nuetral switch, and idle problems
Old Mar 4, 2002 | 12:20 AM
mazdaspeed7's Avatar
mad scientist
I have had a high idle(~1500 rpm!!!) on my car for months and months. Nothing I have found yet has helped it. Had the intake manifold off 3 times hunting for vacuum leaks, and trust me, there are NONE. I replaced the clutch switch that affects the idle, still didnt fix it. BAC is disconnected, no change. My car has no emissions stuff, and therefore no vacuum lines, except the FPR. The throttle stops are all the way up, I sealed the hole in the main throttle plate, and the idle adjustment valve on top of the tB is all the way down, but the idle STILL wont drop below 1500. Sometimes the RPM's will drop below that, and the car will stall. It seems like the ECU is making my car idle high.
The other day my mechanic friend mentioned something about the nuetral switch making the car idle high when the car is in nuetral. I suspect this switch may be bad, b/c the idle does not change a bit between nuetral and in gear, with the clutch in, even though it should if the nuetral switch is good.
My question is what would happen if I bypass that switch? Unplugging it(never any continuity) would make the ECU thnk the car is constantly in gear, which, if I am reasoning correctly from what I was told, would make my idle normal. If it was constantly open(which I believe it is), would my idle not always be high then?
Old Mar 4, 2002 | 01:34 PM
mad scientist
bump
Old Mar 4, 2002 | 08:44 PM
mad scientist
FIXED!!!!!
It was a bad nuetral switch and bad clutch switch. I think the signals were conflicting(when both switches were bad) which was confusing the ECU a lot, and really screwing over my idle.
Old Mar 4, 2002 | 08:57 PM
live4boost's Avatar
AKA ShepFC3
did you just take the switch out and directly connect the wires? Or did you just buy new switches?
Old Mar 4, 2002 | 09:10 PM
mad scientist
I had a good clutch switch on my parts car, so I used that and simply unplugged the nuetral switch. It makes the ECU think the car is always in gear. I have an extra nuetral switch I might put on later.
Old Mar 4, 2002 | 09:13 PM
live4boost's Avatar
AKA ShepFC3
my clutch switch is bad, but I think that Ill just bypass it.
Old Mar 4, 2002 | 10:27 PM
kleach18's Avatar
Just Looking Around
where are the two switches
Old Mar 4, 2002 | 10:31 PM
live4boost's Avatar
AKA ShepFC3
clutch switch is under the dash on the drivers side above the clutch peddle. I don't remember where the nuetral SS is.
pp13bnos's Avatar
Pineapple Racer
so whats it idle at now? CJ (just curiosu)
Old Mar 4, 2002 | 10:39 PM
mad scientist
It was very very cold today, and I didnt have time to mess with the idle setting and TPS, but right now, it hunts between 900 and 1200, but very very slowly, a few seconds per cycle at least.
The nuetral switch is on the tranny.
Old Mar 4, 2002 | 10:46 PM
kleach18's Avatar
Just Looking Around
how do you know that the clutch is bad is there a way to test it
Old Mar 4, 2002 | 10:48 PM
kleach18's Avatar
Just Looking Around
can anybody help??????
Old Mar 5, 2002 | 08:15 AM
mad scientist
I checked for continuity with a volt meter when the switch was opoen and closed. It didnt change, so the switch was dead.
Old Mar 5, 2002 | 10:30 PM
mad scientist
Theres where the nuetral switch is.
Anyone else think this should be archived?
Old Mar 5, 2002 | 10:39 PM
Erik's Avatar
Best of both worlds
I do I do
Old Mar 6, 2002 | 03:58 PM
mad scientist
bump
Old Mar 6, 2002 | 11:04 PM
kleach18's Avatar
Just Looking Around
would i be able to see that from under the car or is it on top of the trans? i can't tell from the pic
Old Mar 6, 2002 | 11:09 PM
mad scientist
Its on the pass side, at the top of the vertical part. It is easy to get to from under the car. Ill take a pic of the tranny in the car next time I have my car on jack stands.
Old Mar 6, 2002 | 11:15 PM
kleach18's Avatar
Just Looking Around
ok so how would i test that to see if its bad? Volt Meter or what and what readings should it have?
Old Mar 6, 2002 | 11:18 PM
kleach18's Avatar
Just Looking Around
what would this cause the car to stall? only when its not in gear.
Old Mar 6, 2002 | 11:19 PM
RotorBalls's Avatar
Very good info here I give it a
Old Mar 6, 2002 | 11:24 PM
mad scientist
I checked for continuity when the car was in nuetral and in gear. If it changes, then the switch is good. Sorry, but I dont remember whether its open or closed in nuetral.
It caused the high idle in my car. No matter what I did, I could not adjust the idle down from 1500 rpm. It always seemed like the ECU was not letting my engine idle below that.
Kyo
Apr 13, 2019 09:24 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
Kruel13
Aug 26, 2015 12:17 PM
