18x10 on all 4's?
Old Jan 31, 2002 | 02:07 PM
GoRacer's Avatar
Speed Mach Go Go Go
Question 18x10 on all 4's?
This was mentioned in a 3rg gen thread that M2 and I think someone else had that setup without rubbing...is that possible?
If so, what offset's? Where are the tire guru's that answered before?
Old Jan 31, 2002 | 02:58 PM
SleepR1's Avatar
Max will have to respond to his question...I'm growing weary...
Old Jan 31, 2002 | 04:30 PM
GoRacer's Avatar
Speed Mach Go Go Go
here's a link
I think I found this from the same thread I read earlier.
In the tire section says he runs 18x10's on the track.
http://www.geocities.com/valspeed/
Old Jan 31, 2002 | 07:16 PM
gfelber's Avatar
I run 18x10 with no rubbing
Max and I both run 18x10 CCWs on all four at the track with 285-30s. Call or e-mail John at Complete Custom Wheel to get offsets (www.ccwheel.com).
Pics of these wheels on my car at the bottom of page: http://www.purplemantis.com/Mantissa..._Atlanta_2.htm
Gene
Old Jan 31, 2002 | 11:39 PM
maxcooper's Avatar
WWFSMD
For me at least, one of the keys to avoiding rubbing is running the ride height at relatively stock levels. I like the way the car works best at that height anyway. If you want to run the ride height really low, you might run into rubbing problems.
I have done three or four track events with the wheels and they only rubbed once, under full braking and full steering lock (oops!). They caught the fender lip just a bit. I was able to bend it back without any paint cracking or cosmetic damage. I raised that corner up a turn and haven't had any trouble since.
Here are pics and info from my web site:
http://www.maxcooper.com/rx7/parts_i...w18/index.html
-Max
Old Feb 1, 2002 | 12:29 PM
GoRacer's Avatar
Speed Mach Go Go Go
Thumbs up I'm glad I waited
Nothing worse than spending money then after wishing you had bought something else. I was going to go with 17x8.5-F & 18.9.5-R.
I was originally looking at the Blitz 03's, they just look sweet. No one can tell me what they weigh but supposedly not light.
So if I can get the correct backspacing, i'll get the Racing Hart CP-035R...else CCW.
One thing I don't understand though?
* Doesn't the backspacing or offset have to be different for front and rear? ...if the same, that means tires can be rotated.
I allways thought you needed more backspacing in front or had to use less width?
Thanks guys, you rule!
Old Feb 1, 2002 | 03:35 PM
msv's Avatar
msv
The valspeed site is mine.
I run the 18x10's all around at the track and on the street. They have 53mm offset front and rear, with 285/30-18 tires. I, like Max, run at relatively stock ride height, and as he mentioned, that is the key. I don't feel it necessary to lower the car any further. Even on the street I don't have any rubbing except when I hit a really big bump or pothole.
Other factors that are going to matter in this regard is your overall suspension setup, i.e. spring rates and dampers, bump stops, and even anti-roll bars.
Mark
Old Feb 1, 2002 | 06:42 PM
Johnny's Avatar
OG
Ah..well stock front to back is 50mm offset..so what makes you think you need different offets...
I thought alot about doing 18x10 all around..but then really thought about it more and realized I'm not tracking my car an awful lot..so I went with 18x9 and 18x10..both with 50mm offset..I may be slightly lower then stock..if any at all..
Old Feb 2, 2002 | 03:14 AM
maxcooper's Avatar
WWFSMD
I run 17x8.5" and 17x9.5" wheels on the street. When I drive around on the street with the 18x10" wheels on (to go get gas or back to the hotel after the first day of a track event), the car requires more attention to keep going straight, because it follows grooves more easily -- more "tramlining" I think it is called. There is a cost for running really wide tires on the front, but I certainly understand the desire to get more rubber on the road. Just be aware that the ride will be more harsh and you'll need to give more steering input.
-Max
H2o
11
Mar 1, 2003 04:09 AM
agent712
13
Dec 29, 2002 03:22 PM
LT1-7
Oct 8, 2002 05:26 PM
