T72,t78,t88,t100??????
Old 01-06-02, 11:27 AM
VIPERKILLER's Avatar
What do these numbers represent? I always thought the T78 is better than the T72 as the T88 is better than both and T100 is better than them?!?!?! But it doesn't seem to be the case.....and I really never have gotten the right answer then!!!! I have unlimited budget for the turbo for one, I want to produce INSANE INSANE hp on my 13B....the fuel system, ecu, and ignition have been acounted for....WHAT TURBO???? I want something that is RIDICULOUSLY FAST!!!! At least 10's on the street.........WHICH ONE?? PLEASE PLEASE PLEASE PLEASE HELP ME!!!!!!!! AND WOULD A T100 be GOOD????
Old 01-06-02, 12:21 PM
Greg's Avatar
Re: T72,t78,t88,t100??????
Well , since you have the money I would get a Thumper 88 (not the Greddy 88) and periphial port the engine Also get a HKS Tranny and you cant loose
Old 01-06-02, 12:37 PM
Hey whatz a Thumper 88???? And how much is it? And what is a peripheral port? And how much for HKS Tranny?
Old 01-06-02, 12:41 PM
'Tuna'
crispeed's Avatar
TS04, T-61, T-64, T-66, T-70, T-72 and the T-76 all belong to one family of Turbos made by Turbonetics called the Competition T-Series! They are all based on Garrett turbos.
Also in the Turbonetics family of competition turbos there is the Thumper Series! The T-88, T-91, T-100 all fall under this series from Turbonetics. Basicaly in all of the above turbos the # represent the size of the compressor wheel in millimeters and thus the compressor performance. The higher the # the greater the air flow capability!. Roughly the TSO4 is capable of 550hp and the T-100 is capable of 1600hp!
The Greddy T-78 and T-88 are another series made by Mitsubishi turbos of Japan! The #'s on these turbos don't represent the size of the compressor wheel but actually the performance output of the turbo. So then the T-88 flows more than the T-78. In comparison with the Turbonetics turbos the Greddy T-78 would be close to the T-66 and the Greddy T-88 to the T-76.
Go to www.allturbos.com for info on the Turbonetics family of turbos.
crispeed
87TII
9.20@150mph
Old 01-06-02, 02:27 PM
WOW!! Thanx Crispeed.....u've opened my eyes to a new world!! Seriously thanx.....thats the best info I've received in a while!!
Old 01-06-02, 04:23 PM
toppdogg_1's Avatar
check out this T100
i heard that you need at least a small block 302 to even produce enough exhaust gas to run this thing.
Old 01-06-02, 05:30 PM
RX7_RCR's Avatar
Uh, how old are you?
I suggest you stick around and read up some more. Also, I suggest you consult with a reputable shop to help build that "10 second street car" for you. Just remember, Power is nothing without control. You have a loooong way to go ViperKiller-san.
Old 01-06-02, 05:43 PM
I Sold My Car 2 the Devil
wonder1and's Avatar
Thats alot of turbo....
Old 01-06-02, 08:07 PM
Greg's Avatar
there is no need to flame the guy for asking questions
Old 01-06-02, 08:18 PM
AJatx's Avatar
That compressor could swallow a small child!
J
Old 01-06-02, 08:45 PM
'Tuna'
crispeed's Avatar
J
And a flock of birds and small flying aircrafts!
crispeed
87TII
9.20@150mph
Old 01-08-02, 01:20 AM
JUN S14's Avatar
Excellent info by crispeed except for the GReddy turbos. GReddy T78 has a TD-07 compressor and a TD-08 exhaust turbine. GReddy T88 has a TD-08 compressor and a TD-08 exhaust turbine. T78 has a 67mm compressor wheel, not sure about the T88. The T88 turbo is definitly smaller than a garrett based T76, it's slightly smaller than a T72... I'd say it's around the size of a T70.
Old 01-08-02, 11:53 AM
'Tuna'
crispeed's Avatar
The T-88 Greddy might me smaller in compressor size in comparison to a Garrett T-76 but it's not in compressor performance. For one the Garrett based turbos are 6 blade compressor wheels and the Greddy are 8 blade ones! You just can't compare them based on the inducer size only!
When you rate turbo performance it's not just by the size or by what the compressor is capable of producing but also you have to take the turbine side into consideration.
It's obvious that a T-76 match with a T-3 turbine section would not operate at it's maximum HP capability like as if it was match with a Q-trim turbine section.
One of the reasons why the Greddy T-88 turbo is capable of supporting a little extra HP over the T-76 is because of the turbine section. The turbine section of a T-88 would swallow the Q-trim Garett based turbos for breakfast!
As for the HKS turbos they are all based on Garrett designs.
