Hot air OUT! New mod for anyone with too much time on their hands........
Old Mar 7, 2002 | 04:53 PM
RonKMiller's Avatar
Blow up or win
Hot air OUT! New mod sucks! (REALLY..)
I was sitting around yesterday thinking about my old chemistry professor mumbling something about how every 10 degree increase in temperature causes chemical reactions to double in speed. And then I realized that summer is just around the corner and had visions of my engine screaming at me for help. I've been contemplating a "vented" hood but it just did not seem to make a lot of financial sense considering the cost, shipping, painting etc. Plus, who knows how well they work? - and then there's the rain issue...... Here's what I came up with: (and true to my Scotch ancestry this is very thrifty as well)
1. The NACA side fender duct on the passenger side of
my 93 touring does absolutely - nothing. So why not
put it to work ventilating the engine compartment?
Yeah - that's the ticket! So, off comes the fender
and out comes the 3" metal cutting hole saw.
On the inside top of the inner frame you will see a
4" square that has been already been cut out -
perfect for my cut, and inside it there is really
nothing except part of a wire harness in the engine
compartment to watch out for when making the cut.
Wham - a new 3" hole now exists and looks like
this:
Old Mar 7, 2002 | 05:01 PM
RonKMiller's Avatar
Blow up or win
Damn server.......GRRRRRRRR. Anyway - on with the new thread!
I then lined the hole with strips of foil tape to create a "tunnel" to the outside:
Old Mar 7, 2002 | 05:10 PM
RonKMiller's Avatar
Blow up or win
OK -
Now we get some foil (not plastic!) clothes dryer 4" super flexible ducting and tape it to the "square", bend it, and cut out an oval section on the interior plastic liner duct to mate it to. Seal both ends with foil tape.
I sealed off the forward end of the duct, as
well as other seams to create a leakproof routing for the exiting hot air. I could have cut off some of the ducting but chose to leave it stock in case I decide to add an extra oil cooler in the future- this way I could just poke through the foil tape to make it functional again without taking the entire fender off:
Old Mar 7, 2002 | 05:20 PM
RonKMiller's Avatar
Blow up or win
And here's the view of the completed ductwork with some additional aluminum sheet to complete a sealed duct that will interface with the NACA duct. I repeated the process for the driver's side. How well does it work? I intend to do temperature measurements with a calibrated pyrometer (a $1K instrument I just happen to have laying around the shop) at different locations and speeds inside the engine compartment with/without the duct sealed and post them later. Stay tuned sports fans!
Old Mar 7, 2002 | 05:46 PM
Flybye's Avatar
It's never fast enough...
Pictures are taking too long to load.
Take your $10 Naca duct and shove it
Old Mar 7, 2002 | 05:53 PM
RonKMiller's Avatar
Blow up or win
HAHAHAHA! Would that be with KY or without?
Hmmm, you wouldn't be selling vented hoods per chance? (It's actually more like $7.50 for the foil tape..)
Old Mar 7, 2002 | 05:58 PM
Flybye's Avatar
A vented hood? I drove around WITHOUT a hood
You know, a naca duct attached directly to the turbo manifold may prove to be interesting....
Old Mar 7, 2002 | 06:08 PM
Freaky Monkey007's Avatar
Now just take a hair dryer and mount it to that and the intake.. You will have a T-100 then and be makin mad HP.
Old Mar 7, 2002 | 06:27 PM
RonKMiller's Avatar
Blow up or win
To quote Dire Straits: "Money for nuttin' and my chicks for free!" I like it but it would exceed my personal budget by at least $10.00 for "cheap ghetto mods that you won't find anywhere else"
Old Mar 7, 2002 | 10:21 PM
ninetyfourfd3s's Avatar
Newbie
Let us know how it works out... if it works well maybe you should add some fans to push more hot air out. It might not be flashy, but hey if it gets the job done...
Old Mar 7, 2002 | 10:26 PM
Manolis_D's Avatar
AHHHHH!!! you cut a 3" hole in an FD
edit-- seriously though... I'd imagine that Mazda put that metal on the frame there for a reason! Maybe i'm misunderstanding what you did with that holesaw...
I have a <much more common> 1990 FC, and i'd NEVER drill a hole in it anywhere...
Old Mar 8, 2002 | 09:55 AM
RonKMiller's Avatar
Blow up or win
If it works the way I envision, the suction created by the NACA ducts will provide alot more evacuation of the underhood air than could ever be provided with fans.
Only by measuring the temperatures will I find out - I'll keep everyone posted on the "science" part as it evolves. Later.
Old Mar 8, 2002 | 10:03 AM
Flybye's Avatar
Are you gonna take temp readings in different locations of the engine compartment?
Old Mar 8, 2002 | 07:48 PM
RonKMiller's Avatar
Blow up or win
Yep, the pyrometer has teflon coated wire with a sensor tip that I can run to multiple areas under the hood. It's accurate to within 2-3 degrees F, and even better if I calibrate it with a reference standard thermometer which is total overkill . I'll also do it over a range of speeds. Also records ambient temperature. I'm also going to stick it through a hole and measure the temp INSIDE the stock airbox above my K&N to see if my "ghetto cold air intake" actually works as well. (that mod almost broke the bank at around $20 for two pieces of choke heat riser tubing and some plastic epoxy putty...but I digress...) This may the first and only ever "real time" measurements ever done on an FD3S. Now when we say are cars are hot little bastards underhood we'll have some real numbers in Farhenheit to toss around! I'm so into dense air.......it's got to be the cheapest hp out there.
