE MAXLIFE AND DURALUBE I'VE
NOTICE THAT MY MOTOR SOUND MUCH QUIETER
ENGINE TEMPS LOWERED A BIT
I USED CASTROL BEFORE IT JUST BURN UP FASTER
THAN THE MAXLIFE TRY IT AND LET ME KNOW WHAT
YOU THINK
Old Apr 10, 2002 | 10:57 PM
JumpyRoo's Avatar
Caps...
What about washer fluid?
Old Apr 11, 2002 | 08:00 AM
RETed's Avatar
I've got no washer bottle, so I can't run any...
-Ted
Old Feb 13, 2004 | 12:45 AM
Ronac's Avatar
RETed, for the motor oil, you say mobil 1 regular and not synthetic correct?
I know I'm a grave digger...
Old Feb 13, 2004 | 12:58 AM
andrew lohaus's Avatar
is 15w-50 the ideal wight of mobil 1 to use. i finaly switched to premix (you convinced me ted) and am gona go synthetic on my next oil change. looking for the best option.
Old Feb 13, 2004 | 11:11 PM
HI!
where is the best place to buy redline?
Old Feb 13, 2004 | 11:22 PM
water wetter for the coolant
Old Feb 13, 2004 | 11:40 PM
Wankels-Revenge's Avatar
Defected to the dark side
Does royal purple make tranny fluid? If so how does it compare to redline?
Old Feb 14, 2004 | 12:26 AM
^^^^^ they do. they have tranny oil. they have a light weight one which i think is equivalent to the red line light weight then the have 75w-90 and 85w-140. i think im gona go with some of the syncromax light weight when my freind gives me his extra lsd, give the whole drive line a little lovin'. new bushings too.
Old Feb 14, 2004 | 12:38 AM
Ya thats good to hear. I ask because this performance shop nearby recently switched from redline products to royal purple. Its more convenience than anything really
Old Feb 14, 2004 | 12:54 AM
yep they sell royal purlpe just up the street from me. i dont care how good it is, it just seems silly having order and ship motor/gear oil.
Old Jan 28, 2005 | 03:03 PM
Feds's Avatar
More Mazdas than Sense
Use the rain-ex washer fluid. It's very JDM. Plus, if it snows, it looks like someone peed on your hood.
Valvoline 20w-50 in the motor, redline everywhere else.
Old Jan 28, 2005 | 03:23 PM
jon88se's Avatar
Eat, sleep, work, mod.
My car has the following:
Motor: Castrol GTX 20/50 summer and 10/30 winter
Trans: BG syncroshift
Rear: Redline 75W90
Brake: ATE Super Blue
I was never particular about brands of coolant in the car...if it's green and you mix it properly (or buy the pre-mixed) I wouldn't worry about it. I think some of the more expensive brands have less/no silicates which can corrode rubber hoses and water pump seals over time.
Old Jan 28, 2005 | 03:25 PM
onePOINTthree's Avatar
N/A is teh WIN!
well i just changed the tranny fluid and diff fluild with 75w-90 Valvoline Synthetic and is shiftes great now, but i'm still going to change it to Neo Synthetics 80w-90.
For the coolant, what me and my friend's run in the summer is the following: 30% coolant, 70% water, 2 drops of Plamolive (dish soap). The plamolive breaks the surface tension of the water (same thing water wetter does) so that you get better heat transfer. Durring the winter i think it's just best to run a 50% 50% mix
edit: oh and brake fluid will be Neo Synthetics becasue it costs less then Motul and has a higher boiling point
