How do I chiping paint off my wheels???? Body kit wheels????
Old Feb 7, 2002 | 09:14 PM
79+80_rx-7's Avatar
Hey,
Anybody know how to get chipping paint off rims. The rims are gold underneath the chipping black paint, and lets you see the lines, which makes the rims look sweet. Does anybody know if there is some kind of solution to take off a top coat but not an undercoat. Are these rims part of a body kit???? They are Enkies (the centercap claims that), and the back of the Haynes Manual show some rims that look like them. Are they stock on a 79 rx7 (gs I think since it has a rear swaybar and sport mirriors)? dunno.... And Is the light on the back of my car part of a body kit, Look closely above each end of the light and you see cracks where bondo wasn't used sparingly??? I see them in pics on the erebuni kits ( http://www.erebuni.net/ge/mazrx779.htm ). Well let me know what you think!!! There should be pics of the light, and my wheels, but I don't know if they worked. LATERZ,
Andrew
Old Feb 7, 2002 | 09:16 PM
79+80_rx-7's Avatar
Another pic, like the wing???
Old Feb 7, 2002 | 09:18 PM
79+80_rx-7's Avatar
yet another
F:\rx7 pics\my rx7 pics\show\backleftfurtheroutnofront.JPG
Old Feb 7, 2002 | 09:20 PM
79+80_rx-7's Avatar
Sorry about that last one. Got confused
Old Feb 7, 2002 | 09:56 PM
RotorMotorDriver's Avatar
Seven Is Coming
My suggestion might be taking them to one of those "do it yourself" car washes with the high power hoses ya know? Try using a pressure washer, maybe even a sand blaster if you get desperate. If those sound too aggresive, try just a bristle brush and some water i guess...Hope that helps.
~T.J.
Old Mar 24, 2002 | 09:32 PM
79+80_rx-7's Avatar
Any one now where to get a key for the locking lugs? I want to take of the rims, take them apart since they are 2 piece, and have my friend vatte them at his work. I tried a presurewasher, and all it did was get them wet Any help is appriciated ) LATERZ, Andrew
Old Mar 24, 2002 | 09:53 PM
coldy13's Avatar
Yeah, shutup kid.
about the wing, no. but i love the color, same as mine
Old Mar 24, 2002 | 10:07 PM
79+80_rx-7's Avatar
it looks better from the front, than the back
Old Mar 24, 2002 | 10:13 PM
coldy13's Avatar
Yeah, shutup kid.
well, right now all i should be able to see is the back, cuz my car kinda just sits still, running on 2 plugs and all
Old Mar 24, 2002 | 10:15 PM
79+80_rx-7's Avatar
Old Mar 25, 2002 | 07:59 AM
DONNA's Avatar
if the original paint is baked on really good, you may spray a fine mist of brake fluid to soften the black paint, wouldnt leave it on for over an hour at first, it worked on mine anyways,,,,,and hard water sprayed right off, then soap them down good to get off the fluid, dont get it on your car paint,,,,,,good luck
Old Mar 25, 2002 | 12:46 PM
79+80_rx-7's Avatar
how do you spray brake fluid??? Or do you mean brake cleaner? THANX LATERZ Andrew
Old Mar 25, 2002 | 05:31 PM
JoseReyes's Avatar
RicanRider
Take an old bottle of windex or something that has a screw type sprayer, put the brake fluid in and spray.
Old Mar 25, 2002 | 05:33 PM
Felix Wankel's Avatar
Super Newbie
I didn't see a locking lug?
Old Mar 25, 2002 | 06:43 PM
79+80_rx-7's Avatar
All the lugs in the picture are locking. I will get a picture of them tommaro, when its day light. Or if you want right now LATERZ,
Andrew
Old Mar 25, 2002 | 10:06 PM
etherhuffer's Avatar
I have a later model set of gold Enkei's. I think these are anodized, not painted. I had mine bead, not sand, blasted, then painted them gold again and polished out the rim. POR 15 makes a 2 part water based urethane for the final clear coat.
Old Mar 26, 2002 | 01:21 AM
Seven Is Coming
I hear ATF takes off paint too, but I've never confirmed it myself...
~T.J.
Old Mar 26, 2002 | 07:35 AM
treceb's Avatar
about the locks. if you cant find anyone that can lend you a key, you can, drill it out very, very carefully.
Old Mar 26, 2002 | 08:13 PM
JIMMY54's Avatar
GSL-SE PRO
brake fluid works for sure! Or you can buy a can of paint remover. Comes in a spray. Turns the paint into a sludge. then paint your rim whatever color you want. the best thing to do is to polish the lip and then clear coat everything.
Th0m4s
Feb 26, 2019 02:04 AM
82streetracer
Aug 23, 2015 09:28 AM
