Midpipe install : smog pump question
Old Jan 28, 2002 | 03:06 PM
GsrSol's Avatar
Z06 powered FD
Question Midpipe install : smog pump question
I know I can just plug up the hoses to the cat, but can I just unplug the pump from the harness and the check engine light won't come on and everything will be fine?
I don't want to leave the hoses hanging and recirculating the air under the car.
Old Jan 28, 2002 | 03:56 PM
HedgeHog's Avatar
Rotary Poseur
let it blow into the atmo...it's a one way check valve so it shouldn't suck ne-thing in. If u unplug the air pump u'll need a resistor to fool the ecu. most ppl get that annoying unstable idle if the air pump is unplugged.
Old Jan 28, 2002 | 03:58 PM
cewrx7r1's Avatar
Eye In The Sky
The air pump also supplies air for the exhaust manifold which helps the O2 sensor to do it's job correctly!
Old Jan 28, 2002 | 04:34 PM
7-sins's Avatar
thats not paint....
I have it vented into the atmo. no problems.
Old Jan 28, 2002 | 09:51 PM
GsrSol's Avatar
Z06 powered FD
OK, looks like I'll just vent it into the atmosphere.
Thanks Guys
12abridgeport
Aug 17, 2015 06:28 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
