Boost problem 7psi max!!
Old Feb 24, 2002 | 06:39 PM
turbovr6's Avatar
Angry Boost problem 7psi max!!
I can't give much info, I'm so pissed I don't want to think to much right now.
I know that my commander is reading .54 as max boost obtained. I have the commander set for .85 duty cycle about 85%
I recently removed my profec-b , I figured I'd just use pfc to regulate boost. 1 week after that I installed my front mount. Now that week in between I hardly drove the car so I'm not sure if it was something I did when I took out the profec, or something that happened when I installed IC.
Now if I remember correctly is'nt 7psi like the set level our system will run is the control system is'nt fuctioning???
Old Feb 24, 2002 | 07:22 PM
rx7speed811's Avatar
Accepting Donations.
do you have the stock pills in place?
Old Feb 24, 2002 | 07:36 PM
neevosh's Avatar
The Dude Abides
Check your wastegate solenoid and actuator. Make sure it's all plugged in correctly.
Old Feb 24, 2002 | 07:41 PM
turbovr6's Avatar
HOLY ****!! you just hit the nail on the head!!!! Before I put in the profec B the car had those ghetto home depot valves(previous owner). I never put them back.
THANK YOU SOOOOOOOOOOOOO MUCH
Old Feb 24, 2002 | 08:32 PM
Crash's Avatar
were can I get some of those boost pills and what are they call at home depot
same provlem after removing avc-r
Old Feb 24, 2002 | 09:00 PM
turbovr6's Avatar
It's amazing how the obvious problems seem to be the hardes to find huh?
If you want to put pills back in, order holley carb. jets from www.summitracing.com.
Do a search for boost pills in this section to find the sizes you need.
If you want to join team home depot racing.. go to the plumbing dept. you need a small brass valve. Depending on how many turns you give it will change your boost.
do a search for boost controller, or home depot, and you should find some pics, and a full explanation. I just dug up my old valve I saved. Putting it back in 2morrow
Old Feb 24, 2002 | 10:45 PM
Mach2's Avatar
Turbovr6,
did you get your problem fixed? I seem to be having the same problem, and I can't find the cause of it. I have the stock pills in place, and I replaced the wategate and precontrol actuators, and the wastegate and precontrol solenoids, and still only aprox. .58 kg/cm2 of boost. I have my commander set at .90 kg/cm2 and duty cycle set at 85% and still nothing. It's driving me a bit crazy now. They transition perfectly except the boost stops climbing at .58 . I used to have manual valves but I removed them to control boost from the commander, but I haven't been able to do that.
Old Feb 25, 2002 | 01:09 AM
no problem. thats my job :1party:
Old Feb 25, 2002 | 05:32 PM
JAMMNN's Avatar
Originally posted by Mach2
Turbovr6,
I have the same thing
Old Feb 25, 2002 | 06:55 PM
rx7_lover's Avatar
Turbovr6,
I replaced the wategate and precontrol actuators, and the wastegate and precontrol solenoids, and still only aprox. .58 kg/cm2 of boost. I have my commander set at .90 kg/cm2 and duty cycle set at 85% and still nothing. It's driving me a bit crazy now. They transition perfectly except the boost stops climbing at .58.
same problem w/ PFC here...
isnt 10psi close to 0.70~0.73 kg/cm2 ???
funny thing is... my Blitz boost gauge says im at 0.73 kg/cm2 ...
Old Dec 2, 2002 | 01:16 PM
r71's Avatar
r71
FOLLOW UP PEOPLE! DID YOU FIX THE PROBLEM OR NOT?
Old Dec 2, 2002 | 04:40 PM
jspecracer7's Avatar
1JZ powered
Reread the thread! This thing thread is 10 MONTHS OLD!
Th0m4s
Feb 26, 2019 02:04 AM
tiger18
Sep 3, 2015 08:27 PM
rx7shirley
Sep 2, 2015 02:11 PM
TerryD
Aug 23, 2015 07:40 AM
Wolf_
Aug 11, 2015 04:23 PM