Old Mar 8, 2002 | 07:57 PM
RonKMiller's Avatar
Blow up or win
Yeah, not one - but two! (But it's only sheet metal and you can't see 'em so they don't count!) I can just imagine the engine sitting in my lap one day - french frying my nuts - after a head on and me thinking, "damn, I never thought about the crumple zone enginering on this sonafabitch!"
Old Mar 9, 2002 | 04:51 AM
amp's Avatar
amp
old yella
Re: Hot air OUT! New mod sucks! (REALLY..)
..uh
no flames intended but the original design/function of that vent is for the same purpose .. an exhaust for engine bay heat
Old Mar 9, 2002 | 08:56 AM
RonKMiller's Avatar
Blow up or win
Re: Re: Hot air OUT! New mod sucks! (REALLY..)
Originally posted by amp
..uh
Actually it's to ventilate the extra passenger side oil cooler for the R models. You really need to pull the fender to see everything.
All it's doing now (in stock form) is ventilating the inside of the fender cavity next to the bumper, there's no way for engine bay heat to escape and enter the duct, except for maybe a few small gaps far forward near the air cleaner. There is no real dedicated flow "path". I also removed the plastic dummy plate on the bumper to allow any additional fresh ram air (positive pressure) to enter the engine bay through the gaps. It's all about creating differential pressures and thereby flow. By far the hottest part of the engine bay is the passenger side above the turbos and exhaust toward the back near the firewall, and that's where my exit "tunnel" that I created is. Since hot air rises (positive pressure) it will accelerate to the bottom of the hood, enter the tunnel and be literally sucked out by the low pressure area created by the NACA duct and the cooler, denser (low pressure again) air on the outside of the fender. The same tunnel and duct I fabricated on the driver's side does the same thing, and the interior fender intake for the oil cooler is now blocked off inside the fender well also to increase the pressure differential and "sucking". Exhaust for my oil cooler now exits two grills that are in the front of the wheel well that I riveted in place flush with the liner. Of couse this all doesn't do a thing for you while sitting in traffic, and I'm sure at some really high speed it will start cavitating and reach maximum volume, but at that point you have so much fresh air ramming the front of the car it becomes academic. Only by measuring the real time temps at different locations at speed with an extremely accurate pyrometer like I have can I prove any of this works! And, it may not do a darned thing, but it sure is an interesting project and costs next to nothing to do, and my bet is that it works as well as spending 2 Large or more on a quality "vented" hood! (although I think the vented hood would obviously do a much better job for the intercooler and is absolutely neccessary with a larger intercooler to allow it to function at maximum capacity) I also like the challenge of doing everything I can stealth - I prefer the stock look and will bet that my car will be worth more in the future than highly modded ones with non OEM stuff bolted on. Don't get me wrong, I like some of the "fancy" exterior stuff - just not on my personal car. All I wanna do is go fast, save money and stay cool - literally.
Old Mar 9, 2002 | 10:42 AM
NickSimcheck's Avatar
Amen to cheap asses like me and Ron.
Nick
(does this count tho? i mean it isn't like there is a kit for something like this... and we're to cheap to buy it. and i'm sure it works.)
Old Mar 9, 2002 | 08:37 PM
RonKMiller's Avatar
Blow up or win
Nick
HAHAHHA! The kit is a feakin' roll of metal duct tape, a metal cutting hole saw and some metallic dryer vent duct! And you can buy it from my website for only - lemme' see - how's about $300.00 or so?
Well, that's what you get when you cross an old 2 stroke motorcycle racer fart like me with an FD3S! I did a preliminary run today with one fender on and one off just to get a feel. (kind of like dating a virgin!) The freakin' duct that was uncovered was damn hot -even after being exposed to fresh air - so I know that it is working - and - the top of my hood felt alot cooler than it usually does when I park it. Sheeeiit - it works! Now I need to develop the methodology for testing.......to make a valid scientific statement. On to the pyrometer.... Jeez, now I'm getting in really deep
Old Mar 9, 2002 | 08:53 PM
the_saint's Avatar
Ron: can you post pictures that are not sooo cropped. I am having a hard time visualizing what you are doing. sounds promising.
thesaint
Old Mar 9, 2002 | 10:51 PM
amp's Avatar
amp
old yella
Ron
Suggestion: upgrade those plastic fastener clips with new ones (redesigned) I have a friend who lost his while driving...now that you have increased the flow through those vents, its better to be safe...i was told that mazda does not sell the part separate from the fender...
Old Mar 10, 2002 | 12:19 AM
Devilish's Avatar
13Bfiscalirresponsibility
Me thinks hot air moves vertically, not horizontally. Put the 4" holes in the hood. That'd be nice and ghetto.
Old Mar 10, 2002 | 10:42 AM
RonKMiller's Avatar
Blow up or win
Ron
Yep - good thinking. I was able to take mine out without breaking them, but they are cheesy. I also replaced the plastic "mesh" insert in the NACA ducts with stainless steel 1/4 screen secured with QuikPlastik brand plastic epoxy putty. When I reinstalled the ducts I put a 1/4" strip of 3M "grey" outdoor double sided foam tape around the entire border of the duct - it's not going anywhere. The stainless mesh also looks better IMO.
You can purchase the duct by itself separate from the fender - it is around $140.00- crazy.. but not the individual fastners.
Old Mar 10, 2002 | 10:54 AM
RonKMiller's Avatar
Blow up or win
thesaint
Let's see if this helps:
Old Mar 10, 2002 | 10:56 AM
RonKMiller's Avatar
Blow up or win
AND this:
