miata thermoswitch
Old Feb 19, 2002 | 10:17 PM
NOSkidRcr's Avatar
miata thermoswitch
does anyone know the exact "how to" for installing the miata thermoswitch, including all the things needed?
Old Feb 19, 2002 | 10:55 PM
Jonesboro's Avatar
Miata Thermoswitch Mod
I did the Mod. Here's what you need.
You need the Miata Thermoswitch. I got mine from PartsAmerica.com, it was a Beck/Arnley #2011621 and cost $26.99.
The electrical connector on the Miata thermoswitch is different than the thermoswitch electrical connector on the RX7, so that also needs to be changed. Go to your local pull-it-yourself salvage yard and get the thermoswitch electrical connector from a 90's Ford Probe (Mazda engine). If you're not sure how to identify the correct connector on the Probe, then purchase the Miata thermoswitch first and take it with you to the salvage yard. Then simple find the electrical connector that fits the switch. DO NOT get the thermoswitch from the Probe since it is NOT the lower temperature Miata thermoswitch.
The thermoswitch on your RX7 is behind the thermostat housing and is the lower, black color switch. It is difficult to get to. I had to remove the alternator to get at it. Remove and replace the thermoswitch. Remove and replace the electrical connector. The work space is very tight so be patient.
This is a worthwhile mod.
Old Feb 19, 2002 | 11:16 PM
juliof's Avatar
You beat me too it,you can also use the thermoswitch connector from a early 90,s Mazda 626 its just like the one in the Probe basically they are the same car with the same Mazda motor.Strange thing is my thermoswitch when it gets up to temp is shuting off the fans at 200F instead of 194F?I have a digital guage so I can check my temps.
Old Feb 20, 2002 | 10:09 AM
Jonesboro's Avatar
Hey juliof,
I learned it all from you. Thanks again.
Old Mar 17, 2003 | 06:34 PM
Goober's Avatar
de doober
The connector that I pulled from a 626 only has one blue wire as opposed to the connector thats currently on car with two. Do I splice it into both wires or just one of them? Thanks for the help in advanced...
Old Mar 18, 2003 | 12:45 AM
Goober's Avatar
de doober
D'oh nevermind... I'm an idiot...
Old May 21, 2003 | 12:37 AM
Zoomspeed's Avatar
exaclty what year range is the miata thermoswitch from?
also what year range for the connector from the probes or the 626?
So all that needs to be doen is put inthe new switch, then splice the connector and thats it?
Old May 28, 2003 | 07:39 AM
DaedelGT's Avatar
Uber Newb.
Originally posted by Mahjik
Malloy Mazda
1-888-533-3400
Talk to Ray Crowe, he'll hook you up with exactly what you need.
I plan on doing the mod as soon as I get the parts. Call the number above if you need any part help.
Old May 28, 2003 | 09:49 AM
KevinK2's Avatar
Miata switch works well in most cases. A quick test is to ground the lead to the switch, with ign key 'on'. Fans should come on. If not, fans still will not come on 'till 221F, even with 207F miata switch. May be just a later model issue.
Old May 28, 2003 | 03:08 PM
DaedelGT's Avatar
Uber Newb.
I'm talking to Ray right now and he seems to think that an extra electrical connector is NOT needed.
Old May 28, 2003 | 03:09 PM
DamonB's Avatar
I just used a simple spade connector on mine rather than bother to go to the junkyard. It's simple.
Old May 28, 2003 | 03:14 PM
DaedelGT's Avatar
Uber Newb.
Do you happen to have a write up on that (or a short explenation)? I've haven't really messed with electronics before. Just basic soldering.
Old May 28, 2003 | 03:18 PM
DamonB's Avatar
Then you're all set. The Miata thermoswitch just has a single small metal tab that a spade lug can slip onto. I cut off my old connector, crimped on a small spade lug and slipped it right into the Miata part. Piece of cake. The spade lug itself is tight enough not to fall off, no need for a true locking factory connector (though it would be preferable).
Old May 28, 2003 | 03:20 PM
DamonB's Avatar
Yep.
Old Mar 24, 2004 | 12:25 AM
tt2323's Avatar
Import Connoisseur
Some good info here...thought i should bring it back
Old Mar 24, 2004 | 12:22 PM
PandazRx-7's Avatar
Fast + Reliable = $$$$$
Anybody know what year miata that's off of?
Old Mar 24, 2004 | 12:34 PM
FormerPorscheGuy's Avatar
Yes it is for sale.
This is one of the easiest and best installs that I have done.
Old Mar 24, 2004 | 02:24 PM
RonKMiller's Avatar
Blow up or win
Originally posted by DamonB
Yep.
I love heat shrink tubing in different sizes to "fabricate"
molded waterproof connectors. The good stuff also has glue inside.
Old Mar 24, 2004 | 09:18 PM
cpa7man's Avatar
Racing is life!
If you order it from Ray at Malloy he sends you the spade conector for free.
Old Mar 24, 2004 | 09:21 PM
tt2323's Avatar
Import Connoisseur
I found the partsamerica part for $33.xx...whats ray charge? Granted this is generic i think?
Old Mar 24, 2004 | 10:05 PM
chiminoid's Avatar
no more problems, PLEASE!
got mine from ray for about $31 w/ free shipping. still haven't installed it because i don't know how to remove the alternator. eh... sooner or later i'll do it
Wicked93gs
42
Oct 7, 2015 11:58 PM
rxlevi7
Sep 26, 2015 07:28 AM