The TO4S is just a 60-1 with a P-trim turbine section.. The only T04R I saw from them was a 60-1 compressor section machined to fit either a 66 or 70 mm compressor wheel or what is known here as the 66-1 or 70-1 with a clipped P-trim turbine wheel. I have seen the old T-51R but not the Kai or modified latest versions. The one I saw someone had already machined the compressor to fit a 76mm compressor wheel! The turbine section was a Q-Trim!
As for the new T-51's available from Garrett they come in various compressor and turbine trims. I saw one trim that was very interesting . It had a 10 blade clipped turbine wheel vs. the regular 11 blade design and was much bigger than the Q-trim or even the turbine section of the Greddy T-88!
Also the Garrett T-51 and some of the HKS turbos are based on large frame heavy duty commercial designs but the turbine housings were cast to fit and bolt to a regular TO-4 manifold.
crispeed
87TII
9.20@150mph
Old 01-09-02, 12:28 AM
Boostn7's Avatar
In addition....
T51R Kai=> 70mm compressor wheel with a 71mm/82mm turbine wheel(bigger then Q-trim) with 1.0 A/R
T51R SPL=> 76.5mm comp. wheel with same turbine side.
which would flow more??? -6 bladed or 8 bladed 66mm compressor wheel... Mitsu turbos (T78 & T-88) seem to flow well in low boost and as well in high boost.
John D
Old 01-09-02, 06:16 AM
Greg's Avatar
So with the information that you and John gave would it be safe to say that the Garrett T-76 Ptrim is around the equivalent to a HKS T51 SPL, as the compressor wheels are both 76mm and that all hks turbos are based on the garrett turbo. With people knowing this info people would be able to stop looking at the huge turbo systems and be able to fabricate a system of the same specs for half the price. Thats the Power of information
Old 01-09-02, 06:44 AM
Freedoms worth a buck o'5
Maxthe7man's Avatar
Crispeed--> any comparison info or links for the size of the compressor wheels with different number of blades and their flows?
Alot of centrifugal chillers(they are basically a huge turbo driven by an electric motor through a gearbox) have similar output and sized wheels with different number of blades, they alter the pitch of the blade to increase or decrease capacity for a given sized wheel family, not the number of blades, but on fans they decrease the number of blades and invert the angle of attack to increase the fans abiltiy to move air against a higher static pressure, I am sure the same rules would apply to turbo's..Max
Old 01-09-02, 05:53 PM
Chris Wilson's Avatar
crispeed
87TII
9.20@150mph
DO HKS actually make their own turbos? I was of the impression they only had cast, or maybe cast, the compressor housings with HKS name cast into them? My HKS TO4E seems a stsock Garrett unit, no reference to HKS to be seen on it whatsoever.
Thanks, greta turbo info, not sure I follow the Trim lettering, can you explain trim and how it is designated a ltter? Cheers.
Old 01-10-02, 12:37 AM
rmani's Avatar
crispeed
87TII
9.20@150mph
thanks for this post crispeed just when i thought i had the whole turbo sizing and companies figured out you've openned my eyes. i appreciate the thorough explanation.
Old 07-20-07, 09:48 AM
phs
phs's Avatar
Smile
very intresting topic you guys seem to know alot about turbo details so i thought you could help me out with some info
im very keen on buying a
"Turbonetics TO4S T-72"
what are they worth ? would i be better getting say a garrett T-70 ? or a Masterpower T-60 GT P ?
wanting to achive good power and quick spool
i was bassicually ready to buy a : "TO4S T-72"
COMPRESSOR HOUSING - TO4S .70A/R 4'' INLET 2.5'' OUTLET
COMPRESSOR WHEEL - 72MM (2.840'' INDUCER 4.030'' EXDUCER)
CARTRIDGE - OIL COOLED / JOURNAL BEARING / BIG SHAFT
EXHAUST HOUSING - T4 .81A/R TANGENTIAL V- BAND 3'' OUTLET
EXHAUST WHEEL - P TRIM , 10 BLADE
would this be a reliable and good choice ?
any thoughts would be great guys thanks phil
Old 07-20-07, 10:12 AM
Down for the count...
Comitatus's Avatar
Woot....5 years later!
Old 07-20-07, 10:30 PM
phs
phs's Avatar
yeah 5 years later shoud i of started a new thread ?
i did a web search of the turbo i wanted to buy and this came up so i bumped it.
really need o know if im makeing the right choice buying the T-72 TO4S ?
need some thing reliable ans able to make 300KWs at the treads with as minumal lag as possible
Old 07-20-07, 10:49 PM
This sounds like an XS Power made-in-china piece of **** turbo. Did you find this on ebay? Who manufactures it?
Old 07-20-07, 10:50 PM
Question
convert 300KWs to 'regular' horsepower for me. What kind of rwhp are you looking for?
P.S. The thread starter from 2002 is a real prize
Old 07-21-07, 02:27 AM
diabolical1's Avatar
didn't he finish his car and find it too slow for his taste and get a Koeing Competition or McLaren or something?
Quick Reply: T72,t78,t88,t100??????
