FD rims on an FC
Old Dec 15, 2001 | 11:11 PM
rxBUN's Avatar
FD rims on an FC
Do the stock 16x8 FD rims (5-bolt) fit on a FC (5-bolt)?
Old Dec 15, 2001 | 11:14 PM
cymfc3s's Avatar
I Raise Chickens
the rears will fit fine, the fronts wont fit unless you use a 1" spacer.
Old Dec 15, 2001 | 11:17 PM
rxBUN's Avatar
so the bolt pattern, just need a spacer for the front?
OK anyone selling rims ?
Old Dec 16, 2001 | 01:07 AM
Scott 89t2's Avatar
SOLD THE RX-7!
if you run GC coil overs and chop away the unneeded perch do they still hit? even with say -2.5 degrees camber? (more - camber = more room)
Old Dec 16, 2001 | 01:28 AM
cymfc3s's Avatar
I Raise Chickens
youd need to clear a good 1 inch of space. Even if you removed some material, youd still need a spacer.
Old Dec 16, 2001 | 03:29 AM
ROSHX7's Avatar
I had these on my car at first. Stock FD wheels are +50mm offset. Our FC offset if +38mm. So the FD wheels tuck into the car way too much, so that's why you need spacers up front, because the fender doesn't have that much space and it rubs onto the shocks without them. The bad thing is you should really spacer the backs too, otherwise if you look at the side of your car, the back tires are so pushed in and the front stick out so much...looks weird and handles a bit awkward too.:p
Old Dec 16, 2001 | 03:31 AM
jmseven's Avatar
Asset is Wealth
Yes, you do need a spacer. There are job shops that do mfg aluminum spacers...pro job...@ $125 as set? The spacers are needed to clear the front calipers for t2's. I have seen the FD wheels on an FC and on a '90 mx6 Turbo....very nice!
Old Dec 16, 2001 | 09:35 AM
TurboII RudeBoy's Avatar
Post count is over rated
i got fd rims on mine i'll post piks tonite, u need a 5/16 inch sapcer in the front and u have to run 205 -50 or lower profile in the front back doesn't matter,made my car look real nice
Old Dec 17, 2001 | 04:53 PM
pp13bnos's Avatar
Pineapple Racer
Hey guys, so whats the final spacer size i need for the front, and rear. I'm getting ready to have some made, and need to know asap. pictures would be nice too. CJ
Old Dec 17, 2001 | 04:58 PM
neofreak's Avatar
accept no imitations™
I have a set for sale, nudge nudge wink wink. =) $400
deadtamagotchi@hotmail.com
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
