Field AFC on a rotary?
Old Feb 14, 2002 | 11:39 AM
busy13b's Avatar
Om Namah Shivaya
Does anyone have experience installing/using a Field brand AFC??
Since they are also a VTEC controller, I'm guessing you'd have dealt with it on a Honda/Acura.
I am wondering if it is possible to control fuel in 2nd gen (series 5) using one of these?? I briefly had a chance to look at the wiring scematic the other day, and think it **might** be possible.
There are dip switches in the back that can be set for different appicatins, apparently.
I'm also thinking about how the Apex S-AFC is a universal unit designed to work with many cars- instead of dip switches, you set the type of air flow sensor. I **think** on the S-AFC, honda/acura and rotaries are set the same in regards to that parameter....
Anyway, as my rebuild nears completion, I am researching a way to control my VDI electronically. One of the easiest ways to kill two birds with one stone is to use a fuel/VTEC controller, with the VTEC changover output being used to control the VDI, probably through a simple relay/solenoid circut.
I am open to using the Apex V-AFC or the Field unit, but it jsut seems the Field unit is a better choice becaus of cost and its compact size.
So give me your input and maybe we'll break some new ground here...
Shawn
Old Feb 14, 2002 | 11:46 AM
1FastT2's Avatar
I dont know all that much about them but I imagine that if your car has a MAF sensor (which it does) you should be able to make it work.
Old Feb 14, 2002 | 02:10 PM
busy13b's Avatar
Om Namah Shivaya
Here is what I'm referring to, in case people weren't aware (see attachment):
I am pretty confident the fuel control portion will work on a rotary (especially the V-AFC), but need to find out more specifics on controlling the VTEC switch-over points.
From my understanding, once oil temp/pressure reaches a specified level in a VTEC engine, the VTEC solenoid can then be actifvated, causing the higher cam to come on-line.
What I would like to know is:
Does the VTEC controller send a positive or ground signal to the soleniod in order to activate it?
Old Feb 14, 2002 | 08:13 PM
RETed's Avatar
I'm running a Field SFC-HyperR.&nbsp If you need help, just ask...
-Ted
Old Feb 15, 2002 | 11:55 AM
busy13b's Avatar
Om Namah Shivaya
Of course, someone has already done it... so much for being a pioneer, sheesh
Actually, Ted, that is great news! I do have some questions:
How did you set your dip switches?
Will they be different for a N/A vs TII?
Would be interested in how it adjusts fuel..
Does it only make AFM adjustments at partial/full throttle? I believe the Apex unit can be programmed for part AND full throttle maps??
Under low/no load conditions, will the factory ECU's closed loop operation take over?
Shawn
Old Feb 15, 2002 | 01:34 PM
RETed's Avatar
I was actually using a Field SFC-VTEC before, cause it had one extra RPM adjustment over the regular SFC-Hyper.&nbsp The newer HyperR came out, so I replaced the SFC-VTEC cause it has the same 8 RPM bands.
8DIP bank - all UP/off except #2 and #4
4DIP bank - all UP/off
This should work for turbo or NA.&nbsp It should guarantee work for the 1986-1988 Zenki FC's, and it might work for the 1989-1991 Kouki FC's also.
The Field SFC units are adjusting at all times.&nbsp So your adjustments affect fuel delivery all the time.
Yeah, factory ECU closed-loop still works.&nbsp Adjustments are moot, as the closed-loop adjusts the fuel delivery anyways.
-Ted
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
