steering wheel install on 93?
Old Dec 7, 2001 | 02:11 AM
I am going to install my new steering wheel, and was wondering if i could get some pointers on taking off the stock wheel. Do i have to do anything about the airbag or will everything come right out?
thanks
Old Dec 7, 2001 | 01:23 PM
manatecu's Avatar
wheel
Taking the wheel off is really kinda easy. Lots of people told me different ways to remove the steering wheel. Steve C's site says there is a little button or something behind the wheel but that is not the easiest way and not how mine came off. What I did was take both hands and place on the top of the wheel. Note: all bolts were removed and it looked as nothing was holding it in place. I then began to thrash back and forth with my arms in the locked position. Within 15 seconds the wheel began to move and bam it easily pulled off. Note: The easiest way to keep the horn is the use the spinning wheel wires. The wheel is located behind the steering wheel. Many sites tell you to remove this device but I didn't. I cut all the wires and tighted them into the horn ground. If you need more details I can provide just let me know.
Chris
Cstrain@coxnc.rr.com
Th0m4s
Feb 26, 2019 02:04 AM
